CAMARO SPECIFIC PARTS REQUESTS
#51
#58
Moderator/TGO Supporter
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
1 Post
Car: 87 IROC 92 Z-28 91 Ragtop
Engine: 5.7
Transmission: 700-r4
'89-'92 spare tire for PBR calipers and 16 inch wheels
Spare tire needed for 16 inch alloy wheels w/PBR calipers -- The spare wheel has a P195/75-D15 tire on a deep 15X5 rim. The P195 tire has a wide tread width and has "XUB" stamped next to the valve stem. The air canister is on the back side. 1991-92 Camaros came with this tire from GM.
Don't need the air canister.
An alternative is a 4th Gen spare - The steel 16-inch wheel with a T135/60R tire from a 98 Z28 also fits and is small enough for the ThirdGen trunk.
Thanks for any help!
#59
1 Post
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Is that spare from any 91-92 or only the 1LE's, we have the info written down and will look for you. We have a 98 Camaro but not sure if it's a Z, I'll let you know what we find.
![thank you](https://www.thirdgen.org/forums/images/smilies/thanks.gif)
#64
I have an 86 Camaro with a 92 body kit on it and no third brake light. I would like to add the 92 third brake light setup. What do I need to add it? Are the parts available? The interior is gray.
#66
1 Post
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I believe you would need the headliner trim piece, the third brake light and the pigtail. You would probably have to splice it into your tails but yes we can get you the setup.
#67
I'm gathering the parts to do a ECM swap from 89 IROC 165 to 730. I'd like the three connectors with pigtails that connect to the 730 ECM (91 or 92 IROC). I'd also like to have a connector with pigtail for the block mounted knock sensor. Also, since I'll be removing the MAF, I need the part(s) that would fill in for the MAF. Please PM me with the info on what parts you have and cost to ship to 37923.
#68
1 Post
Car: 04 Silverado
Engine: 4.8
Transmission: auto
#70
Car: Fire Red 89 RS
Engine: 2.8L :(
Transmission: 700r4 auto
duke what do you have in the way of posi rears? also i highly doubt it but do you have lower control arms and/or panhard bar from a forth gen or after market? if so how much shipped to 11776
#72
Car: Fire Red 89 RS
Engine: 2.8L :(
i deffinately need prices on the parts though because i went to junk yards around here and the one i started asking about forth gen parts at was giving me prices ten dollars under brand new.
#77
Car: 1986 Camaro Z28
Engine: 400 chevy small block
Transmission: 5spd
floor
I am in need of 2 rear floors(left and right) for a thirdgen camaro. I am talking cut from a part car. I would also need the piece that is welded to the rear floor and the frame that gives support to the rear suspension. look in pic..
https://www.thirdgen.org/forums/body...-pan-help.html
If you could manage to cut these off each side of a car and be able to ship it to 55803, can you give me a quote or e-mail kyle @ southpole07@msn.com. THANKS!
#78
1 Post
Car: 04 Silverado
Engine: 4.8
Transmission: auto
#79
Car: 1989 Camaro RS
Engine: 5.0 TBI
Transmission: 700-R4
Axle/Gears: 3.42 open....3.73 posi soon
Axles
I was wondering if you had any 28 spline axles from a 90-92 camaro. Must have drum brakes and be 30 5/16 in length. Please email me at tommyboy_143@hotmail.com. Thank you in advance.
#82
#84
Car: '85 Camaro Z28
Engine: 350 carbed.
Axle/Gears: 9 bolt, 4.11's
I am on the lookout for a few interior bits... and pieces.
T- top stowage bag
Black sun visors
Plastic cover for rear cargo area (black, no el. hatch pulldown)
black kick panels
black sail panels (speaker covers)
all pieces for a '85 Camaro z28.
-Camarogeddon
T- top stowage bag
Black sun visors
black kick panels
-Camarogeddon
#86
Location: South Bend Indiana iphone CALL OR TXT 574-607-2389
1 Post
Car: 2003 GMC 2500HD Sierra Pickup
Engine: 6.0 Vortech
Transmission: 4x4
Rcar7395@comcast.net
We have everything except the t-top bag. Maybe 1 t top bag condition is unknown. PM me for prices!
#87
Car: 1987 IROC
Engine: Built 350 TPI
THANKS,
LARRY
#88
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
Transmission: T-56 fully built WOOHOO
89 iroc 5.7
complete dash harness, with vats box and key,
somone did a hack job of installing an alarm and am looking for a factory uncut harness without an alarm.
let me know asap thanks
eric
eric
#92
1 Post
Car: 85 ish IROC-Z
Engine: 355c.i
Transmission: built 700r4
Axle/Gears: 3:73s, six point cage from jegs
I need a fiberglass hood ,repairables are ok cowl or stock 83type nothing to big though do you have anything send pics if you do
#98
Car: 1986 & 87 Camaro
Transmission: 700R4 & PG
Axle/Gears: 28spline 4.10 & KTRE 12 bolt
Need a price for a lower & upper fan bracket for duel cooling fans shipped to 07424.
Thanks Frank
Thanks Frank
#99
Car: 1990 RS
Engine: 305 tbi
Axle/Gears: 10-bolt 2.73 open
hey guys...I'm looking for a replacement 350 for my 88 Iroc...the original was..let's just say it was punished. Anyway...let me know if you got one, or even sell engines...thanks alot, guys.
#100
Car: 1987 IROC
