11" Rear Wheel Fit
Car: 87 GTA
11" Rear Wheel Fit
Ok.....I know that this has been covered many times, but it always end the same way...."Use a BFH.".....Not exactly overly helpful.
I'm ready to do it, but I'm really not seeing how a simple BFH is gonna help me, despite what I've been told.
My goal is to fit 315s.
I currently have 17" x 9" ROH Snypers, 5" bs/0 offset. To fir 315s, I need a 10"-12" wheel. Goal was 11" then. I was going to add 2" & end up with 6" bs.
I mounted up a tireless wheel & after a bit of SFH (my bigest H is just a SFH ), I had this....
It looks like I'm still 1/2" short of room & that would be with the wheel physically TOUCHING the car. Not even any clearance. No way a simple BFH is gonna move the metal 1/2" in!
Am I measuring wrong? Am I misinterpreting what I'm seeing?
I finally have the $ I need, go to check it all out & now.........HELP!
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: 11" Rear Wheel Fit
is the axle at ride height or is it hanging in the pic?
people usually have the bump stop area sitting inside the wheel, and say "oh, it fits great!" but let the axle drop and it hangs up on the bumpstop, like it would in your pic
You need to cut the bumpstop area off. There are 2 main layers of sheet metal there, you need to remove the outed layer, then box it back in so that its flat instead of sticking out into the wheel.
the BFH or SFM is more for the front of the wheel well.
Your figuring the 315 to be 12.5" in width right?
Car: 87 GTA
Here's another part of the mystery.....
The light streak is the e-brake shield reflecting the flash of the camera......Only 1.5" from the rim edge to the e-brake cable.....2" widening would me the wheel 1/2" into it!
Car: 87 GTA
I pretty much figured on the bumpstop needed to be cut anyways, but I haven't gotten to that part yet, and already having fitment problems!
I'm trying to move/clear than inner stiffening "ridge".
so move the cable? is hsould move out of the way.
my panhard mount is inside my wheel....
do you have rear drums or discs?
Car: 87 GTA
Please......Lets address one problem at a time, before we worry about the others.......Wheel fitment.
That end of the cable won't simply move, that close to the caliper. It is STIFF metal sheathing and just barely out of the caliper, before it starts turning.
as for the cable, i forgot the old factory ones are quite stiff.
I have have the 4th gen cables for my ls1 style rear brakes, while they are pretty stiff too, i was able to flex it enough to clear the wheel, i dont have the original cables to compare with.
Aside from that, the cable should be able to move enough to clear the wheel, i wouldn't worry too much about the cable at this time.
this thread has the pics for the bempstop area cutting, you've posted in it, but here it is if you need it
https://www.thirdgen.org/forums/susp...od-17x11s.html
Car: 87 GTA
OK.....I *THINK* I have 1/8" clearance now. Not that I'll settle for just 1/8" (I want 1/4"), but at least it is some progress! The bright streak is the metal e-brake cable & camera flash off it.
Maybe MORE hammering to the ridge will give me to room I want. All I have to work with is a roofing hammer...... Or a deadblow rubber mallet.
I do have a 700R4, & have NO plans to go T56, so do I NEED a e-brake? Not really. So no BIG loss if I disconnect it & lose it. Not sure if they even check it at inspection time. I'll look into that.
Now......If I put in a 4th gen rear axle, all my problems would be solved, but new "problems" would arise. My tires sit in about 1/2" right now, which means they'd be about 1" OUT, past the fender.
Car: 87 GTA
I would shoot for 1/2" clearnance minumum. Thats what i need or my tires will rub occasionally.
I didnt mean remove the cables, not sure if you were thinking i meant that.
Sounds like you need to invest is a bigger hammer
looks like your getting somewhere.
Car: 87 GTA
I moved the jackstand from the axle to the body & let the axle drop.
Yep.....EXACTLY 1", rim edge to the bumpstop and the wheel drooped below the bumpstop, so it'll interfere & will need cutting off.
I beat in the upper wheel well some, but can only guess at how much I'll need for the tire sidewall bulge, until I actually have a tire mounted on the wheel to see it.
From the rim edge to the stock LCA is EXACTLY 2" (which is what I'm gettung them widened by), so that is an issue, right? NOPE!
I already anticipated that problem & got a set of UMI Performance Tubular LCAs w/spherical Rod Ends & Offset Bushings, so I'm good there.
Cut out and box the bump stop area, that alone will get you 3/4" at least. I am running a 13.1" section width tire with a 15x10 on 6.5bs rim. It all fits fine, I posted a thread with pics a long time ago, feel free to search for it. I think it was 15x10 with 6.5bs in the title.
Car: 87 GTA
I have a UMI Performance Double Adjustable Rod Ended Panhard Bar so I doubt I have ANY side-to-side deflection.
