Got Vette Wheels??...Post pics here...!
#552
Re: Got Vette Wheels??...Post pics here...!
I see everyone is running 2-3 inch spacers, has anyone had any failures running this big of spacers? Where do I get these spacers?
#553
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
1 Post
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
I'm running hawks spacers and 2.5in ebay spacers. They both are holding up great. If you torque them down as specified you should have no problems. And this is my daily driver.
#554
Spacers are NOT bolted on and are generally no more then
0.5". Any more then that would not be safe.
Many people come to this thread for information so it is very
important they get the proper information.
#555
1 Post
Car: 1992 Camaro
Transmission: t-5
Correct "adapters" everyone in this thread has been refering to spacers and I just followed along so there was no confusion. But when it comes to safety I should of been more specific.
#556
Car: 1992 B4C
Engine: L98 5.7 liter
Transmission: THM 700-R4
Back in the day (late 80's-early 90's) VBP was about the only provider of a hub-centric bolt on adapter. They were pricey compared to whats out there now.
They used a shank-style lug like weld wheels with the large caved washer to hold the adapter to the axle, and had a race style long stud (high tensile strength)pressed through the adapter to retain the wheel to the adapter.
Most of the modern (ebay) versions are imported knock offs of this original style. They use acorn style lugs and cheap wheel studs that I have seen several fail. They come in both a hub-centric and a non-hub centric design.
I'll post up picturs of both styles later
My personal preference however is to use the hubcentric version
No matter your personal choice, they key to using any of them is to always assure the proper torque values for the stud diameter and thread pitch.
#557
@HI85WH1
Excellent info
This should be stickied
http://www.skulte.com/adapterfaq.html
Am using Skulte 2" adapters up front & 4th gen rear end out back.
Excellent info
![](http://planetjupiter.com/transam/images/wheels-drop.jpg)
#558
Here's my thread(will update soon):
http://ls1tech.com/forums/conversion...rey-paint.html
#559
Car: 1984 Camaro Z28 Clone
Engine: Bored .030, vortec sbc350
Transmission: Built T5 WC
Axle/Gears: 1999 Torsen 4:10 Locker
2in spacers all around. The rear spacers will get removed when I get a chance to install my LS1 rear. (4th gen) I am running Sumitomo HTR III's 245/45/r17 on the front and 275/40/r18 on the back
It's a brilliant red from GM. I added some black and pearl in the paint to darken it up. It's a beautiful color. Prep'ing my rear bumper, hood and chin spoiler for repaint this week. Bumper didn't adhear correctly and the chin has some chips. The hood was damaged the other week in a shop who closed a tool under it...I was unhappy to say the least.
#560
Oh the tires in the pics where crappy continentals. I'll get some pics of the sumitomo's soon.
#561
Car: 1992 B4C
#562
1 Post
Car: 91 RS 305 TBI 5 Spd
Engine: 5.0 TBI
Transmission: 5 Spd
Axle/Gears: 323
I love the fact that this thread was started inb '09 and it is still going strong!
#563
1 Post
Car: 1992 Camaro Rs
Engine: 305 TBI
Transmission: 5Spd Pro 5.0 Shifter made shorter;)
Axle/Gears: Stock rear :(
Hey guys I just ordered a set of c6 zo6 chrome wheels 18x8.5 in the front and 19x10 in the rear stock everything what spacers would I need to get my setup going??? I'm lost with everyone saying yes n no they'll work. Thanks oh and I plan on dropping it later this year with some sportlines
#564
1 Post
Engine: 5.0 TBI
Transmission: 5 Spd
Axle/Gears: 323
I use 2" on both front and back but mine are only 18". For the rear you will need to go with 2.5. Do you have a stock 3rd gen rear or 4th gen rear? If you have a 3rd gen then you will need spacers in the rear. If its a 4th gen then no spacers.
#565
1 Post
Car: 1992 Camaro Rs
Engine: 305 TBI
Yeah it's a stock third gen and I should use a 2 in the front and 2.5 in the rear? And would this be affected if I drop it on sportlines? Thanks again
#566
1 Post
Engine: 5.0 TBI
Transmission: 5 Spd
Axle/Gears: 323
Yes 2" infront and 2.5 rear then. And it might effect it if you do the sportlines if you go too low.
#567
1 Post
Engine: 5.0 TBI
Transmission: 5 Spd
Axle/Gears: 323
Just saw that you are in Laredo, I spent 9 yrs in Harlingen before moving to WI. Man I miss TX
#568
1 Post
Car: 1992 Camaro Rs
Engine: 305 TBI
Okay what drop would u recommend for my baby lol and that's cool I got family in la feria n McAllen basically all over Texas haha n Texas is the bomb for everything I lived in houtson for a while n way diff from Laredo n the valley.
