3.1 v6 timing chain
1 Post
Car: Firebird
Engine: 3.1
Transmission: 700r4 /borg warner t5
3.1 v6 timing chain
hello i got a 3.1 l v6 firebird with 105.000 miles on it , i dont know if its time to replace the timing chain because the haynes manual says: "if the engine has over 25000 miles on it ,its almost certainly of replacement"is that true or just a printing error? because i cant imagine you need to chage it after only 25k miles
thanks
thanks
Car: 1991 Camaro RS
Engine: BBC 509 Merlin ii 9.6:1 pump gas
Transmission: ATI pro th350 sfi case. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: 3.1 v6 timing chain
if its not giving you any symptoms to change it then i wouldnt unless you plan to tear into the engine and change gaskets, injectors, basically freshen it all up. I didnt change my chain originally untill about 109k miles. It was loose but then again it only takes about 5k miles and they can loosen up a bit anyways.
1 Post
Car: Firebird
Engine: 3.1
thank you
are the DNJ timing chain sets good or crap?
I bought one a long time ago for 35$ to fill my shopping cart at rockauto