Car: 87 GTA
OK.....Everything is looking like it can be pretty easily "fixed", EXCEPT.....the e-brake cable problem.
The rim would just touch it at 1" more bs, so 2" would be a BIG problem. And it isn't very flexible at all so.......
Any ideas?
I can't eliminate the e-brake cable. It can't be easily just twisted to the side & make room for the rim so.....
Any ideas?
What PHB do you have? Poly Bushings?
The rear of the car will still move a little side to side, but i think my rubbing is happening when the suspension is loaded in a turn, the body rolls a little and causes a rub.
Car: 87 GTA
No "easy" fit exists, if you wanna keep the tires under the fenders. Otherwise, I'd just get some spacers & stick them out. As it is, I'm gonna use my brand-new, used, OEM aluminum factory aluminum drum spacers. Which are just under 1/4", IIRC..
Well, I did discover that the e-brake cable ran through that flimsy "bracket" on top of the axle tube & was actually being held "out" & it could possibly move in more. After releasing it from the bracket, it swung inwards a little more, and that gave me the room for the wheel to clear the cable. I'll make a new bracket to hold it in farther.
After recalculating, I was gonna end up with 7"bs........A 17" x 11" & 7" bs, with ONLY some BFH work......NOT POSSIBLE! (Some CLAIM 6.5" bs to have done just a BFH, yet no pics from them......not surprised at pics showing off their lies)
I challenge those who say it is possible & have done it (6.5"bs), to pop a wheel off their car, take a pic, show the wheel bs & PROVE IT! I've been researching this for over 6 months now, & of those who "claimed" to have done it? They are obviously full of it & leaving something out, that they don't want to admit to.
It is obviously going to require some cutting & re-welding, to even fit 6.5" (much less 7")bs.
5"bs? Yes, direct fit.....
5.5"bs + BFH?.....Yes, but not just simple MINOR BFH work
6" bs + BFH only? (like some claim to have done).....NOT IN YOUR DREAMS! (much less the 7"BS I was going to end up with)
I can get 2" of clearance (9" wide/5"bs wheel), wheel edge to body metal, but NO MORE, with only BFH work. Meaning the (widened) rim would be TOUCHING the body metal. Then there would be the tire bulge on top of that! And that doesn't even take the bumpstop section into account that sticks out even further.....
It looks like I'm going to end up with a 1.5" widened, 10.5" (10"-12" is the recommended size)/6.5" bs wheel, if not just a 1" widened 10"/6" bs wheel.
https://www.thirdgen.org/forums/orga...28x12-50s.html
just in case u need to see the pics at the bottom of the thread
screw it....here u go
Car: 87 GTA
i made a huge thread on the drag board or fabrication board about MY 6.5" backspacing....sorry you can't believe me. 28x12.50 slick with 13.1" section width, cut out the bumpstop run offset LCAs and it's not too difficult to fit.
#2....NO inner fender pics. So we can't tell from the outside if it just messed with or back-halfed & tubbed.
#3...Only 15" wheels. I have 17" & the problem the wheel to metal problem.
Not surprised that, as usual, no wheels off pics of the inner sheet metal.
Last edited by Stephen; 04-27-2009 at 11:30 PM. Reason: Misread & responded to the misreading
Car: 87 GTA
Your pics only reinforce my point.....
You cut & welded exactly what I expected to see. Not "just BFH" like some claim.
Tire sidewalls end up in a totally different area than rims do, so the argument of rim vs tire width is pointless.
The area tires would rub, is way thinner, easier to move and wider to begin with, than where a rim "intrudes" upon. Yes, the sidewall & bumpstop area still might present an obstruction, but that is another issue to be dealt with later & easily addressed with limiting straps, if nothing else.
Car: projects.......
17x11, 4th gen rear, 8" bs, 315/35/17:
rolled the fender lip, trimmed the corners of the bump stop/mounts, and tapped the spring hump slightly with a BFH.
There is a drivers' side straight-on rear shot of it that has been posted up on here for a few years now. You should be able to find it in one of the wheels threads by searching my name and the word pics.
Car: 87 GTA
I have 5" bs right now...There is physically 2.125" from the rim edge to the body metal & that doesn't even include the bumpstop sticking out.
You'd have had to cut a full 2" out, or have the rims sticking out. Pics like that show nothing. Lets see it without the wheel in place.
What sized adapters did you use? 8"bs on a direct fit wheel, without serious cutting & welding, is not even remotely possible.
Car: 87 GTA
If I had a 4th gen rear end, I'd have minimal inner clearance problems, but then my tires would stick out about 1.5"!
As 86TA noted, I run an 8" bs due to the 4th gen rear that is currently under it.
For note, the only reason I trimed the corners off the bump stops and thier mounts was for clearance when the suspension is fully extended.
