Got Vette Wheels??...Post pics here...!
Old 08-12-2010, 05:47 PM
  #251
CRAMOS78's Avatar
Car: 92 camaro
Engine: stroker
Transmission: Megaraptor
Re: Got Vette Wheels??...Post pics here...!
ok, im new at this photochop thing, im just trying to see who they look, what do u think
Old 08-12-2010, 05:56 PM
  #252
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
Too big, I just don't like the look of big rims and little brakes.
Old 08-12-2010, 06:08 PM
  #253
CRAMOS78's Avatar
Car: 92 camaro
Engine: stroker
well those were photochoped, and not very good. but the ones im looking at are the 18x10 in the back 17x 9.5 or 18x8.5 in front. but that style wheel.
Old 08-15-2010, 03:43 PM
  #254
CamKid1992's Avatar
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
personally, one of the best looking wheels on a thirdgen. just got them finnaly installed yesterday. 17 by 9.5 in fronts with 2.5 in spacers. and 275 tires. and 18 by 10.5 in rear with 2 in spacers and 305 35r18's
Old 08-15-2010, 03:48 PM
  #255
CamKid1992's Avatar
Car: 1992 Camaro
Transmission: t-5
Originally Posted by 396l35
P315/35R17 on 17x11 with a 7.8" back space and 2" spacers. P275/40ZR17 on 17x9.5 with a 7.1" back space and 2.25 spacers but I think I have to push it out another .25" so I dont hit the drag link. No rubbing in the rear and slightly touching the inner fender in the front with stock suspension. The wheels were listed as 17x11 50mm and 17x9.5 53mm if you dont want to convert from metric. I hope this helps, Mark
just wanted to say thanks for calling me up and for your help i think it looks great and the spacers came 4 days before they were suppose to. look at the above thread to see the new wheels and thanks again for your help.
  #256
King NothingSS's Avatar
Car: 2001 Camaro SS
Engine: no engine yet :)
Transmission: T-56 with z06 drive gears
Axle/Gears: most likely 12 bolt or 9" with 3.91
pics no work
Old 08-15-2010, 08:39 PM
  #257
396l35's Avatar
Car: 3 1969's and original owner 1987
Not a problem Josh, now get those pictures up so we can see your work...
Old 08-15-2010, 09:05 PM
  #258
CamKid1992's Avatar
Car: 1992 Camaro
Transmission: t-5
ill just show them like this cant figure out how to make them smaller then to upload with the url.
Old 08-15-2010, 11:54 PM
  #259
CamKid1992's Avatar
Car: 1992 Camaro
Transmission: t-5
hmm fixed themselves
Old 08-16-2010, 04:27 PM
  #260
Ryder85's Avatar
Car: 1985 Camaro Z28
Engine: LS2
Axle/Gears: 3:73
18x9.5
245's in front
285's in rear
BF GForce2
Old 08-16-2010, 04:49 PM
  #261
dust3r's Avatar
Car: 1986 z28 & 1992 z28
Transmission: 700-R4
Originally Posted by Ryder85
18x9.5
245's in front
285's in rear
BF GForce2
Is that the original paint? I really like the dark (charcoal?) ground effects with the stripes.
Old 08-16-2010, 04:58 PM
  #262
Ryder85's Avatar
Engine: LS2
Axle/Gears: 3:73
its the original color, i had to have it repainted a few years ago due to the OEM paint defect. its silver metallic, it was a rare paint combination. it looks amazing at night.
Old 08-17-2010, 05:23 PM
  #263
BloodyBlueBird's Avatar
Car: 86' Firebird
Engine: 350 c.i. swap
Transmission: G-Force T5
Did they even make zo6 rims that were 18x10's up front??
Old 08-17-2010, 05:53 PM
  #264
Car: 86' Firebird
nevermind they are the 18/9.5
Old 08-18-2010, 12:35 AM
  #265
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
There's really nothing stopping you from trying to bolt a "rear" 18x10 on the "front"...
Old 08-24-2010, 02:24 PM
  #266
91camarosRS's Avatar
Car: 02wrx/88 rs
Engine: 2.0L turbo/nothing yet!
Transmission: 4eat/waiting on a t56
so what is the widest 18 that you can run on the front? and tire size? i want to run the same all around so i can rotate
Old 08-24-2010, 11:52 PM
  #267
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
You're going to hate driving if you go wider than 10" wheel/285 tire in the front unless your roads are awesome and your suspension/steering is in great shape. Just the nature of the beast. With proper fitment you can fit huge wheels in front. There are a few running 18x10 w/ 305 or 315 tires. Definitely not the norm, or easy, but doable.
