Tires for 1983 Pontiac Firebird Trans Am
1 Post
Car: 82,83,99 T/As
Engine: 350,350,383
Transmission: ST-10,700r4,4l60e
Axle/Gears: P-3.23,P-3.42?,P-4.10
Hey everyone, I need some help with tires for my 83.
I was recommended to go with 60 profile tires as height would not make that much of a difference on 15x7 rims (turbocast). Stock 3.23 rear (I think).
I am looking at
Size - Speed - Price
Cooper Cobra Radial G/Ts:
235/60/15 - T - $74
245/60/15 - T - $74
255/70/15 - T - $81
BF Goodrich Radial T/A:
245/60/15 - S - $79
255/60/15 - S - $83
255/70/15 - S - $82
Dunlop SP Sport A2 Plus
215/65/16 - H - $53
The tires are going on the rear wheels only. The fronts are 215/70/14 S-rated. I drive it daily and would also like to use it on the track. I've been told the BFGs have stiff sidewalls so they are worse for launch. I was thinking big/wide tires because of the look and contact with the road, although I don't know how much better performance tires would be with the better speed ratings.
Any ideas?
I'm not looking for anything expensive, just reasonable. The price of the Dunlop tires is really good, but are they good performers?
Thanks for any input.
http://answers.yahoo.com/question/in...050AAZrvEk&r=w
http://answers.yahoo.com/question/in...9223432AAjlktq
I am looking at
235/60/15 - T - $74
245/60/15 - T - $74
255/70/15 - T - $81
245/60/15 - S - $79
255/60/15 - S - $83
255/70/15 - S - $82
215/65/16 - H - $53
Any ideas?
1 Post
Car: 82,83,99 T/As
Engine: 350,350,383
Re: Tires for 1983 Pontiac Firebird Trans Am
I checked on a tire size calculator and 255/60s are about an inch taller than 235/60s. Is that a big difference? I'm not good with tires.
I'm leaning towards the Dunlops as they have a good rating for a good price. Second choice would be the Coopers.
BTW, would the Dunlops be good for or is that pushing it? lol
1 Post
Car: 89 Formula
Transmission: TH 700R4
The further you go from factory tire size the more your speedo will be out (assuming you don't try to keep the aspect ratio to width ratio close)
Not sure if you know this but I will break down a tire size for illustration purposes.
255--means width in mm
60---is called the ascpect ratio. It is a percentage of the above number, in this case 255. So the tire is 60% of the width in height.
15"--diameter in inches
In the 80's cars started to have lower (shorter) profile tires. A taller side wall will flex in corners, resulting in poor handling.
255/60s will loook very tall and chunky--gives it kinda of a 70's look, IMO--most people are after a contemporary look, with good handling abilities. Few on here run such a tire.
1 Post
Car: 82,83,99 T/As
Engine: 350,350,383
About the speedo thing, mine is pretty off as it is, so tire size wouldn't matter as it has to be recalculated anyway.
I've read about the flex issues and I agree, they're going to make for some poor handling. Like you said, a contemporary look with good handling will do it for me. So I am going with the Dunlop 215/65/15s.
Thanks for your help and input!
Great! Another thread to show off my Kitt
I have 245/60/15's...
As for the stock turbocasts wheels, I had them media blasted, edges polished then clear powder coat... they look sweet, easy to clean & are 3+ years old!
I see in your post, you're asking about 15 & 16 inch tires, but you say your car has 14's???
Rafael
Rafael
1 Post
Car: 82,83,99 T/As
Engine: 350,350,383
Damnnn!! Those are some nice looking wheels you got there!
I have 14s on the front and getting 15s on the back, so I was asking which are good tires for the rears.
Just a question with running 245s in the front, do they not rub the insides when making sharp turns?
I am going with 215/65/15s tomorrow for the rear as they are rated for better speed/traction/handling. But I am really missing the beefy looks.
-edit-
just saw that 16 there, that was supposed to be a 15. oops
-edit-
1 Post
Car: 88 T firebird
Engine: 2.8
Transmission: t5
1st decide on the width you want, then use the tyre calc to get the right profile to match the factory wheel diameters.
http://www.tyresave.co.uk/tyresize.html
i always use this one, put your factory settings in the top then play around with the second line.
what i do - especially for track, is get a lower than std profile, this will put less stress on drivetrain, make your car slightly quicker and slightly lower- for conering. all round good ;-) . i prefer 235's on light cars like ours, wont have too much drag but if you get the right rubber will give you plenty of grip - a loose car is a fast car.......
Car: 1985 Trans Am
Transmission: 350 turbo
Axle/Gears: Not sure yet
I'm getting some 14" turbo cast wheels. What would be the correct tire size to use in order to make the car look right?
1 Post
Car: 82,83,99 T/As
Engine: 350,350,383
Glad you know how to use the search and welcome to TGO!
