Got Vette Wheels??...Post pics here...!
#701
Car: 82 camaro z28
Engine: gen 6 454 carburated and cammed
Transmission: ls1 t56 trans
Axle/Gears: currie f9 with 3.70 gears
Re: Got Vette Wheels??...Post pics here...!
nope a little bit of inner fender rolling and your set no rubbing what so ever.
#702
Car: 82 camaro z28
#703
Car: 1992 Camaro Z28
Engine: 5.7L TPI
Transmission: 5 speed
Axle/Gears: 3.47
Please help me!!!! I have a 4th gen rear but it seems that I still need spacers because the inner tire rubs against the body just a slight. Anyone with 4th gen rears still needed spacers? Also the studs are too short so anyone with 4gen rear and spacers how big of a spacer and how long of studs?
#704
1 Post
Car: 1991 Camaro Z28
Engine: 2002 SS LS1
Transmission: 6 speed
Axle/Gears: Auburn 3.42
What offset do you have? You could use a hammer to beat the inside down where its rubbing. I have an extreme offset at 79mm but I did a mini tub and offset lcas. If you need a spacer got to a rim shop and start with the smallest and work your way up. They are pretty cheap. If you go to big though you need adapters because you will run the risk of breaking the studs.
#705
Engine: 5.7L TPI
Axle/Gears: 3.47
#707
Car: 1990 firebird formula
Engine: 355 HSR comp xfi 268 vortec heads
Axle/Gears: 3.27 BW 9bolt
oh how i love vette wheels on third gens lol
#710
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: T-56 w/hurst short throw
Axle/Gears: unknown
#711
Car: 82 camaro z28
front i used a 2 inch spacer and the rear is a 4th gen rear so its 2 inch wider than stock.and a 1/4 inch spacer on both sides for the rear
#712
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: unknown
Thanks, I did a rough measure with my corvette wheels and I estimated a 2.5" spacer if I want a 9.5 inch wheel for the fronts.
#713
Car: 1988 Iroc-Z
Engine: 350 TPI; Stock internals
Transmission: 700r4; TCI-CPVB; BW Hi-Frition
Axle/Gears: 4th gen 7.5 w/ 3:42 gear
ZR1s
#714
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: unknown
Those ZR1s look good on your Camaro.
#715
Car: 1991 Camaro RS
The guy who painted it is doing a final buff this weekend, I plan on taking some better pictures when I get it back.
17x9.5 all around, kinda wish i went bigger
2" spacer in the back, 2.25" spacer in the front
lowered 1" on eibachs
#716
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: unknown
I need to hurry up and get my vette rims posted on here.
#718
Car: '91 RS, '64 C10 Stepside
Engine: 305 TBI, '00 5.3
Transmission: Manual, Automatic
Axle/Gears: 4th Gen with 3.42, 4.10
Finally got pictures of mine. 2 inch adapters up front and 2 1/4 inch in the rear. Still have some rubbing in the rear against the body. I'll get the hammer out and fix that though. Love the look and get comments often. If you're on the fence about doing this upgrade, just do it.
#720
Yes, I did... I put them on back in '91 and just never took them off. At the time, Chevy had nothing for me to put on. They had the 5.7 TUNED PORT INJECTION and just TUNED PORT INJECTION on the back of the Z-28's.
#721
Car: 1987 IROC-Z
Engine: 383 stroker, 1st F.I. TPI
Transmission: 700R-4. Modified to handle engine
Axle/Gears: 10 bolt 3.42 posi
What size tires are those?
#722
1 Post
Car: 88 t/a 92 rs camaro 88 firebird
Engine: 305 tbi in both
Transmission: auto camaro 5spd firebird th375
Axle/Gears: 3.73 minispool
im not sure if these were ever used on a vette i know they came on 91-91 rs z28 camaros but they have vette flags on the centercaps
#723
1 Post
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
2.25in rear? What is your backspacing. I run 18by10.5 with 305's and I have 1.5in spacer
#724
grampaben, I have 255/40-18 up front and 275/35-19 on the rear.