Old 08-25-2010, 06:40 PM
  #268
Car: 02wrx/88 rs
Well I'm not going to hijack this thread so ill make it quick. I want to build a hot street car built for auto cross and track. So I like the wide wheels all around. So what do you think is a good size all around?
Old 08-25-2010, 06:45 PM
  #269
firechicken76's Avatar
Car: 88 Trans am GTA
Engine: 2002 Ls1
Transmission: t-56
Axle/Gears: Ford 9" 4.11 gears w/ locker
So do all these c5/c6 wheels require spacers or adapters?
Old 08-25-2010, 09:33 PM
  #270
oscarsrs's Avatar
Car: 91 RS/ QX56/Altima 3.5 SE
Transmission: AUTO
Axle/Gears: ?
Front = YES
Rear = depends
stock =yes
4th Gen rear end = no
TWON_3rdGEN (12-23-2019)
Old 08-25-2010, 11:08 PM
  #271
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Originally Posted by oscarsrs
Front = YES
Rear = depends
stock =yes
Except for mine, which came with a 26mm offset. 17X8.5, no spacers required, I bought them at Discount Tire and was told not long after that the vendor doesn't make that offset any more.
Old 09-02-2010, 10:56 PM
  #272
breynolds's Avatar
Car: 91 Firechicken
Engine: 355ci SBC
Transmission: 97GM BW T-56
Axle/Gears: 9", Moser 31 Splines 3.73s Trac Loc
I picked up a set of 2002 C5 5 spokes, 17 front, 18 rear. Consensus is that at stock springs, 2 inch spacers all around is what will work the best. Where do you find these for the best price? Also, what's a good staggered tire size setup that won't rub without modifying the inner fenders and fender lips?
Old 09-03-2010, 12:08 AM
  #273
Fords88Bird's Avatar
Car: '88 Firebird Z20
Engine: 305 TBI w/TBI mods
Axle/Gears: Stock
Iansane, it's been a while. You back on the road. Later.
Old 09-03-2010, 01:06 AM
  #274
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Yeah. The bird is back to my daily driver status. The bicycle sucked.
Old 09-04-2010, 10:09 PM
  #275
CRAMOS78's Avatar
Car: 92 camaro
Engine: stroker
so josh006, can u fix ur pics......
Old 09-16-2010, 01:13 AM
  #276
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Attached Thumbnails Got Vette Wheels??...Post pics here...!-dscf1564-small-.jpg   Got Vette Wheels??...Post pics here...!-dscf1568-small-.jpg   Got Vette Wheels??...Post pics here...!-dscf1569-small-.jpg
Old 09-18-2010, 01:35 AM
  #277
CamKid1992's Avatar
Car: 1992 Camaro
Transmission: t-5
Not sure what's up. When I'm logged on they work. If not they don't. trying get them off my phone now.
Old 09-18-2010, 01:41 AM
  #278
CamKid1992's Avatar
Car: 1992 Camaro
Transmission: t-5
Old 09-19-2010, 01:23 AM
  #279
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Originally Posted by watajob
Any larger pictures? Can you email them to me? Are those 18s? Look good.
Old 09-20-2010, 01:51 AM
  #280
CamKid1992's Avatar
Car: 1992 Camaro
Transmission: t-5
lets try this... made pics smaller hope you can see them. lmk if you cant.
Old 10-04-2010, 09:22 PM
  #281
jer4251's Avatar
Car: They all sit.
Engine: LB9,LB9, LS1, LT4, LT4
Transmission: T5, T5, 4L60, T56, T56
if i can get my hands on some spacers ill have some pics to add to the pile.
Old 10-04-2010, 10:17 PM
  #282
CRAMOS78's Avatar
Car: 92 camaro
Engine: stroker
sorry josh, nada.....
jer4251, just post pics of the rims, that way we can imagine them on our cars
Old 10-05-2010, 03:53 PM
  #283
Car: 86' Firebird
I feel ya! I'm in the same position right now. I'm just gonna buck up and buy some ebay ones though. I think I can trust the quality of them.
Old 10-05-2010, 08:55 PM
  #284
adamwbennett's Avatar
Could you by chance tell me what size tires you have on there. I just bought a set of those for my 88 camaro and I wasnt sure if the stock vette size tires would fit ok or not.
