Max 18 inch Tire.
Car: 83 Z28 Camaro
Engine: 5.3L L33
Transmission: Manumatic TH 350
Axle/Gears: GM 12 bolt 3.73
Max 18 inch Tire.
I have a 83 Z28 with no fenter well mods. I have used the seach funcion with not much luck. The rims that I have are off of a fourth gen camaro with a 6 in backspacing and are 9 in wide. Please help with the front and rear tire selecton. I want to put on Nitto NT05 tires on all four corners. Thanks for any help that you can give me.
Car: 87 GTA
Re: Max 18 inch Tire.
To put wheels specd for a 4th gen, on a 3rd gen, Skulte 2" ones-link are the most common choice.
Personally, I'd suggest buying wheels that FIT & do not require adapter spacers to make them fit.
Combine the price of the wheels and the price of the adapters & see if you can find direct fit wheels for about the same price, that you like.
Car: 83 Z28 Camaro
Engine: 5.3L L33
I am set on the rims that I have. I could still use some help on the on finding the lagest tire to fit on the front and back of my car.
i would stay between 255-275/ 40 any less sidewall and the car will skid accross road imperfections. you could also run a 35 series tire but it would ride horrible and look out of place
i currently have 18 X 9.5" wheels, 265 40 18 on the front and 275 40 18 on the rear, the car sits at about 26- 26.25" all the way around no rubbing, no wheel well gap
Car: 1987 Chevrolet Camaro Z28 IROCZ
Engine: L98 350, mini ramed and camed
Transmission: T56 6 speed manual
Axle/Gears: 10 bolt 3:73 limited slip
I had 295/35/18 on all 4 corners with 18x10.5 tt2 rims on my stock 89 Camaro vert. Only had a slight rub when I turned the front wheel all the way to lock. Adam :-)
LT1Formula
10-08-2015 09:34 PM
