Torque Converters , can't find one AND I NEED IT !
1 Post
Well my injectors arent too much a problem anymore , not right now atleast ! My torque converter is making my car shake again .So I need to go ahead and order one .I am looking for one only 300-600 increase in rpms over stock .I need a 10 inch , 30 spline one .I dont know whether to get the lockup or non lock up ? Any suggestions guys ? Thanx !
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
If you want the full benifits of overdrive, i.e. better fuel economy at cruise, get non-lockup convertor. Lockup came with your car, & should be replaced with same.
1 Post
Wayne,
Least expensive
proper alternative
get a remanufactured stock convertor INSTALLED for you.
HOW DO YOU KNOW YOUR CONVERTOR IS GIVING YOU THE SHAKES?
Check your replies with the tranny side, they really know their stuff.
Least expensive
proper alternative
Engine: 5.7 / 7.4
my bad, I meant GET LOCKUP CONVERTOR to get full benifit of overdrive tranny.
Maybe I should start preveiwing my responss first
1 Post
Originally posted by KED85
Wayne,
Least expensive
proper alternative
Wayne,
Least expensive
proper alternative
Remember last year when I had the shakes .Well I took it in to the shop and they said it was the converter but they said it might stop if we changed the tranny fluid first .They also told me if it starts shaking again , you have to get a new converter .That was in Oct it was changed . I have not put that many miles on it sence .So its the same shake , does it at the same time and everything . So Im shopping for a converter . I want one thats just 300-600 rpm over stock .
Wayne.
My stock lock up cost me about $100 or less. 300-600 ain't worth the money that you seek to spend.
IF you want to get rid of the shakes and your tranny feels funny, you really think any extra looseness is good now?
AND if ya gonna go to the tranny, I think you'll have it rebuilt at the same time.
You get it done, all at once. Stay stock, cause when it works seamless and proper and "fun" you win.
Your engine feels like new again.
I was real pleased about the rebuild of mine. I liked having a "3.4 sized engine" again.
Save your money and shop for the tranny shop.
1 Post
Wayne.
Wayne.
Wayne, you so win in the end of that financial decision.
Wait until you get the tranny sorted out, to up grade on the cam.
You'll have so much more power, you'll be real pleased.
Now's the time to stretch the car, rebuild, strengthen the foundations (ignition, fuel, air management, tranny) then go back to the engine.... BY INSTALLING A 3.4 SHORT BLOCK. I mean, your heads are rebuilt?
To upgrade the current heads, install stronger springs and make sure your valve guides are in good shape.
You will own this car for a very long time, then.
1 Post
I swear I much be the only v6 guy who isn't running a stock convertor.
TCI 3200 RPM Stall Torque Convertor.
PN is TCI-283200 (I think)
or TCI-323600
I got mine from summit. just let them know that you are looking for a 3200 stall, but the ones they list are too big for the bellhousing.
everyone thinks I'm nuts, or the convertor is too loose. well than how come I can rape a 2.8 or 3.1 auto on the launch?
or TCI-323600
a tranny cooler is a good idea, glad you are looking @ one. my car launches awesome and I lke the better tq multiplycation. I never did get to see the full benefit of my rebuild though. The guy that installed it, installed something wrong, and it's likely that one of the clutches for 1-2 is burnt (or more gears, clutches) because it always shifts out of first @ 5100 and I can't do anythign about it, and recently it stopped holding a gear altogether. if it's in 2, it'll hold 2, but only when I'm on the throttle, when I let off, it'll let off like a clutch, and I'll be rolling in neutral (kinda) it sucks, my car sucks. too bad I can't take the torque convertor out of the camaro and put it in the GP. I'm guessing that's the case because of the camaro being rwd and the gp being fwd w/ a transaxle.
Car: 1986 Firebird
Engine: 2.8 V6
Thanks for the part #! I had posted a message here yesterday; don't know where it went... I said to ask on the Trans/Drivetrain board. Transfixleo (a trans repair guy) has a V6 f-body, and recently rebuilt his transmission. He said he used a higher-stall TC in it; but I never asked him which one.
Oh, and my first trans had no overrun braking (when the trans slows the car down when you let off the gas) before it died... the second one just died on me- no warning at all.
Slowcamaro, that's the way my tranny in my S-10 Blazer always acted. Ever since I had it "rebuilt".
I even had them re-install it corrected and I took them to court. Ran it until it died.
Finally did after about 9 years of no maintenance.
I shifted, manually.