If you add 2" to a 4.5" backspaced wheel, then you will have a 6.5" backspace, thus making the roughly 1/2" difference we have in fitment. - Basically, my wheels stick out approximately 1/2" more than your's currently do. I don't have any pics with the wheels off, however there are some rear shots on this board that show where mine sit in relation to the fender lip, which would probably verify this. - I would re-post them, but I don't have those shots on my photobucket account and I don't often get on-line from home.
Car: 87 GTA
Passenger side was much quicker, since I already learned what was going to be a waste of time, doing the drivers side.
The bumpstop is now gone, just need to address that center "ridge/bump".
Guest
Posts: n/a
The problem originates from your insistence that your backspacing is 4.5" and that the number is going to be the same on every other wheel out there. I was going to reply last week, but things came up and I had to leave so all the bookmarks I looked up are not here. In any case, feel free to look up any of the following manufacturers and how THEY measure backspace:
American Racing
Bonspeed
Boyd
Budnik
Centerline
Cragar
Weld
Wheel Vintiques
US Wheel
I may have forgotten some and some dont say, not to mention I did not look up everyone, but I'm sure a phone call would resolve the question. So what you're doing is wrong, telling people that have already done this that what they did is not possible, and calling them out and whatnot. Stop.
You are not using a backspace dimension that is equivalent to what everyone else uses. Its about a 1/2" different, because everyone else measures from the mounting flange to the back of the rim, not to the bead like you insist. So forgetting what you say yours are, start with EQUIVALENT measurements. If you consider that measuring your rims backspace the way that any of the above do, and what those vehicle owners are telling you they are running on their cars, it might make some more sense. You're talking about adding 2" to a wheel that is not 4.5" backspace but 5" backspace measured in the manner everyone else on this board was told to measure and how the manufacturers they got their wheels from measured it, putting you at 7" backspace the way everyone else measures theirs. Now maybe it will make sense to you how a bunch of people are running 6 to 6.5" with a BFH and you cant, its because you are trying to run 7".
American Racing
Bonspeed
Boyd
Budnik
Centerline
Cragar
Weld
Wheel Vintiques
US Wheel
1 Post
Car: 1990
Axle/Gears: stock
i love your car. when mine grows up i want it to be like that.
Car: 87 GTA
......YOU, not fully reading before you Post!
I already posted that I made the MISTAKE of calling the bs wrong in the beginning.
Try READING a whole thread before you mouth off!
I fully understand, and already posted about it. And I AM using edge to wheel seat measurements. And yes.....I WAS using one that is equal.....
I don't seem to have any shot with of the wheel wells with the tire's off. Like I said though, less BFH work than you, but approximately 1/2" less backspace.
Here's a rear shot of the car, should help to show fitment vs the lip:
Car: 87 GTA
Yeah...we could play with the #s all day long, but no one can ever make up their minds if a 4th gen rear is 2", 1.75", or 1.5" wider per side, so we can't trust their judgment in what they say about cutting/hammering etc.
I gave up & just cut mine out yesterday, so it doesn't matter anymore. My bumpstops & the vertical bump are GONE now.
Guest
Posts: n/a
But you have a 4th gen rear, so your fit is pointless to me, since I'm still using the 9-bolt, since it is stronger than the 10-bolt rears.
I do understand what you are saying, just noting that since the 4th gen rear is almost 2" per side wider, I am running 2" more bs than what you would need. That said, the difference in fitment was due to how you were measuring it; thus the 1/2"difference in clearance.
Sorry to have tried to help. I'll leave you to your own choices.
1 Post
Car: 1991 camaro vert
Engine: ls1 soon
Transmission: t56 soon
Axle/Gears: moser 12bolt 4.10 soon!
love the wood behind the wheel... 1in wood block vs. 3000lbs car lol this transam vert also has camaro vert side spoilers.. nice car tho sorry its off topic
1 Post
Car: 84 TA,69 camaro,81 vet 92 vet
Engine: 400
Axle/Gears: 3:73
I just got mine on yesterday, 17 front 18 back. 285- 40-18 rear tire. Stock rear w/ 2 inch adapters. I have 2.25" of space from the tire wall.
1 Post
Car: 82 Camaro
Engine: 327/30 over 1965 block
Transmission: 4 speed M22 trany
Axle/Gears: 373
Man need I help with getting wider tires under my 82 camaro.. man can you email me specs pics rim size back pacing and tires size... if you can... man the car spins all most, all the way down the strack the way it is now...
1 Post
Car: 82 Camaro
Axle/Gears: 373
I was told that you can fit, 28 x 11.50 tires with a rim of 15 x 10 back spicing 5.1/2
is this right.
is this right.
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
kah992
08-19-2015 02:55 PM