I'm running 215/70/14 all around on one of my cars. They look alright. You can go a little wider if you want a beefier look. Just don't go too wide in the front or it might rub. 235/65/14 could work? But it also depends how wide the rims is, which is 7".
Car: 1985 Trans Am
The rims are 14x7, so could I get away with 235-70-14 all the way around?
1 Post
Car: 82,83,99 T/As
Engine: 350,350,383
assuming 215/65/15 is stock diameter, going with 235/70/14 will result in a 3.6% difference in diameter. That is not good as you want to keep below 3.0%. Farther you go, the more your speedo will be off. 235/65/14 is 0.1% difference. This size will fit 14x7 with the right tire. It will be hard to find size.
Or you can step up to luvofjah's size. Seeing as how his 245s do not rub, you can go with 245/60/14. BFGoodrich Radial T/A is available and will fit 14x7.
1 Post
Car: 82,83,99 T/As
Engine: 350,350,383
hah, yah you're right, wider is better. my brother's 99 has 285s and those look meaty.
just a side question, it looks like you repainted your car. would you happen to remember the paint code of the gold you used?
The gold was a gold paint found in 1982 color chart. There isn't a code for it since it's not considered a two tone car. The gold is considered a accent color and my paint codes are 19U 19L
Car: 3 3rd Gen F-bodies and 7 others
Engine: 305 CFI, 350 TPI & 3.8 Turbo V-6
Transmission: all automatics (stock)
Stick with the 235/60R15's. I don't know why everybody thinks they need to come up with all these messed up sizes. No one makes 235/65R14's or 235/70R14's
Stick with a size that is common enough that way if you have a blow out you won't have a difficult time finding a replacement.
P215/65R15's are super common and there are plenty of choices to go with if you choose to stay with the stock size (for those who have 3rd Gens with 15" wheels)
Also with tires, don't always go with cheap *** no name tires, you get what you pay for often times. Firestone, BF Goodrich and Goodyear are worth the money compared to the Korean and Chinese brands. The quality is worth the extra few bucks most times.
If some of you guys and girls took a look at the country you live in and the situations people are in with jobs you'd look at spending your money on products like tires that benefit this country and not China and Korea.
I know I got a bit off subject, but the number of tire posts I've read on here with so many different questions and ideas prompted my reply.
You may not all agree but no one ever does, can't satisfy everyone right...
Car: 1985 Trans Am
1 Post
Car: 82,83,99 T/As
Engine: 350,350,383
As for quality tires, can't disagree with you there. But you say buy tires that benefit the country. Can't say Firestone, they're Japanese. Can't say BFGoodrich, they're run by Michelin who are French. The only one is Goodyear. Or Dunlop who are British, but 75% owned by Goodyear.
1 Post
Car: 1983 Firebird Trans Am
Engine: 1969 Chevy 350 crossfire FI
Transmission: 700R4 overdrive auto
Axle/Gears: Posi Rear
Anyone have pics of the 14 inch turbo casts with the hubcaps installed on their car? I was curious to see the visual difference from the 15 inch wheels. Thanks!
1 Post
Car: 82,83,99 T/As
Engine: 350,350,383
I should have some lying around. Give me a day or two.
1 Post
Car: 82,83,99 T/As
Engine: 350,350,383
That's one. 14s all around.
1 Post
those look great, thanks for taking the time to post the pics my only concern at this point is if the 14s would work with my all wheel disc brakes, i wouldnt think the calipers are an issue.
Car: '92 Firebird + '06 Charger R/T
Engine: Firebird 3.1L V6
Transmission: Firebird Automatic
Just wanted to say that I'm so glad I stumbled onto this thread. I bought the 14" Turbocast due to the price of the 15" also.
Any complaints with 225/70/14? I think that's what I'm going to go with unless there are any major issues
...and just realized, sort of an old thread.... hope people still read this!!
1 Post
Car: 82,83,99 T/As
Engine: 350,350,383
According to the tire calc, you should be good. It's a 1.5% difference. It'll be slightly taller than stock (26.0" vs 26.4").
They make BFG Radial T/As and Firehawk Indy 500s. Same price, looks are upto you. Can't go wrong with either one!
I don't have the option to stick with 15" tires. Turbo cast rims are hard to find and 15" sell for upwards of around $2000.00. BF Goodrich makes a 235?/60/14 as well as a 235/70/14. I would love to have 15" wheels but their's a huge difference between $400.00 and $2000.00, and for what I'm doing I have to use those rims.
1 Post
Car: 82,83,99 T/As
Engine: 350,350,383
Depends on condition. If you want ones which are mint or nicely reconditioned, they will be very high in price.
colton_carlson
03-08-2019 12:21 PM
1992 Trans Am
Exterior Parts for Sale
04-04-2016 12:50 PM