CamKid1992, I don't know what the backspacing is. I just researched and listened to what eveyone else has been doing. The lady I got the wheels from said they are off of a '05 Vette.
#725
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: unknown
Actually, the 5.0 badges aren't too bad at all. It is similar to having a 9" rear end. I'm on the fence about this upgrade, but it's just because I am running low on money (especially for the price of 19" tires).
#726
Homer23, thanks for the compliment.
It was tough to part with $832 for the tires. I paid $400 for the wheels, $130 for the adapters and can't remember what I paid for the mounting/balancing. I bought the tires from Discount Tire Direct and they had, and still have, an $80 rebate on the Hankook's. That helped lessen the "pain". There's a set of wheels just like mine on Craigslist here in Charleston for $325 OBO. I had Weld ProStars on her since '95.
#727
Car: 1988 iroc
Engine: 350 tpi
Transmission: t-5
Axle/Gears: stock
I'm about to join this club with these bad boys, they're going on a black 88 iroc with a 1.5" drop. Should look sweet!!! I'm super excited
#728
Car: 1988 iroc
Engine: 350 tpi
Transmission: t-5
Axle/Gears: stock
Also, after looking at all these sweet pics it makes me want to upgrade to some decent disks brakes all around. The stock brakes are especially ugly with these wheels.
#729
Car: 1987 trans am GTA ws6 package
Engine: tuned port injection 305 5.0
Transmission: t5 5speed manual
Axle/Gears: 3.08 i think
thats the nicest camaro i"ve seen!!!!!!!!!! nice ride
#730
Car: lots of Firebirds!
Engine: LS1s, 455
Transmission: t56s all around! lol
Got the same set waiting to go on my 89 GTA. You gonna leave em silver or paint them? I'm thinking about painting mine a dark gray, or flat black.
#731
Car: 1988 iroc
Engine: 350 tpi
Transmission: t-5
Axle/Gears: stock
I was literally thinking the same thing! I think for now I'm just Gunna leave them silver because they're still in such excellent shape. The PO had them plastidipped and when I peeled it off the rims looked brand new! I just wanna get them on for now and then I'll decide what to do as far as painting. I might even recoat them with plastidip because it preserved them so well. NJ winters are getting worse and worse lately. But I'll post pics if I make changes in color so you can see what it looks like. Good luck with the install though. Apparently some fender reshaping is in order. I went with 2" spacers up front and 2.25" in the rear. I'll let you know how it turns out. I'm also lowered 1.5" as well.
#732
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: unknown
#733
Engine: 5.7L TPI
Axle/Gears: 3.47
Pics suck. I need to take pics with a real camera instead of my phone. Best I can do for now.
#734
Car: 1987 IROC-Z
Just got them on 17"x9.5" 275/40 and 245'45. Fit well, no rubs, nothing sticks out!
#735
Car: 1988 iroc
Engine: 350 tpi
Transmission: t-5
Axle/Gears: stock
Got them mounted and balenced this week. Their 07 vette rims. Staggered 18" by 245's up front and 19" by 285's in the rear. 2 inch spacers up front that fit no problem. 2.25" spacers in the rear that required a lot of beating and some grinding to fit. The wheels are tucked up nicely in the wheel well though and with the 1.4" drop springs I think it looks great. Sacrificed some ride quality though. I'm looking to upgrade my struts and shocks next!
#737
#738
Car: 1987 IROC-Z
#739
Car: 1989 Iroc-Z Convertible
Engine: 6.0 LQ4 LSX
Axle/Gears: Moser 12 bolt w/4.11s
I'm planning on upgrading my wheels this winter. Going with C5 ZO6 17x9.5. Seems like the majority are running 2 or 2.25" spacers up front. Just curious where you are getting the spacers from. I saw Hawks has a set and also motorsport-tech.com. Any input would be helpful. Thanks!!
#740
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: unknown
Those are some nice rims. Ebay has some too.
