Got Vette Wheels??...Post pics here...!
#451
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Re: Got Vette Wheels??...Post pics here...!
I l'm running C5 Y2K's right now. 17x8.5, 18x9.5. Falken FK452's 245/45/17 and 275/40/18. I have 2" adapters all around.
I'm not to pleased with how they sit, I'm not a fan of the "battleship" look. So I'm thinking about running 3" adapters up front and 2.25" adapters in the rear to get them to sit flush.
#452
1 Post
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
Huh... Are you sure?
Mine aren't on the car right now and I just measured them (and double checked the recept), my spacers are definitly 2" and my wheels are front 17x9.5 with a +54mm offset and rear 18x10.5 with a +58mm offset. That should put your wheels farther in and it definitly looks like yours stick out and mine are significantly further in, like at least 1/2-3/4"
Something is not adding up. Do you have a 4th gen rear?
My mistake- I am running 18 x 10.5 +58mm offset with 2in spacer and 305 35zr18 and 17 x 9.5 +56mm offset with 2.5in spacer with 275 45zr17.
Sorry for the confusion
#453
Car: 1987 Camaro Z28
Engine: 5.0 TPI
DBLTKE, i just bought same set but dif size: 17 x 8.5 all of them, they are aftermarket replicas...
do you think i could go 2" spacers all the way? or you think i could go another direction? what do you recommend?
#455
updated with 1.6'' drop in front and 1'' rear,
2.25'' spacers all around
#457
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
Here's a couple of mine
#459
So should I NOT run Sportlines with an LT1 up front?
1. 265/40/18 upfront. I was running 275/35/18 but my headers hang too low so I had to go a little taller. These are perfect.
2. I'm running the Sportlines, however my car weighs around 3400 because the LS1(about 150 lbs less than stock).
3. Color is Cyber Grey Metallic, I fell in love with it when the ZR1 came out. I'll get some better pictures with a SLR camera soon.
#462
1 Post
Car: 1992 Camaro RS
Engine: L98 5.7 350
I forgot to post mine in here LOL.. 17x9.5" +54 c5 Z06 wheels.
2.25" adapters up front, 2" in the rear.
#465
Car: 84 Z28
Transmission: auto
Are you guys with the C6 wheels running factory "take offs" or replica wheels?
#470
Car: CAMARO,GMC SUBURBAN DUALLY,RACEBOA
Engine: 305 TBI( soon 383),350Vortec
Transmission: 700 turbo
#472
mine are factory rims
#473
I would also sell the complete Camaro if anybody is interested.
C6 wheels, rear disc brakes ( 3:56 rear 9 bolt ), all white ( NEW PAINT ), T tops, black leather, COLD AC, 5.0 ( 305 ) chevy.. good on milage, 2 inches lower, KYB II shocks, aluminum driveshaft ! and on and on !
thinking $ 3800 OBO
oh, year 1988 coupe with extras... not many out there like this one !
thinking $ 3800 OBO
#475
#476
1 Post
Car: Iroc
Engine: 350 4-bolt
Transmission: T5 non-W/C
Axle/Gears: 3.27 Open
17x9 275/40/17 HTR Z3s
BUT THENNNN!!!!
I loved them so much I had to put them on my Daily Driver!!! 245/40/17s HTR Z3s
#478
Car: 1979 Camaro
Engine: 305 5.0 Tpi
C6 Vette Wheels 18x10.5 rear and 17x8.5 front
#479
Car: 1990 RS
Transmission: Built-700R4
#484
just got these today
[IMG][/IMG]
18x9.5 and 18x11, now need to buy tires......
[IMG][/IMG]
#485
Car: 1992 Camaro z28
Engine: 350 HSR
Axle/Gears: 3.42's
What are those? they look like Z06's that i have yet different. Either way though there gonna look killer!
#486
they are ACE Slick in hyper black. Some call them Z07's. i had been wanting to get C6 Z06's but i never able to figure out which to go with (color/ size/ etc) when i saw these on SLP i fell in love! i got the on ebay for a great deal!!
#487
#488
GTA running C6s. Standard 18/19s with 255s up front and 295s on rear. LS1 Brakes on front. 1 coil cut off of front and 1 1/2 coils off of rears. Moog springs. No isolators
Rear could do with another half coil and perhaps a slightly thicker tyre wall
Pics at my local sikh temple - enjoy!
#490
1 Post
Car: 1991 Camaro Z28
Engine: 2002 SS LS1
Transmission: 6 speed
Axle/Gears: Auburn 3.42
325/30/19 19x11 79mm offset rear 2002 axle/20mm spacers and 275/30/19
19x9.5 front 57mm offset with 2 inch spacers
#493
1 Post
Engine: 2002 SS LS1
havent really broke them in, just did the install using Kore3 settup. 1/4 pedal still feels night and day compared to the 10.2 inch stock 2 piston Z28 brakes.
#494
here are a few phone pics of my new set up. ill take some better pics in the daytime.
18x9.5 275/35 18 18x11 305/35 MT drag radials. might need to go to a 1.75 adapter to tuck the rear in a bit more.
#495
Car: 1991 Camaro RS
Axle/Gears: Stock
#496
Car: 87' Iroc Z
Engine: TPI 350
Axle/Gears: Borg Warner 9 bolt and 3.27's
Need some help. I am very picky on how I want my setup to come out.
Ok so I have a question or two. I have read this entire thread from page 1.
I have decided I want to go with these wheels.
And once I lower the car I want this exact stance. With the rear being about a half inch or so lower(want the ground fx to be perfectly parallel to the ground).
I'm wanting to go with 18X9.5's all the way around.
Now my problem is I'm gonna stay with the third gen rear end and I know I need spacers/adapters. I want the edge of the wheels to stick out just barely past the side of the fenders, but not past the fender flares(so basically right in the middle of the extended part).
I have read some are going with 2" all the way around and some are using 2" in the front and 1.5" in the rear.
Does anyone know exactly what size I would need to achieve my goal or is this something I'm going to have to mock up and measure for the precise size?
Also when I lower it what type of setup should I go with. Car is just gonna be used as an everyday get around car/cruiser.
TWON_3rdGEN (12-23-2019)
#498
1 Post
Car: 1992 Camaro
Transmission: t-5
Hope you have those fenders rolled. Mine like to eat tires!
#499
1 Post
Car: 1992 Camaro
Transmission: t-5
