questions about custom wheels and offsets
#52
Update: after a few days of looking arond for news I think I am going to go with a 18x9 in the front and 18x10 in the rear. I will have to switch back to a 3rd gen rear when doing this. My question now is what backspacing changes need to be made since the wheel is 1/2" narrower then what most everyone runs here?(9.5") I also plan on adding the C5 brakes so I need to take that into consideration when ordering the custom backspacing for the fronts. Maybe Im asking for too much with this but I want the car to track good and have a deeper lip or equal lip on the rear. I just dont want the front wheels to have a deeper lip then the backs. Its looks funny on the GTA wheels
#53
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: projects.......
If you want to make sure that the lip is deeper on the back, then run the same bs as the guys running the 9.5's. This way you'll loose the 1/2 of width on the outside lip. Actually, since the new rotor hat will move your hub out almost another 1/4", you could add that 1/4 to the bs also.
I don't know if you've seen pics of mine, but I'm probably gonna tuck mine under about another 1/2" so I can lay it in the weeds. - I'm thinking I'll probably ditch the 10-bolt with the new chassis, so custom axle/housing length won't make a difference.
#54
so is it as easy as placing an order for wheels and giving them just the backspacing desired or do I still need to make sure the offset is correct? I was looking at wheels on nestalagiawheel.com and I emailed them asking the specs on some wheels and this is what they said
18x9 with 6.00 bs and +25 offset and 18x10 with 6.00 bs and + 13 offset.
This is for the JYD wheel.
The reason for 6" BS on the front is to take into concideration the C5 brakes
Do those specs look good or will I have problems with them rubbing or not fitting right?
#56
no, the C5 brake rotor will push the wheel out another 1/4" more then stock. You may be getting confused based off my previous post aout the 6" BS. I was gonna try and use a 6" BS on a 9" wheel to make sure it would not stickout past the fender. The additionally 1/4" from the C5 rotor would theoredically put me at 5 3/4" BS and then I would add one of those stock spacers if need be. I am ditchng this idea since I highly doubt it is possible to get a 9.5" wheel to fit correctly inside the wheel well AND stil use the C5 brakes. The wheel will just stick out too much for my liking. Now I dont know how well a wheel would fit with a 5 3/4"BS but I really dont want to find out the hard way. If I get a chance I may try to make a homemade tool to check it
#58
ya I know that. maybe I miss worded it wrong. what I was trying to say is that by going with a 5.75" BS ona 9" wheel AND adding the C5 rotor that my wheel would now sit in the same location as the same wheel with a 5.5"BS.. I think. If I put a wheel with a 5.5" BS on the car with a C5 rotor then the wheel is going to sit in the same place as a wheel with a 5 1/4" BS would on the same car with a stock rotor.... I think. Does that make sense
#60
so now I gotta see if its even possible to get a 9.5"wheel with a 5.75" BS to fit right with the C5 brakes. It shouldntit anything on the inside since a lotof guys run that wide of a wheel with a 5.5" BS which is where my wheel should sit once the C5 brakes are are on. Once I get my car back from the dyno, I will try to ake a tool or buy one from Summit that would allow me to simulate those specs along with a tire profile
#61
Car: 1986 iroc
Engine: 350 .060 AFR HSR XFI280
Transmission: transgo 700r4
Re: questions about custom wheels and offsets
im looking in getting new rims. im interested on the 15inch rims WeldRacing Draglite and want to go the widest i could go and what backspace? 295's and up will be allrite.
also, im thinkin in running skinnys on front what would the a good size?
ambainb
04-25-2016 09:21 PM
kah992
08-19-2015 02:55 PM
