Got Vette Wheels??...Post pics here...!
#951
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
Re: Got Vette Wheels??...Post pics here...!
Well this is the first time my car has seen the ground since the day I bought it in august. I still need to adjust and align it
Did weight jacks and konis all around, everything suspension wise brand new or custom made and I built a 3.5" stainless exhaust.
Here she is on c4 zr1/ss rims.
4th gen rear
1.75" adapters up front on c5 z06 brakes.(adds 0.300")
Sorry for the cell pic. Once its out ill be doing a photoshoot
Jay
4th gen rear
Jay
#953
Please tell me what rear suspension you are running is that a IRS late corvette? Would like to confer with you regarding difficulty of swap?
Thanks,
Carl 336-707-2328
Thanks,
Carl 336-707-2328
#954
hey guys, can someone help me, I have a set of 18''x9 boss 304 wheels, so I got 2010 camaro brembo brakes, I installed my brakes and my wheel wont fit over them so I borrowed a 18'' cobra mustang wheel and it fits perfect! the design of my wheel is the problem.pic of cobra wheel
next question? does anyone on here have these wheels wheelswww.oewheelsllc.com/Clearance/Wheels-for-Chevrolet/Corvette-C5-Deep-Dish-Wheel-Matte-black_3#.U35lXPldU71 if so can you measure the inside distance of the barrel for me? I really dont want to order these wheels to find out they dont fit!! thanks
#955
Car: 91 Camaro
Transmission: Automatic
Axle/Gears: 10 Bolt 3.73
Mmmm vette wheels on a 3rd gen just what I wanted to see.
I've been researching, I have a 91 vert... Looking to just get a clean set of wheels for the street. Found a set of c5z wheels 17x9.5 18x10.5 OEM wheels.
With spacers only would they clear without rubbing?
Tire size front is 295 rear is 315...
Yay? Nay? Before I make a purchase
#956
4th gen rear
Jay
4th gen rear
Jay
Really... I dont think theres any advantage to 17x9.5, you're gonna run a 275/40/17 on both of them. Just one has more unsprung weight and will stick out a little further from the fender. Yours look amazing.
I just realized I never put up a picture with ZR1's re plastidipped a different color. I thought the "anthracite" was way too dark so I decided to spray some pearlizer over it.
#960
#962
Car: 1989 Iroc
Engine: LS2
Transmission: GTO T-56
Axle/Gears: 4:th gen Auburn with 3:73
I used to have cheap z06 copies, but now I've got these c5 magnesium ones and I also upgraded my front brakes with some c6 ones. At first I thought the magnesium wheels were alot uglier than the c5 z06 ones I had, but after a few weeks I got used to these ones too and actually like them now.
#963
1 Post
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
91' bird 305 TBI T-5, trick flow 175 cc heads, 4.10 gears, lots of suspension upgrades......... 24mpg @ 2300rpm hwy 65mph ........ 8.63@ 85mph 1/8th on street tires... 8.000's soon
#965
Car: 1989 Iroc
Engine: LS2
Old wheels. Old brakes. But upside down.....
#967
Car: '90 Camaro
Engine: 305 tbi
Axle/Gears: 9 bolt posi 373
#968
Car: 1989 Pontiac Trans Am GTA
Engine: cammed LS1
Transmission: Monster SS 4L65E
Axle/Gears: 9 bolt posi w/ 3.70 gears
^^ I have two 2" adapters that would work for those. Shoot me a PM if you are interested.
#969
Car: I have an 88 IROCZ. Also an 87 IROC
Engine: none, but want LS2
Transmission: none, but want 6 spd.
Axle/Gears: 88-9" not complete, 87- 10 bolt
man that looks just like a car the guy next door to me had in high school. In Tara subdivision in Richmond, Tx.
#971
Car: 1987 Z28
http://www.ebay.com/usr/wheelgear?_t...10.m2749.l2754
Jay
#972
#974
Car: 91 Camaro Z-28 5.7 ( RED ALERT )
Engine: 5.7 TPI
I will like to use the same wheels and spacers....
The rear wheels are perfect is exactly this what i am looking for!!
plz can u tell me what full setup are u using??
Tires Size , Wheels and Wheels offset front and rear , Wheels adapters sizes...etc...
Tks
#976
Here's a set
OE Wheels C6 Z06
18x8.5 front, 1 in spacer, 13 in vette brakes
18x10.5 rear, 1.5 in spacer, stock third gen rear, drum to 4th gen f-body disc swap, minor forward inner fender clearance with a blunt instrument, lol
245/40/18 Sumitomo HTRZ III front
285/35/18 rear
Mike
OE Wheels C6 Z06
285/35/18 rear
Mike
#977
Engine: cammed LS1
Looks great Realmac4! ^^
Thanks Scuzo! Sorry, I haven't been on here in quite awhile.
