Anyone offer a lesson in vacum lines?
well, its easily said i have learned so much over the last few years while owning my 'bird and visiting this forum...so i have a question about something that i was never really quite sure where they were located of what they did.
vacum lines.....ok, from what i read they can cause a lot of probelms if they break, fall off....etc. now, i think i know where to find them. are they those thin (maybe 1/8") black placitic tubes that run in, out, and around the plenum?? if they are, then i think i know what they are. but how many are there?? and what do they do? where do they create the vacum?? etc....
thanks for whoever responds, i have been wondering this for a while.....
1 Post
There not only the plastic ones .But alo rubber hoses .The ones that hook up to your Charcoal canister are vacumn .There easy to change , sometimes you just strain your guts out to get one off .If your car is in need of new vacumn hoses , it will run so much better after you change them .You should have a diagram near the underneeth the front part of the hood , displaying the vacumn hoses .I think its even called the "Vacumn hose diagram"...goodluck
The engine is a vacuum cleaner.
It creates a sucking system.
The hoses pass around the vacuum signals to various components to make them operate on cue.
Go to the GM dealer. Buy the parts guy a soda, ask him for the illustrated printout of the PVC system for your engine.
Use 5/16" windshield wiper hose to fix platice breaks. Use 1/2" heater hose at the one at base of distributor (driver side).
This plastic hose stuff in no longer available.
In my search for answers, like your question (during swap mission,) I discovered 1985 V-6 is a one year stand alone design.
Wayne is 100% correct in his answer, too.
PS, install a vacuum gauge on your ride.
Best gauge you can invest in for your car. Promise.
Every car of mine has one or will or is planned not installed, yet.
Car: 1986 Firebird
Engine: 2.8 V6
Anyone replace the ones going to the charcoal fuel vapor canister? Mine seem to be decaying; if you rub my finger on 'em, the outer covering of the hose leaves a black mark on me that's a btch to wash off. Looks like I could just use regular 'ol fuel line. Anyone do it?
TomP,
Yeah I have done it. It is a prety standard size. I can't remember the size off the top of my head. I just yanked one in the parking lot of the parts store and brought it in with me. Then matched it up and cut a length of bulk vaccum line.
Worked just fine.
Worked just fine.
Engine: LH0 3.1L
I've recently replaced a few hoses. My line going down to the Air Manegement Valve had a fat hole in it. Anyway, most cars use either 5/32 or 7/32 vacuum hose(not including stuff like the brake booster vac. line). Just go to your local parts store and pick some up.
Hotrodboba400
12-10-2019 07:07 PM
92projectcamaro
01-18-2016 08:00 AM
86CamaroDan
09-29-2015 10:08 PM
