Spark Settings for 6 Cyl MPFI with DIS
Old 10-20-2019 | 06:16 PM
84Elky's Avatar
Car: 84 El Camino
Engine: 360 TPI
Axle/Gears: 3.42 + Truetrac, Moser 28 Spline
Trying to get 6 cyl Fiero with DIS running properly on 7730 ECM with S_AUJP but having problems determining proper spark settings. Anyone know the correct values?
DIS is running with these but not best:
70 deg ($c7) Address 0x025 Initial Spark Advance (Base Distributor)
0 deg ($0000) Address 0x026 Max ADVANCE Relative to SA-REF
-60 deg ($ff55) Address 0x028 Max RETARD Relative to SA-REF
Thanks, Elky
Old 10-21-2019 | 08:44 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Spark Settings for 6 Cyl MPFI with DIS
They are close enough that it should work:
https://www.thirdgen.org/forums/v6/5...ml#post4436973
RBob.
Old 10-21-2019 | 01:04 PM
84Elky's Avatar
Car: 84 El Camino
Engine: 360 TPI
RBob.
Thanks RBob. Wow, so much conflicting info in that thread which is what I've run into after hours of searching. Why is there not a one stop place for such info, or does one exist and I just missed it? With the 6 cyl Chevy using DIS, seems the numbers should be published or available somewhere. What mask/bin did the v6 with DIS use?
To the matter at hand. Simulating the $8d spark calculation at idle with 850 idle RPM =Commanded Idle RPM at temp so there are no adjustments to spark calculation, I get the following:
Initial setting just does not seem right. Way too much REF spark, right?
Changed seems better but still a lot of REF spark to ECM. Which is correct?
Why is SA-TDC less than SA-REF?
Is the difference between TDC and meaningful?
Is the Base setting same as the Reference Angle?
Apologies for all the questions, but really trying to understand this for other than 8 cylinders!
Thanks, Elky
Old 10-21-2019 | 02:19 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Masks $A1, $8F, and $31 are set up for DIS. But note that $A1 and $8F handle these values differently.
RBob.
Old 10-21-2019 | 03:51 PM
84Elky's Avatar
Car: 84 El Camino
Engine: 360 TPI
RBob.
Thanks again RBob! But when time permits, would really appreciate your pondering the other questions.
Elky
95 4x4
05-03-2009 08:36 PM
Gunner823
05-13-2008 10:25 AM
cormyr
01-12-2005 10:27 PM
JPrevost
27
08-30-2004 06:56 AM
Quick Reply: Spark Settings for 6 Cyl MPFI with DIS
