camaro pics with Z06 wheels and wheel specs
#51
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: camaro pics with Z06 wheels and wheel specs
you may need it. Somtimes the rear is centered enough after the car is lowered and you dont need it. but having one wont hurt
#56
Car: 92 z28, 07 Silverado
Engine: LS1, 5.3
Axle/Gears: 3.73, 3.23
I got nitto nt555 all the way, found the rear tires at a swap meet for 40 bucks, still got about 50% tread left. as far as the front wheel spacers, they are from skulte, but being the cheap bastard i am, i searched and searched on ebay untill i fould a used set, i think i payed like 50 bucks for them with shipping, lol
#57
#58
ok, ive gone through this whole thread, as well as the post you vette wheels thread and have not found my answer.
Is anyone running the stock C6 Z06 rims on a third gen.
I believe they are 18x9.5 and 19x12. will they fit.
I want to change out my current c5 setup
[IMG]
[/IMG]
[IMG]
![](http://i291.photobucket.com/albums/ll302/carlosramos00/IMAG0072.jpg)
#59
Car: 92 Camaro RS, 84 Recaro T/A
Engine: LS2, none in the TA at the moment
Transmission: T56, 700r4
Axle/Gears: 3.23 posi, G80 LSD
[IMG]
[/IMG]
[IMG]
and for the front, you are going to have to do some work on the fenders as well to be able to turn from full lock to full lock without rubbing the fenders or the inner fender wells
#60
http://www.oewheelsllc.com/Wheels_3/...-Wheels-Argent
http://www.oewheelsllc.com/Wheels_3/...heels-gunmetal
I really liked orr89iroc's wheels which are the c6 competition gray 19s in the rear and 18s up front, and oe wheels has them dished as shown. So basically I was wondering if anyone has run either of these 2 wheels and could please post pictures because I'd love to see them on more irocs before I make a purchase! Anyone?!
![Big Grin](https://www.thirdgen.org/forums/images/smilies/biggrin.gif)
#61
woops just found the thread that answered my questions if anyone is interested: https://www.thirdgen.org/forums/post...5-post304.html
pics are still welcome tho
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
#62
Car: 1991 Z-28
Engine: 5.7L(350ci) TPI L98
Axle/Gears: G92
So, I have a 1991 Z-28, stock. 4 wheel disc (non 1LE), Perf Suspension Package etc.
If I buy these:
http://cgi.ebay.com/ebaymotors/18-Po...ht_1717wt_1165
And (4) 2" adapters, they should go on my car with no problems?
Also, is around $600 a good deal for those rims?
If I buy these:
#64
Car: 2000 Camaro SS
Heres mine, 2 inch spacers in the rear, 1.7 up front with the brake upgrade, 285/35/17 rear, 275/35/18 up front
Attachment 219240
Attachment 219241
Attachment 219242
Attachment 219240
Attachment 219241
Attachment 219242
#65
Engine: LS1, 5.3
Got it for 800 bucks used, was in great shape, goes for like 1500 new
#66
Car: 91 Z28
Transmission: 5 speed
i read racing geek did 18x10.5 all around has anyone else done that? i have 4 chrome chrome zo6 18x10.5 and was wondering what your guys' thoughts are for getting them installed. 58mm offset. stock axle. disc brakes front and rear non 1LE.
#67
Not sure about 10.5s up front but in the rear is fine. Make sure you check the spacing changes that may occur when using other than stock front brakes. For example the c4 brakes push the measurements out like .3" on each side up front so you need a thinner spacer to prevent rubbing tires on fender wells.
#68
Car: 2004 BMW 325CI/ 1991 Camaro Z28
Engine: 2.5 straight 6/ 305 TPI V8
Transmission: Steptronic 5 spd./5 speed manual
Axle/Gears: Stock/stock
#69
Car: 91 Z28
Transmission: Automatic
#70
Location: Home of the world champion San Antonio Spurs. 210 baby!!!
Car: 1992 Z28 Convertible
Engine: LB9 - seeking sped density L98
Transmission: 700r4, have a t5 I am swapping
Axle/Gears: G92 3.23 third gen Borg warner
#72
Car: 1992 Camaro RS
Engine: Stock 305
Transmission: Stock
Axle/Gears: Stock
Alright everyone... Don't yell at me for asking, but will these fit?
http://www.ebay.com/itm/321707569455?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I want to wrap them in Nitto Invo 285/35r19's in the rear and 265/35r18's up front. My 92 isn't lowered and I was planning on running 2" hubcentric spacers all around. I read that possibly a 2.25" is better for upfront? Comments? Concerns? Advice?
Thanks everyone!
Thanks everyone!
#73
Here is mine
91 Z/28 M6
Eibach springs
OE Wheels C6 Z06
18x8.5 front / 1.5 spacer /255/45/18 Sumitomo
18x10.5 rear / 2 in. spacer / 285/35/18 Sumitomo
Slight rub in the rear forward inner part of the rear wheel well, nothing a BFH wont take care of
Mike
![Name: mikesphone2077.jpg
Size: 181.3 KB](https://www.thirdgen.org/forums/attachments/wheels-tires/327138d1501290574-camaro-pics-z06-wheels-mikesphone2077.jpg)
91 Z/28 M6
Eibach springs
OE Wheels C6 Z06
Mike
![Name: mikesphone2152.png
Size: 979.7 KB](https://www.thirdgen.org/forums/attachments/wheels-tires/327139d1501290574-camaro-pics-z06-wheels-mikesphone2152.png)
#74
Z06 Replica rims here. WIP.
18X10.5 in the rear with Continental DWS 295 35ZR 18. 2" spacers. About 1/2" clearance with inner wheel well. Not road tested.
17x9.5 in the front with Continental DWS 275 40ZR 17. 2" spacers. Clearance OK with wheels straight. Not road tested.
Original brakes in the pics. Upgrading rear axle next to 2002 Camaro SS. Will road test after axle replacement...
#75
Car: 1992 25th anniversary RS..Z28 clone
Engine: 5.0L 305ci V8 TBI (soon to be TPI)
Transmission: auto
#76
Car: 1986 Camaro Iroc-Z28
Engine: 305 5.0L
Transmission: 700r4 Automatic
#77
http://www.ebay.com/itm/321707569455...%3AMEBIDX%3AIT
Thanks everyone!
Thanks everyone!
I run a 2 inch on the front and 2.25 on the rear. I would say the 2.25 wouldnt be bad if you want to go that wide. The 2 inch gives it a very staggered look pushing a 295 on the rear.
#78
I'm two posts above your post with the red very with black z06 wheels. And it's a 285 rear, sorry
#79
Car: 1987 Camaro Iroc Z
Transmission: T-5 5 speed
Ok so to further revive a dead thread I’m looking at the C6 Z06 rims 18x9.5 to put on my 87. I have stock suspension and I’m wondering what’s the maximum tire size I could go, what’s the minimum and maximum space size I need and will I have any clearance issues? Any advice is greatly appreciated.
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
