C5 Rims
Car: 1983 camaro
Engine: 350 soon to be 355
C5 Rims
my friends has a 98 vette and swapped over to Z06 rims and said i could get his c5s cheap. from looking at othe rposts i only need a 2 in spacer and this can work. I would just like confirmation befor i go and spend the money. 17in frnt and 18 rears if you need the tire size i can get that aswell.
Car: 1988 IROC-Z
Engine: 355ci SBC, Holley carb
Transmission: 5 speed manual
Axle/Gears: 4th gen Z28
Re: C5 Rims
From what i have read, you'll need spacers front and rear. Are these the thin spokes? I'm running the Z06 size 17/18's with 275/40/17 fronts and 295/35/18 rears. I just picked up a 4th gen rear end, so i won't need spacers in the back, 2" up front.
I believe the stock size tires on the rims you're talking about will be 245/40/17 and 275/35/18.
Car: 1983 camaro
Re: C5 Rims
i just wanted to make sure befor i invested in some spacers. back looked like it might need a little more then 2in but thats just eyeing it up
Car: 1988 IROC-Z
Re: C5 Rims
Buy 1 pair of 2" spacers and see how it works for the fitment at both front and rear. If it works at both ends, order up another pair. That was my plan...until i bought a 4th gen rear. Now i don't need spacers in the rear and can use the 1 set i bought on the fronts.
Car: 1983 camaro
Re: C5 Rims
well the tires on the rims are 245/45/17 and 275/40/18 so i hope everything works. i dont want to buy new tires right now.
Car: 82 Trans Am
Engine: 355
Transmission: t5
Axle/Gears: 373
Re: C5 Rims
If they are the wagon wheels they will bolt right on with 2 inch spacers front and rear this is with 245's in the front and 275's in the back, at least it did for my 82 firebird. I have rear drums though so I dont know if rear discs will be any different.
Car: 1988 IROC-Z
Re: C5 Rims
Thin spokes or wagon wheels, you should be OK with those tire sizes and the spacers. I know i need to modify my bump stop bracket on mine...a little too close for comfort to the 295 Michelin's.
Car: 1983 camaro
Re: C5 Rims
that sucks because i ordered 2 sets of 2 in as i was eyeing it up though i thought it might have been closer to 2.5 in but i guess time will tell. anyhow im sure i can sell a set of new 2in spacers quick. or maybe they place i bought them from will let me exchange them.
Re: C5 Rims
You should be good with the 2" front and back just like the C6 wheels. Later.
Car: 1983 camaro
Re: C5 Rims
they look good all around except i think it might be a little to close on the bumpstop. im not sure but i might have to beat the fwheel well a little bit, i would just rather be careful then have somethign bad happen.
LiquidBlue
Wheels and Tires
32
12-10-2019 04:06 PM