It is bad, just run it until it dies or sue the tranny shop for lousy work.
Wayne, I hear ya 100% on your engine & such.
Try this.
Look for a wrecked 94 & above car
OR
Any 3.4 engined car. Go get the cam from that car.
OR
Do a complete head and cam swap (the Crane cam).
But you will need head work to make the package work better (check all springs, you're gonna rev higher)
One bad weak spring, can instantly ruin a good engine, rev'd to high.
Many people know a person, that has happened to their good engine (new cam-no head checking, spring breaks, valve hits piston).
Tranny-expect to pay close to $500-$800. While you're checking the yards, find a 1987 & later V-6 700R4. You may score a great tranny for lots less. Grab the convertor, too.
One other way to stretch your shopping dollars.
AND get what ya want.
I am not a fan of tranny swaps on the F bodies. Not much tranny tunnel room to move around.
You may have to pay someone else for their labor.
Try this.
OR
OR
a friend rebuilt it and he obviously f*'ed up somewhere. he rebuilt the trans in his truck and GTA a few months later, both were flawless. no warrantyt.
let's put it this way. trans was rebuilt in july of '00 trans fluid smelt burnt by jan '01. line came loose, car pissed out 80% of fluid. replaced that 80% of burnt fluid w/ new amsoil. went on my way. got really poor over last summer than tranny started to get worse. couldn't do anything about it. in oct. I leave my temp job for lunch, and on the way back from lunch, it wasn't holding gears anymore. checked the fluid, was a little low, added some, still bad. scrounged up $50, got friends uncle who is mechanic to to fluid and filter change, cuz I didn't have time and didn't ever do it.
trans was same, but just with new fluid. he said there was some clutch material in the fluid. really fine too, like it's been like it for a long time (july 00 to nov. 01??)
trans is partially cooked AGAIN, this time with over $900 into the rebuild.
$350-400 TC
$150? transkit
$200 for '88 S-10 casing.
then labor, I think he got $250 for it, I don't remember how much I payed him..
anybody know if I can get my convertor to work with the grand prix? that would make it fly!
$350-400 TC
$150? transkit
that's always good to know that my trans is pretty much fried again. more motivation to sell it.
there are so many parts I need to take off and put on my dad's iroc. the fogs, the grille, the tails, the center caps, int. pieces. minbe are better than his.
1 Post
THANX so much for all the help guys !
Karl , I was thinking about finding a 3.4 engine and getting the cam .You must have read my mind My car should feel real nice after all this guys -New injectors , re-built tranny , shift kit , 3.4 cam , work done on heads .I also changed almost all my vacumn hoses and I must say WOW guys .I feel a little more low end torque and more mid-range ! 3 of my hoses were completely shot ! One of the plastic ones had melted and bubbled up and the hose that runs behind the ac had a hole in it the size of a pencil ! If I put a 3.4 cam in , do I have to put roller rockers in ? Also Slow88camaro , thanx for the part numbers !
1 Post
Crower is a wonderful name from along time ago.
They make a good cam for this idea of Waynes'?
Good suggestion.
IF you can find a wrecked 3.4 that someone wants to part out, a used cam is an option.
BUT, ya gotta do the head/spring/guide work also.
Wayne, the stronger you make your foundation (igntion, fuel, exhaust, tranny) the stronger the 2.8 will feel and run.
Will make more torque?
NOT REALLY, it will just perform correct and since ya been driving with it running poor, you'll be pleased with the return on your efforts/dollars.
I'll bet it is idling smoother, too.
Vacuum leaks suck and are so cheap to repair.
Good suggestion.
or TCI-323600
or TCI-323600
My father has a 1980 Z28 with a stroked 350 ( 383 ci ) heavily modded , he has a 3200 stall in that .
I love the way it shifts , you cant even feel it. He more less had to run high stall convertor for the cam . wont idle under 1100 rpm.
well it isn't like the car won't move unless it's @ 3200 or above, though I'm sure it flashes to a higher RPM than stock when jumping on it a little @ low low speeds. mashing it from a dead stop will yield 2500 ish launches. holding it with the brake will give exactly 3200. driving around town it feels normal but if you think of the driving pattern.
1st gear till 38 mashed.
lite throttle it'll shift into 2nd @ 15 and into 3rd @ 25 4th @ 42
it's the same as stock kinda, but there's gotta be a fair amount more clutch slippage below 3200 and a small amount more above. the tranny was way better than stock, I just wish it would have been installed right to really impress me.