Originally Posted by 19 Trans am 82
Here is my old 82 with some wagon wheels.
Its still a work in progress, I think it needs lowered.
Old 10-06-2010, 12:11 AM
  #285
rapid rods's Avatar
Car: 87 iroc z28
Engine: 89 C4 TPI ,
Transmission: ZF6 speed , 89 C4
Axle/Gears: 89 corvette rear end
Hey if any of you guys need some spacers for the Vette wheels, I have some for sale.I used them on my 3rd gen , when I had 89 Vette wheels on it. They were custom made Billet, for the offset !!! 1(650)867-3946.p.s I paid $600.00 when new. Bryan
Old 10-06-2010, 01:06 AM
  #286
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
I'm using ebay spacers and my car drove off a cliff.
Old 10-06-2010, 01:11 AM
  #287
CamKid1992's Avatar
Car: 1992 Camaro
Transmission: t-5
i have ebay spacers on my car no problem work great. same as if you were to buy from hawks except theres are 100 bucks more.
Old 10-06-2010, 03:27 PM
  #288
89blues's Avatar
Car: 1989 IROC
Axle/Gears: 3:23 Torsen 4th gen rear
Some pics of my car from last weekend. C5 Z06 18x9.5 all around. No spacers on back...4th gen rear.
Old 10-06-2010, 04:46 PM
  #289
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Here is some pictures of my 87 with 96 Grand Sport wheels...
And the money shot...
Are those 9.5 rears?
Old 10-06-2010, 08:56 PM
  #290
CamKid1992's Avatar
Car: 1992 Camaro
Transmission: t-5
tgo just dont like me lol try smaller pics i took today.
Old 10-06-2010, 08:57 PM
  #291
CamKid1992's Avatar
Car: 1992 Camaro
Transmission: t-5
let me know if those pics worked yet. they all work when im signed in.
Old 10-06-2010, 09:44 PM
  #292
dust3r's Avatar
You can't link to the image that is attached to an email like that because we need to be logged in to your email account to view the images. You will need to download/save the image from the email attachment to your hard drive and then attach the image file to your post, or use a website like imageshack.us to host your file and paste the link in your post.
Old 10-07-2010, 01:43 AM
  #293
CamKid1992's Avatar
Car: 1992 Camaro
Transmission: t-5
i tried photo bucket and i tried linking them as an attachment. neither worked. one last shot with photo bucket...
Old 10-07-2010, 01:51 AM
  #294
CamKid1992's Avatar
Car: 1992 Camaro
Transmission: t-5
camaro7.jpg?t=1286434229
Old 10-07-2010, 02:08 AM
  #295
CamKid1992's Avatar
Car: 1992 Camaro
Transmission: t-5
camaro8.jpg?t=1286435086
camaro7.jpg?t=1286435086
camarowarped.jpg?t=1286435086
camaro2.jpg?t=1286435231
Old 10-07-2010, 02:14 AM
  #296
CamKid1992's Avatar
Car: 1992 Camaro
Transmission: t-5
At last... if there working on my phone I assume there working now thanks for the help lol and thanks for those who helped me get through my wheel process.
Old 10-07-2010, 02:19 AM
  #297
CamKid1992's Avatar
Car: 1992 Camaro
Transmission: t-5
Check it out finally got pics to work.
Old 10-07-2010, 08:50 AM
  #298
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I've correctly got a set of 92 Anniversary wheels on my Berlinetta. They are real nice - but I just gotta' get some new rubber so I can get the ZR1's re-mounted !
Here's a pic from when I had my C5's installed.....
Here's it is with ZR1's installed:
Some wheels just don't look right with certain cars / colors. IMO; The silver ZR1's work with every color combination...... It may just be the perfect 17" wheel for just about every ThirdGen !
Old 10-07-2010, 05:33 PM
  #299
CRAMOS78's Avatar
Car: 92 camaro
Engine: stroker
way to go josh, car looks good with those!!!
what size are they?
Old 10-08-2010, 01:57 AM
  #300
Z28FAST1's Avatar
Going from these...to these:
to these:
Anyone know off the bat what spacers I need?
PRODUCT: C5 Style Deep Dish
FRONT WHEEL SIZE: 18x9.5
FRONT WHEEL OFFSET: 54mm
REAR WHEEL SIZE: 18x10.5
REAR WHEEL OFFSET: 56mm
Quick Reply: Got Vette Wheels??...Post pics here...!
