INTERIOR PARTS
#52
Car: 1992 RS
Engine: Vortec Headed 383 9.6:1
Transmission: TKO600
Axle/Gears: 10 Bolt Posi 3.73
Driver's side A pillar trim and the plastic pieces that fasten it to the body for a hard top 92 camaro.
#53
Car: 85' Z-28
Door Panels
Looking for gray door panels, both sides. They are gray and black lines at the
top and gray on the bottom. 82-85 I beleive? I may be enough info so a few choices would be nice.
#54
Car: 1982 Trans Am
Engine: SBC 400
Transmission: 700-R4
Axle/Gears: 9 Bolt 2.77
1982 Camaro Black Front Seatbelt Recievers
I'm looking for a set of BLACK, UNCRACKED, front seatbelt receivers from an '82 Camaro. These may be the same up to '84, not sure. I just need a set NOT cracked.
Thank you.
Thank you.
#55
1 Post
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I think we have a set in blue but so far no black.
Last edited by 82 Iron Duke; 01-06-2007 at 01:28 PM. Reason: Automerged Doublepost
#57
Location: South Bend Indiana iphone CALL OR TXT 574-607-2389
1 Post
Car: 2003 GMC 2500HD Sierra Pickup
Engine: 6.0 Vortech
Transmission: 4x4
i have a 91 firebird 3.1 lt. non t top power truck latch. ..... i need alot of help. k to start with i need a trunk latch and the cover for it.. i need a key for the trunk not importent though. i need a dimmer switch, and a power antenna and if at all possible can someone tell me how to remove the center arm rest where the the gears are and the compartment thanks awhole lot PM me so i get an email thanks
Ray
#58
#59
1 Post
Engine: 6.0 Vortech
Transmission: 4x4
#61
Car: 85 z28
Engine: 355ci
Transmission: th400
WTB set of front seatbelts, black not faded, seatbelt guides also black, headliner transition piece black (on the seatbelts, i jst need the belts not the reciever and i don't want faded) shipped to 37341...also need inner fenders l&r and rocker panel emblems in excellent shape silver, 85 Z28
#63
Car: 85' Z-28
1 Post
Car: 04 Silverado
Engine: 4.8
Transmission: auto
No verts, sorry.
Last edited by 82 Iron Duke; 01-07-2007 at 10:53 PM. Reason: Automerged Doublepost
#68
Moderator/TGO Supporter
Looking for the following parts off of a 85-92 Firebird/Trans Am
Black console lid, would like no rips holes or sepration.
Radio pod in grey
the center console wiring harness, mainly need shifter plug and light plug,
and console door light wiring and switch wiring plugs.
Driver side cup holder and screw covers in grey
Driver side door handle plastic trim and screw covers See attached pic
Driver side a pillar plastic trim with t-tops
Also need a cruise controll module mounting bracket and cable for a tpi car.
91-92 firebird/trans am/formula turn signal lenses and mounting brackets, really need passenger side
Thanks for helping out
Aaron
Radio pod in grey
Aaron
#69
1 Post
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Radio pod in grey
Aaron
Radio pod in grey
Aaron
1-Yes
2- Berlinetta?
3-Yes
4-passenger only
5-yes
6-yes
7-possibly from an 88 GTA
8-pics would be great so we are on the same page.
#70
On the radio pod it is where the radio mounts on the firebirds, I think mine is dark grey or black.
Also I am looking for a key warning beeper/buzzer box for a firebird as well.
The cruise control bracket is the one in the pic
if you want you could pm me the prices
#75
1 Post
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Right now hard top only, what color and I will see if we have one.
PM sent Aaron, been very busy sorry about the wait.
Last edited by 82 Iron Duke; 01-12-2007 at 05:59 PM. Reason: Automerged Doublepost
#76
Car: black 88 formula
Engine: 355 tpi
1.console for an 88 formula
2. door panels for both sides for an 88 formula they are a dark grey or just grey
3. the cupholders for both sides
#80
Car: 1988 GTA
Engine: 5.7L
88 GTA
I need the piece of trim that surrounds the radio/temperature control unit (T.C.U. ??? WTF is it actually called? lol, you know what I mean).
A 140mph/8K tach cluster.
S&H to L9W5H5, Ontario, Canada
Also, I see that there is a market for a digital dash, what is it worth, I'm going to take mine out and replace it with an analog setup and I'm curious how much I should sell mine for.
#81
1 Post
Car: 04 Silverado
Engine: 4.8
Transmission: auto
#82
Car: 25th Anniversary Camaro RS (1992)
Engine: 3.1 V6
I need a 110mph instrument cluster in white...i hope thats even out there...i have a 92 camaro and i want a white cluster instead of the black. I have tried the overlays, and they dont work as well as i wanted, so thats why i need the whole cluster
#86
Car: 1989 Camaro RS
Engine: 5.0 liter TBI
I need a headliner for my 89 camaro rs. No T-tops. I am also trying to find a replacement center console/ auto shifter assembly. I broke mine trying to fix my car. Prefer black. Thanks in advance.
#88
Car: 1983 Recaro T/A
Engine: L69
Transmission: MM5
Axle/Gears: 3:73
#89
Car: 1983 Camaro Z28/1999 Cavalier
I know we talked about it a while back, but now I'm kind of in need of a few different things.
I need the little plastic piece that screws the headlight switch into the dash, doesn't matter how it looks just needs the full set of threads. Also, a big assortment of torx screws, the big screws that hold the plastics on in the hatch, the phillips screws that hold on the door sill pieces, the plastic that goes inbetween the t-tops and the hatch.. just a whole bunch of random screws really. I have Paypal now, so if you guys do Paypal that would be great. Could probably Paypal the money to you tomorrow after I get my check deposited. LMK as soon as possible.
#90
1 Post
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Are you still interested in the door panels, we can give you a really good deal on everything. PM me with a complete list.
#91
Car: 1987 camaro
Engine: 6 cylinder
Transmission: 5-speed
I need a perfect condition seat belt complete set for a 1987 camaro with rear lap belts...do you got? can you send pics to Transam346x@aol.com
thanks,
Nick
thanks,
Nick
#92
1 Post
Car: 04 Silverado
Engine: 4.8
Transmission: auto
thanks,
Nick
thanks,
Nick
#96
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Jeff's Wishlist:
* Black plastic seatbelt trim pieces where belts retract into roof
* Black carpeted kick panels both sides
* Driver side under-dash plastic for 1992 Camaro with fuse cover
* Swivel light from overhead console (or an otherwise busted overhead console with a good swivel light
* Last small item: 1992 Camaro, in the dash, in the center, above ashtray/radio pod, there is a very small little light - it's pigtail connects under the dashpad - has a black and gray wire, the connector must be pushed in and turned 1/4 turn to remove - the whole light may be 1/4 inch diameter, and there is no replaceable bulb - the whole light/pigtail is one assembly.
Thanks.
Thanks.
#97
1 Post
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Jeff's Wishlist:
Thanks.
Thanks.
1-The seat belt trim pieces are one piece, they can be cut off but will have a slit in the back of them, I do believe someone sells replacements but
2-We have a set of black carpeted panels in stock.
3-On the swivel light, I think so because the lettering is gone, the dials are messed up, and the dome lens is missing.
4-We can get one.
#99
Car: 1987 IROC
Engine: Built 350 TPI