#741
Car: 1987 IROC-Z
I got mine off e-bay. Here's a link to where I got mine.: http://www.ebay.com/itm/CHEVY-S10-CA...00260157497%26
I have abused them pretty well with no problems. Just make sure you follow all instructions to the letter on them.
WORD TO THE WISE: Have an extra $50 or so sitting around, as you will likely have to replace your wheel studs. (mine were too short to extend all the way through the nut and spacer). DO NOT run on studs that are too short. They WILL break. It's better to put studs that are too long, then cut them to the right length.
#742
Engine: 6.0 LQ4 LSX
Thanks for the info. I was wondering if anyone else had the Ebay adapters and how well they hold up. Makes sense to upgrade the studs too.
#743
Car: 1983 Camaro Z28
Engine: 355 Tuned Port with Vortec Heads
Transmission: T56 six speed
Axle/Gears: 373 10-bolt
Thanks. It's finally painted and back on the road with the LSx. Mine are the factory 18x8.5 front and 19x10 rear. I run a 2" spacer in the front along with a 275/35-18 BFG KDW2 tire. For the rear I've got a 4thgen LT1 rear axle so it's wider. I'm also using a 1" adapter along with rolled fenderlips. If you're running a stock thirdgen rear I'd try a 2.5" adapter in the rear and a 2" in the front and be willing to pick up another pair of adapters if that doesn sit how you like it. Oh yeah, rear tire size. I've got a 295/35-19 which is a little (I think an extra inch?) taller than factory heigh tires. I'm using sportline springs in front with a half coil cut and stock WS6 springs in the rear with 3/4 coil cut.
#744
Car: 84 Z28,03 GSXR1000,07 RMZ 250
Engine: H.O. L69
Transmission: 5spd
Axle/Gears: 3.73 possie
Hi iansane, I know this is an old post but I am trying to figure out why I need to add a spacer for my 19x10 rear vette wheel when I'm running a 4th gen rear? Most posts I have read say you don't or just a small spacer. I figure I will need to run a 1 1/8" or 1 1/4" to get good clearance from the inner wheel well even with a 4th gen rear. I'm not sure what year the car was that the rear came out of but it has a torsen diff. From what I've read torsen didn't go in till 99. I beleive 98-02 rears are smaller than 93-97 rears. What do you think? Should I only use a 1" spacer. I really don't want to modify my wheel well, I just don't have time for that. Thanks!
#745
Car: 1989 Pontiac Trans Am GTA
Engine: cammed LS1
Transmission: Monster SS 4L65E
Axle/Gears: 9 bolt posi w/ 3.70 gears
I need some opinions guys & gals. OE Wheels has two sets of rims on sale, so I figure now is my chance to finally get some 18" wheels for my car. The problem is I have been looking at this all day and can't figure out which I like more for my car.
First off, here's the link to their site in case any of you might be interested in some new rims. http://oewheelsllc.com/Wheels_3/Wheels-for-Camaro_4
Here's my car...
Here's the first wheel:
(18" Fits Camaro Corvette C6 Deep Dish Wheels - Gunmetal 18x10.5 / 18x8.5 SET) This set is about $40 cheaper... not that it makes a difference
Here's the second wheel:
(18" Fits Camaro Corvette C5 Deep Dish Wheels - Black 18x10.5 / 18x9.5 SET)
So, any input would be appreciated. By the way, the car is getting Tokico Illumina shocks & lowering springs.
Here's my car...
#746
1 Post
Car: 1992 Camaro
Transmission: t-5
305 35 18 rear nt555 extreme 2's in rear with 1.5" adapter. 275 45 17 front nt555 extreme 2's with 2.5" adapter.
#748
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: unknown
Or, if you race it, get both sets, one for your slicks/competition tires
#750
Im running 245/40/18's all the way around. Gotta get some widers for the rear, i know. and i need 2.5" spacers in the front instead of the 2" after i seen a little rubbing.
How it used to sit:
How it used to sit:
