rear and side shots of 17x9.5
1 Post
Car: 1992 Camaro RS - 1971 Chevelle
Engine: 3.1L - 5.7L
Transmission: T-5 - TH350
i am getting these size of rims and just wanted to know what they look like from the rear and sides so if anyone has pics it would be much apperciated
1 Post
Engine: 3.1L - 5.7L
Re: rear and side shots of 17x9.5
Thank you, i've done alotta searching and found nothing really.. that helps alot, i'm getting Z06's put on soon and that was the size, i just wanted to get an idea on what they'd look like better, any rear shots would help alot
1 Post
Car: 1989 Camaro RS
Engine: Turbocharged 350
Transmission: Viper T56
Axle/Gears: LS1 3.23 Posi
I have 4th Gen SS wheels that are 17x9, note sure if that is what you are looking for but I can get pics if you want.
AC -
What brand/model wheels are you running? They are just what I am looking for!
AC -
1 Post
Engine: 3.1L - 5.7L
Yea, close enough, like i said, i just want to get a general idea of what they'll look like on my car
1 Post
Car: 89 trans am gta; now 92 firebird
Engine: 350 tpi
no, I've heard of others running that size up front with no issues. I would personally recommend 8's up front though. It looks bad *** like that. That's my thoughts. What kind of rims are you looking at??
1 Post
Engine: 3.1L - 5.7L
i'd like to get 8's up front, but they only make them in 9.5...
I am getting Black Z06's put on here soon.. les schwab claims that they'll fit my car with no spacers or anything.. so we'll see soon
1 Post
Engine: 3.1L - 5.7L
scratch the rubbing thing, talked to a guy at les schwab that actually has a camaro and he said their book is right and we can run as wide as 9.6's so i'm good.. Thanks alot for the pics, i'll be sure to post some pics up with the rims on later
Car: 1984 Camaro Z28
Engine: '92 LT1
Transmission: 700R-4
Axle/Gears: 3.73 factory posi. disc brakes
I have 4.5's on the front that's hardcore
1 Post
Engine: 3.1L - 5.7L
dang lol, that's like how wide my riding lawn mower's wheels are.. i've seen pics of another guy on here tho that has around that up front and their sick looking
Car: Used to drive a camaro
The wheels I have are ROH RT's with a black ice finish. 17x9.5 rears, 17x8 fronts. Nitto rubber all around. My ROH's might be up for sale soon with the tires (only 1000 miles on them) because I want to go 19" rear and 18" fronts. I'll be taking a rear picture this weekend and post it up.
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
i have 17x8 at all four corners with nitto rubber. that extra inch and a half on the rear makes a HUGE difference. wish mine sat like that!
Tobias- You can get a wide tire on a 8 inch wheel as well. You wont be getting a 295 tire but you can go pretty wide without buying new wheels.
I've got 10 out back and 4 up front and IMO a 315 tire out back looks the best on these cars.
Also one more thing to remember is that the wider of a tire you go in the front the higher the chance of the car drifting around and pulling hard when you hit a line in the road or something. Just to keep in mind.
-LINY
-LINY
'86 Camaro BoSs, sorry it took so long...we've had snow ALOT.
Heres some shots of what the rear 275 Nittos look like on 17x9.5 ROH's.
I've got some 17's that are 9.5 too:
Had to ditch the mudflaps because it looked like I was trying to stop a waterfall with a 2X4.
1 Post
Engine: 3.1L - 5.7L
Havn't got a chance to log on lately either, those look great.. maaco's still takeing forever.. i reget sending it in there almost now.. but with how long it took the paint better amaze me or i might lose it.. lol.. thanks for the pics AC they look great in the rear.. idk how the front iwll look... anyone got a pic of that up front?..
Mine are c6 wheels 17x9.5 with 275 tires on all four corners.
https://www.thirdgen.org/forums/cama...my-iroc.htmlon
Car: 86 iroc
Engine: 496ci
Transmission: stock t5
Axle/Gears: stock/323 posi
http://i202.photobucket.com/albums/a...4/SANY0240.jpg
and another one
http://i202.photobucket.com/albums/a...4/SANY0242.jpg
and another one
1 Post
Engine: 3.1L - 5.7L
ok.. so if i'm not crankin the wheel i'll be good.. that's good to hear.. i know that i'm going to need to drop the car cause it bugs me of the gap that our car's have after we put these big of rims on.. thanks for the info guys.. anymore pics or info on the drop would be appreciated
Car: 1989 iroc z
Engine: 98 ls1, prcs, btr cam
Transmission: rkt56 6 speed
Axle/Gears: midwest chassis 9 inch 4.30wavetrac
those vette wheels will rub i have 18x10.5 in the rear and 17x9.5 in the front and all four rub i cant lower the car because the rears wont tuck in the wheel well and it wont turn very well..... nothing a little fabrication wont fix though
Car: 1989 iroc z
what he said i had to cut off bump stops at 275 in the rear id go wider if i could with out shortening my axle
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
I can fit 345/30/18 drag radials and still have room.
The wheels are tucked nicely, about 5/8" in from being flush with the fender
https://www.thirdgen.org/forums/susp...s-widened.html
Car: 1989 iroc z
they look awesome as hell did you buy a kit or make the wells yourself
Car: 1989 iroc z
its dirty and i need better pics
1992 Trans Am
05-10-2023 07:19 PM
novaderrik
08-10-2015 12:44 PM