#569
Car: 01 Z28 and 89 Iroc
Engine: ls1 fti 3600,S60 w/3:73 gears
Transmission: A4
Axle/Gears: 3:23
Best wheel thread ever. I've been drooling. I am definitely taking my C5 wheels off my 01 z and putting them on my Iroc once it's running.
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
#570
Car: 1990 firebird formula
Engine: 355 HSR comp xfi 268 vortec heads
Axle/Gears: 3.27 BW 9bolt
heres mine. just got them mounted up
#571
CLEAN Mike. CLEAN. Liking it!
#572
Car: 1989 Pontiac Trans Am GTA
Engine: cammed LS1
Transmission: Monster SS 4L65E
Axle/Gears: 9 bolt posi w/ 3.70 gears
Yeah, that does look good Mike. Those wheels look good on 'birds. Wish they made them in deep dish.
#573
Thanks that's the only thing I don't like is there not deep dish but other then that I'm very satisfied I should have some better pics up with in the next few weeks
#574
Engine: cammed LS1
What size spacers/adapters did you need?
#577
is anyone running the coil-over conversion with the vette wheels? i was looking into spohn, umi, etc, but i read on here that you can't use those with wide tires. i have Z06 replicas 18*9.5.
just wanted to make sure before i spend the money and they dont fit
#578
1 Post
Car: 89 Firebird Formula
Engine: 3500T
Axle/Gears: 9 bolt/4.11
I have Z06 17x9.5 all around and they clear the coil over conversion by about 1/4". I would think there would be slightly more room with 18s. I'm using 2" spacers.
#579
1 Post
Car: 82 Trans Am
Engine: 13:1 383 stroker on e85
Transmission: t-56
Axle/Gears: ford 9" locker 3.70
19"x11 c6 black wheels out back, and 19x9 (had a second set of the 19x11's chopped) on the front.
tires are 255/35/19 and 305/30/19
![](http://i55.photobucket.com/albums/g122/jwdominick/IMAG0133-1.jpg)
![](http://i55.photobucket.com/albums/g122/jwdominick/IMAG0135-2.jpg)
TWON_3rdGEN (12-23-2019)
#582
Car: 84 Z28 / 11 genesis coupe
Engine: 355/210 heads/275deh/Proform 750 DP
Transmission: 700r4/B&M 2400
Axle/Gears: 02, allu.axle, 3.42, posi
i have had mine for a while i don't even remember if i posted a pic already but if not here it is
#585
Engine: cammed LS1
#586
Engine: cammed LS1
I'm going to go with one of these wheels on my car. 18x8.5 fronts & 18x10.5 rears. That way I can put the Corvette or CTS-V big brake kit on the front.
![Got Vette Wheels??...Post pics here...!-c5-18-g-dd](https://www.thirdgen.org/forums/attachments/wheels-tires/234559d1482196899t-got-vette-wheels-post-c5-18-g-dd)
C5 deep dish
![Got Vette Wheels??...Post pics here...!-c6-g-rt-r](https://www.thirdgen.org/forums/attachments/wheels-tires/234560d1482196899t-got-vette-wheels-post-c6-g-rt-r)
C6 deep dish
![Got Vette Wheels??...Post pics here...!-z07gunmetal.jpg](https://www.thirdgen.org/forums/attachments/wheels-tires/234561d1482196899t-got-vette-wheels-post-z07gunmetal.jpg)
C6 Z06
Man, all this talk about deep dish is making me hungry for pizza!
As of right now I'm leaning towards the Z06 wheels, but the other two would be easier to clean. That's one of the reasons why the crosslace GTA wheels are going bye bye. They are such a pain in the **** to clean! Bigger brakes is the other reason of course. What do you guys think?
C5 deep dish
C6 deep dish
C6 Z06
![lol](https://www.thirdgen.org/forums/images/smilies/lol.gif)
#588
Here's a picture of my car with the GTA rims:
Attachment 234562
And here's a picture of a 4th gen that I found with the Z06 wheels on it:
Attachment 234563
I think the gunmetal centers will look good on my car. If not, I can always paint them silver.
Attachment 234562
Attachment 234563
![driving](https://www.thirdgen.org/forums/images/smilies/driving.gif)
#592
1 Post
Car: 84 Z28 HO
18x8.5 +56mm offset & 19x10 +79 mm
No rubbing so far but hadn't driven it much just put them on but ill let you know if I have any issues
#593
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
They look good what tire sizes are yOu runnin?
#598
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
I got all stock c6 wheels ima buy the spacers tomorrow ill find out soon if they work
#599
Car: 1992 Camaro RS
Transmission: auto
Axle/Gears: unknown
I have been waiting to post on here for a while! I got my c6's on and im working on uploading the pic. totally changed the car
#600
New Pic from last weeks Bham Meet.
![](https://www.thirdgen.org/forums/attachments/wheels-tires/236321d1331590520-got-vette-wheels-post-img_0283.jpg)
