Lightest rims made for an f body?
Car: 2004 GTO
My stock Formula rims weighed in at 55lbs with center cap and 255/50/ZR16 BFG's. The Ronal's on my car now weigh exactly the same.
The GTA rims are MUCH lighter.
Car: 91 firebird now
Transmission: 5 speed
The car im buying has GTA's on it, now when I get it home in 5 days Im gona have to take off a rim and weigh it LOL.
I used to install tires for a living.. Point is if you want to know how much the rim weighs you need to do it without the tire on it because I've seen hugh difference in weight from tire to tire that were all the same size
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
for some reason i want to say that 18 lbs sounds about right for the GTA rims alone... i am not positive... but that rings a bell for some reason... don't quote me on it though
Yep, that's right...
18lbs for the rim alone is dead on the nose. Of course that doesn't count center caps and lugs Are we being truly picky here? I know someone on this thread would have brought that up.
I plan on changing the 17" billet rims I have on my IROC now for some black GTA wheels around spring time.
I need to get the WC T5 swap done, and get the '870 ECM out and the '165 in first though.
Originally posted by FLYNLOW92rs
What do the factory rims and tires weigh....
Inflated to 35 PSI anyone know????
Do you think it'll weight more if you inflate it to 40lbs?
:sillylol: :sillylol: :sillylol: :sillylol: :sillylol:
Anyway, I've got a set of 15x7 centerline magnesium wheels on my Sport coupe. They're an aluminum/magnesium blend and I'll bet the wheels are under 10lbs each. I've never felt such a light wheel ever.
lol if you inflate the tire more its gonna weigh more.....but not by much
1 Post
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
Make sure you change out the summer air and put in winter air. It saves weight, I promise!!!
Originally posted by panman79
I have centerline modulars on mine and my rear wheels weigh 15 lbs.
http://newton.dep.anl.gov/askasci/eng99/eng99085.htm
Here is a discussion of why using nitrogen in tires can save weight, cause air weighs more....
So in theory if air has weight, the more in there, the more it will weight......
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
the amount of weight difference has to be miniscule if any at all.. not even measurable by the scale your using i would bet.
Steve
Steve
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Just about every online tire/wheel business ships their wheel/tire combos out with 30-50% of air in them because their lighter that way. It saves them some money on shipping costs. I doubt it's a lot per wheel, but if you ship thousands out per year, I'm sure it adds up.
Jim...... have you ever lifted a full bottle, then an empty bottle of argon or propane? There's a difference between compressed gas/air and atmospheric pressure.
also remember that those bottles of argon are coming up aronf the 1500psi mark too! were talking about a tire with 35psi in it
With propane, keep in mind that its being filled with a liquid, not a gas as well
I don't know about argon, but like fb said, Propane is in liquid form in the tank. Same deal with freon. Quite possibly the same with argon, I don't know.
I'm not disputing that a 30lb tank of LIQUID doesn't weigh 30lbs more than an empty one.
Originally posted by Jim85IROC
I've lifted a full/empty compressed air tank that I use to blow up tires with. It doesn't feel any damn different full or empty.
This isn't some great discussion on properties of various elements....
Air has weight........The more air in a tire.......the more it weighs.........Albert Einstein didn't have to tell us this.....
Now does it really matter when it comes to inflating to 35 or 40 PSI......NOPE....maybe a few molecular weights....
BUT, for arguements sake 40 PSI inflated tires DO weigh more then 35 PSI tires.....
all matter has mass, and therefore weight
air = matter
therefore, Air = weight, and Air + Air = more weight.
if you took something a bit larger like a huge truck wheel, and placed it on an accurate scale, it would should a noticeable difference from the uninflated weight.
lol no offense to this guy, but wow thats really dumb. gaseous substances are matter just like liquid, its just less dense. today, i picked up 2 100lb oxygen cylinders, 2 acetylene, and one 100lb argon.....and i dropped off the empties......theres quite a bit of difference in weight there. its easier to notice because of the density due to the huge pressure in a gas cylinder....theres more in there
air = matter
a gas like argon, CO2, oxygen, and acetylene are all stored at MUCH higher pressures than what you would find.
Of course when you compress air, and make it more dense, the weight goes up, but most gasses at a pressure of 30-40psi will for the most part less than a ounce.
This is about an absurd arguement. Will a tire with 40 psi weigh more than one with 35? Yes. But come on! The damn manufacturing tolerances probably make a bigger difference than that 5 PSI!
And to those who are carrying on about the propane and argon comment I made.....
IT WAS A JOKE PEOPLE!!!!!!!
I could say "that's why the earth's flat" and some of you would take that to mean I really think that and carry on another 7 day argument about it.
The joke was intended for Jim because he has a habit (although not bad ) of being sarcastic sometimes. That's all. A little 'poke fun' humor.
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Amazing how arguments can start from the simplest, dumbest things isn't it?? Btw AJ, your Honda/Mountain Dew thing...that's great. I have to remember to tell that to my friend with a saturn..1.9 liters. Or my other friend with a Daihatsu Charade...inline 3, 1.0 liters. Thats right! 1.0 even...
Car: 87 Black Formula
Engine: Rollercammed Lg4
Axle/Gears: 3.23 10 Bolt Locker
[i]......Or my other friend with a Daihatsu Charade...inline 3, 1.0 liters. Thats right! 1.0 even... [/B]
Oh well, to the subject, I think the main difference in weight when it comes to wheels is whether they are cast or not. The cast ones weigh alot more. Look at centerline, only billet and ... what do you call the convo pro's... stamped? not cast anyway. So if you're looking for some light wheels, just dont get cast ones and then you're set.
Congratulations, you resurrected a 1 1/2 yr old post.... You are the man. :hail: :hail: :hail:
Yeah, I search alot in the forums. Is it bad to resurrect an old post? Lot of good info although it's old.
It's just taboo.... And it makes people like me make fun of you. Lol :lala:
Oh, well, since you only got a 302 in a FORD!!! I guess it's me who should make fun of you, right? What's that wussy gay 302 eh? I've got 3 more inches than you! Yeah!! LOL
Hmm, fair enough. But can your 305 do 13.73 at 104 mph?
No sorry, I can't not at the moment. But still, I race cars where I'm at, not in the US, and over here my car is considered pretty fast, at least as a daily driver, and on the street I'm able to smoke most cars unless it's a skyline turbo or something, but there ain't much of them around, that's for sure.
I'm going to the track the 29 of June, after that I can post some real number, hoping for high 15's with better traction, as a baseline for future mods. But still, you know, hard to beat that "3 inch advantage"
Lol, yeah.....the 3 inch advantage.. lol Honestly that ET isn't bad for what you're working with. Those little 305's were never meant as performance platforms, so you've got more of a challenge. The reason the 302's perform is because they were meant to compete...in the later years of the third gen, they had to compete against 350's. Now THAT's a displacement increase worth counting.
xpndbl3: Well I'm still running a stock transmission with 153,000 miles. Gimme a race trans and I'll beat my own time. Whatcha got done, just out of curiosity?
My mod list is: New 302, Edelbrock Performer RPM heads, cam (220/220, .498/.498 at .050), 1.6 full roller rockers, full Cobra intake, 75mm MAF, headers, offroad X pipe, dumped Flowmaster 40's, , 4.10 posi
This combo SHOULD make over 350 hp at the fly, but right now due to the tranny it's only outputting approx. 280 to the wheels.
Terrell351
06-13-2021 01:13 PM
colton_carlson
03-08-2019 12:21 PM
