z06 rims
Car: 1991 CAMARO RS
Engine: 5.0L 305 TBI
z06 rims
Hi everyone,
Well i found these ZO6 rims on ebay and i dont think they fit in our 3rd gens is there any way to make em fit.
Also it says they got some blemishes wat is that????
And some minor dings will that affect how the ride moves or anything like that.
Plz help me out guys
I would really like these nice rims on my 3rd gen.
Edgar
Oh this is the link hahaha
http://cgi.ebay.com/ebaymotors/Corve...spagenameZWDVW
Edgar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: strange s60 4th gen width - 3.73
Re: z06 rims
to make them fit... adapter/spacers. heres some... http://hawksthirdgenparts.com/index....ROD&ProdID=491
and blemishes are pointed out. there don't apprear to be any on the actual outside of the wheen just on the inner lip.
Car: '90 Camaro RS, C5 Z06 wheels
Re: z06 rims
I have the 17" x 9.5" of these rims on my camaro. I bargain hunted on ebay for my wheel space and spent about $160.
You need 2.25" wheel spacer up front to clear the steering componets.
You can use either 2.25" or 2" spacers in the rear.
I bought four 2" wheel spacers.
Then I bought a pair of .25" slip on spacers.
I did not want 2.25" spacer up front because if I did the c5 vette brake upgrade upfront the new rotor adds the .25" and I would only need a 2" spacer then. I use the 2" spacers with the .25" slip on spacer behind it for now until I do the c5 upgrade. One more note you will have to press in longer lug studs up front for the 2"+.25" combo or the 2"+c5 vette brake(.25") combo. I bought my longer lug studs at o'reilly auto parts.
The 2" wheel spacer is just fine on the rear. The ones I bought had to have the hole in the middle opened up a little with a engine hone so it would slide over the end of the axle.
Car: 1989 Pontiac Firebird
Engine: Multiport 2.8L V6
Transmission: 700r4 with Shiftkit
Axle/Gears: All Stock
Re: z06 rims
I asked a Question like this, But I want to Fit C6 Z06 rims on my 3rd gen, now is that possible?
18 rear 17 front, is it Possible?
Re: z06 rims
What about doing a
front tires 275/35ZR18
with
rear tires 325/30ZR19
knowing the rear are wide tires would that be possible?
plus I want to lower the car a bit. so it don't look to high off the ground.
with
1 Post
Car: 89 IROC
Engine: 5.7L
Axle/Gears: 3.70
Re: z06 rims
With that tire on the back you might have to "clearance" the inner fender wall and possibly roll the lip on the back fender. I think that would be a real nice combo though.
Re: z06 rims
The best place to get spacers for those wheels are off ebay. I got a set of 4 for under $150 shipped. I had to get 2" spacers for my 2002 SS wheels to bolt up. Just run a search on ebay for camaro spacers and they pop right up.
Re: z06 rims
Just as TMZIrocZ350 vbmenu_register("postmenu_3854993", true); said you will have to clearance the innner wheel wells and roll the fender lip. You have to do that to any tire 315 or bigger.
Car: 1991 CAMARO RS
Re: z06 rims
I appreciated alot
one more question though about the spacers will they affect how the maro handles like will it feel weird or anything like that
Re: z06 rims
The handling is better than the stock wheels.
With the lower profile than stock tires you will feel the bumps a little more but you will get this with any low profile tire. (The taller sidewall tire dampens bumps in the road like a shock absorber but mess up handling when cornering.)
The spacers don't affect these aspect at all. All the spacers do is give you the correct back spacing. With my front end being .5" wider than rear I do not have any weird handling problems. With the wheel spacers I'm using my wheels are still tucked up under the fenders.
Car: 1991 CAMARO RS
Re: z06 rims
Which brand did u get ur spacers and how much did u spend for all four
Thanx
For all ur advice
Re: z06 rims
Yeah I'll see what I come up with, I got so many things I wanna do, first things first. I needed to know about the rims, thanks.
Car: 91 Camaro RS
Engine: 305 TBI
Re: z06 rims
LiquidBlue
Wheels and Tires
32
12-10-2019 04:06 PM
