225's on 8 inch wheels?
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
Transmission: 700r4x2
Axle/Gears: 3.23 bw, 2.73 10 bolt.
hey guys. i have a set of GTA rims that need tires, i plan on getting the wheels refinished and putting new tires on next winter, but for now i have a set of potenza runflats size 225/50/16's, i know 235's work fine on the 8 inch rims, but is 225 going to be an issue?
Car: 1990 T-Top Camaro RS
Engine: engineless
Transmission: Trannyless
Axle/Gears: 10 bolt/3.08. soon to be axleless
Re: 225's on 8 inch wheels?
i dont believe they will be an issue. i got 235s on my rims. im sure 225s will work fine.
Car: 91 Firebird & 02 VW Polo TDI
Engine: 3.1 V6 & 1.4 3 cylinder
Transmission: Auto, M5
Axle/Gears: Stock
Hi Guys,
Don't know if it helps you but I've got 15" cast alloys (I think they were standard on the V6?) but the tyres are 225/60R15 :-)
Ian
Ian
Car: 1989 GTA
Engine: Future: LSX Turbo
Transmission: built T-56
No they wont. I would go with a 245 50 16 though...just looks a bit meaner but if you already have the 225s then you might as well.
1 Post
Car: 89 Formula
Transmission: TH 700R4
factory stadard tire size on 91-92 Trans Ams was 215/50/16.
So 225s will fit fine.
However---it will hurt in the looks dept and the handling will suffer. Just get some 245's
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
well i'm a bit short on the cash dept, and i have 225's already. but yea the last set of tires i had were some ol 245/50 eagle gsc's and they do give it an aggressive look for sure. gonna have to wait till winter to get new tires or untill the camaro sells.
thanks guys i think the modern potenza's compared to the old eagle's might be a wash despite 20 less mm of tread on all four.
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
heh did i mention the potenzas are RE050's? i think i got the right designation but after a search i find they are quite, expensive, i got mine cheap from my ol' job. i doubt i'll even see a drop in performance considering re050's vs the ol' gsc's
1 Post
Car: '08 Mustang GT
Engine: 4.6L
Transmission: º º 0 . . . |-|-|
Axle/Gears: 8.8", 3.55
You'll be fine with 225's on 8". Expect sharper turn-in response and a slightly stiffer ride.
Norm
Norm
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
i kind of figured, seeing as the sidewall will be more flush and less meaty with the narrower tread. can't wait, the new car the rims and tires will be going on has had addco swaybars installed and unlike my gta, it's bushings aren't shot and neither are the shocks. even if i lose all that torque and a lil horsepower the car ought to maintain speed better into and through the turn.
morrow
01-13-2024 12:29 PM
Hotrodboba400
12-10-2019 07:07 PM
