That's not right is it? Camshaft play.
Old 08-26-2018, 01:11 AM
maroe624's Avatar
Car: 92 Z28
Engine: Ramjet 350
Axle/Gears: 3.23 Torsen
Was tearing into my 3.4 and noticed this play in the camshaft. I know some play is ok but seems like a lot. Is it fixable? Nvm the clicking noise it's just the slacking timing chain. Seems like it moves in and out everytime the chain slaps.
Old 08-26-2018, 08:57 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: That's not right is it? Camshaft play.
Replace you're known loose timing chain and the end play will also be reduced.
Old 08-26-2018, 01:04 PM
maroe624's Avatar
Car: 92 Z28
Engine: Ramjet 350
OK good to know..
Old 09-29-2018, 06:41 PM
maroe624's Avatar
Car: 92 Z28
Engine: Ramjet 350
So I replaced my timing set and still have some camshaft play. Is it normal? It's less then before. I also removed the sensor above the camshaft. Could this cause the extra play? Should I put it back in or leave it out or plug it???
Old 09-29-2018, 07:39 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Put it back in or you're going to have oil everywhere.
Old 09-29-2018, 07:42 PM
NoEmissions84TA's Avatar
From looking at your lifters, you have a hydraulic flat tappet camshaft.
So there should NOT be a camshaft retainer plate behind your new timing set.
A roller camshaft would use the retainer plate.
The endplay you refer to is therefore normal. If it really bothers you, you could install a cam button
that limits the back-and-forth movement against the timing cover.
But it is not necessary since flat tappet camshaft lobes are ground with a taper that forces the camshaft
rearward in the block under normal operation.
Roller camshafts do not have that taper to the lobes and that is why they need the retainer plate.
Old 09-29-2018, 08:14 PM
maroe624's Avatar
Car: 92 Z28
Engine: Ramjet 350
Ok good to know thanks for the info.
maroe624's Avatar
Car: 92 Z28
Engine: Ramjet 350
Ok will do.
Old 09-29-2018, 08:25 PM
maroe624's Avatar
Car: 92 Z28
Engine: Ramjet 350
The timing mark on the cam seems to point at 12 o clock and the crank at 12 o clock instead of 12 on the crank and 6 on the cam like the 3.1. Is this correct ??
Old 09-29-2018, 09:10 PM
Rotate the crank 1 turn and the dots will be pointing at each other.
Old 09-29-2018, 09:35 PM
maroe624's Avatar
Car: 92 Z28
Engine: Ramjet 350
When I tore down the motor all stock the crank gear dot was at 12 and the cam at 12 also when I aligned the timing marks. So I'm wondering if this is how it goes stock. I don't wanna set it up wrong. On the 3.1 it's, crank and 12 and cam at 6 facing each other. Will the cam still be in the same position if I turn it to 6 position?
Old 09-29-2018, 10:28 PM
Dots at 12 and 12 or 12 and 6 will be the same thing.
Choose which ever way works easiest, and use it.
Personally I use 12 and 6, because they will be closest to each other. Rotating the crank one full rotation will cause the cam to rotate exactly 1 half turn, turning the crank one full turn again will bring the cam back to it's original position.
IIRC 12 and 6 on the 60 degree V6 will have cylinder #4 at TDC compression stroke.
Old 09-30-2018, 07:25 PM
Stop thinking about this and rotate the crank already. See what happens for yourself. You will have an "A-HA" moment.
maroe624
09-30-2018 07:04 AM
Quick Reply: That's not right is it? Camshaft play.