Here's the information on the wheels and tires:
dished 18x8.5 fronts w/ 245/40zr18 tires and 1" non-hubcentric spacers
dished 18x10.5 rears w/ 285/35zr18 tires and 1.5" spacers
When I have to buy rear tires again I will switch over to 295's. The sidewall on the 285's lean a little toward the centerline of the tire instead of being vertical like it should be, IMO. And the 295 tire looks like it would fit just fine.
Also, I was glad I went with 18" rims on the front so that I didn't have any rim/tie rod end interference and I have plenty of room for a bigger brake upgrade in the future if I so desire.
I have Sportline springs all the way around, LS1 brakes up front & stock PBR brakes in the rear.
Here's some more information from my build thread along with a few pics:
Front 1" spacer installed
Luckily the wheels are dimpled between the mounting holes because the wheels studs are 1¼" long and extend past the spacer
Because of that the wheels mount-up with no problem.
There's more information towards the bottom of page 12 on my build thread in case you need more. The link is in my signature below.
Ur car are looking Amanzing!!!
Tks
Tks
#979
Car: 1988 Camaro IrocZ
Engine: Holley Stealth Ram 385 Stroker
Transmission: Redline Performance 700r4 Trans
Axle/Gears: Bulletproof 4thGen Ls1 SS Rear 3.73
C5 Z06 Chrome DeepDish. 265-40R17 front, 295-35R18 in back
#980
Just another set of C6 Z06 wheels and tires. Seen a lot of them on here but most are replicas. These are OEM. The wife wanted black wheels on her '07 Z06 so I got her a set of the '09 black spyder wheels. That means I got the originals that I just had to do something with. All it took was hours and hours of mini tubing along with narrowing a 4th gen rear about 3/4" each side. Perfect fit for 19x12s in the rear. The fronts just use a 1-1/4" spacer with C5 brakes that space them out another 5/16".
The car isn't done yet so I don't have much better pics. Doing a LSX swap this winter.
#983
Car: 91 G92 Z28
Axle/Gears: 342
I have a second hand cheapo replica set of these to put on a stock rear end. What width are your wheels? If they are the same as mine think I'll do the same tire size as you. Looks good!
#986
Car: 91 G92 Z28
Axle/Gears: 342
I talked to Founders and they sent me another LCA relocation bracket just to be sure that one was not damaged in shipping. The replacement bracket was not any better...which means the original rear end bracket was just off from the F body assembly line. I gave it another go with the pry bars with no success. I may have a hernia now. I plug welded the original hole in the rear end, ground it nice and flat then drilled a new one to line up with the Founders bracket. It's all back together now and my ride height seems to measure the same on both sides. I'm happy.
#988
Engine: cammed LS1
here are my wheels guys, 18x9.5 front and 18x10.5 rear with 2'' spacers all way around, love them!!
Attachment 287263
Attachment 287264
Attachment 287263
Attachment 287264
#989
1 Post
Car: 1991 firebird
Axle/Gears: 4.10
Only think I hate about spacers is how far the brakes are from the wheel ... just don't look right especially when u have nice brake setup
#990
Engine: 5.7 TPI
My 91 Z-28 5.7 ( RED ALERT ) with 67.000mil on it...
I have on a C4 Corvette Wheels set....
Front 8.5 wheels with 2.0 spacers and tires 245/45/r17
Rear 9.5 wheels with 1.5 spacers and tires 285/40/r17
Eibach Springs Set...Black ones on front and Red ones on rear and a Bilstein Shock Absorbers Set...
Tell me what you think because nobody uses C4 wheels on this cars...
In my opinion It looks "sweet" !!!
TKS.
TKS.
#991
Car: 1990 IROC Convertible
Engine: 5.7 TPI, L98 Heads w/roller rockers
TKS.
TKS.
#992
Car: 1989 Iroc
Engine: LS2
Looks dääm fine with those saw blades on it. And that paint job does ad a bit to the sweet look swell for sure :-)
I just got hold of another set of C5 magnesium wheels for mine, so now I run 4 rear 18x9,5" gold mags. It always fun to use unusual wheels
#993
Car: 91 Z28
Engine: 6.0L LQ9
Axle/Gears: Dana 44 3.92
+1 on the saw blades. that looks great. the older i get the more i like a "period correct" wheel and look.
#995
#996
I've got a few to add. I've always been a big fan of vette wheels.
My 91 right after I got the air ride system complete:
My convertible with C4 Grandsports just on there temporarily:
And my convertible now with the same wheels from my 91 but painted. I restored this car over the winter and using these wheels painted white was my idea of a somewhat period correct mod:
The following 2 users liked this post by IrocZ'85:
1986BANDIT (09-30-2019), TWON_3rdGEN (12-23-2019)
