3.1l fuel mixture is off
Old 05-13-2015 | 10:42 AM
Rell_1218's Avatar
Car: 1991 Chevy Camaro RS
Engine: V6 3.1L
Axle/Gears: Stock
my car is fouling out sparks plugs within a week. Currently it is idling rough and I have changed the wires, plugs, cap and button, Ignition coil and a oil change. The tps and map sensor(Nov 2014) are new also .also New injectors and fpr(Nov 2014). Changed the pump in 2013
My car starting to idle rough one night last week. Then it went away the next morning. The following night the problem came back and my car begin sputtering also. I made it home and I have been able to drive it since. Would this issue be timing related?
Old 05-13-2015 | 11:05 AM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Re: 3.1l fuel mixture is off
Originally Posted by Rell_1218
my car is fouling out sparks plugs within a week. Currently it is idling rough and I'll change the wires plugs cap and button. Ignition coil and a oil change. The tps and map sensor are new also . New injectors and fpr. Changed pump in 2013
Timing is doubtful. It's possible the coil, cap and rotor could be up for replacement, I'd start there.
Old 05-13-2015 | 11:24 AM
Rell_1218's Avatar
Engine: V6 3.1L
Axle/Gears: Stock
I had to edit the post but I've already changed those items this week actually
Old 05-14-2015 | 09:17 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Check EGR is not sticking open. Then....?
Old 05-14-2015 | 09:02 PM
willexoIX's Avatar
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
Check for vacuum leaks. A small leak on/near the MAP line could cause a rich condition.
Old 05-29-2015 | 07:57 PM
Rell_1218's Avatar
Engine: V6 3.1L
Axle/Gears: Stock
I changed the plugs again..it ran great for a week and then the problem returned.
Old 05-30-2015 | 06:10 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Pull the FPR vacuum line and prime the fuel pump. Diaphragm in the FPR might be leaking fuel directly into the intake. It might be new-ish, but check anyways.
Then get a pressure gauge and check the fuel pressure. Could also be a leaking injector. Follow this up by checking injector resistance on both banks. Should be 4 ohms. Shorted injector could be holding others on same bank open.
Old 05-31-2015 | 12:41 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
I think injectors should be more like 13-16 ohms each with little variance.
Old 06-01-2015 | 09:02 PM
Rell_1218's Avatar
Engine: V6 3.1L
Axle/Gears: Stock
I bought a fuel pressure gauge and multimeter from summit racing. What fittings do I need to connect the gauge to the fuel rail. Also what should be my ohms for my injectors?
Old 06-02-2015 | 08:24 PM
Rell_1218's Avatar
Engine: V6 3.1L
Axle/Gears: Stock
Will this work?
Old 06-02-2015 | 09:17 PM
Engine: 2.7L V6
Axle/Gears: 4.41
You bought the wrong fuel pressure gauge. Should've bought an Actron fuel pressure tester for fuel injection.
Old 06-03-2015 | 07:21 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Will this work?
Yes, those two parts should work. The line is a little short, but usable. The fuel pressure tap is on the fuel rail behind/below the plenum, in front of the distributor. Can be difficult to see, but it is there.
RBob.
Old 06-06-2015 | 05:51 PM
Rell_1218's Avatar
Engine: V6 3.1L
Axle/Gears: Stock
I was able to check the fuel pressure today. With the key in the On position, it started at 40 psi and dropped almost immediately. When I started the car, the fuel pressure was 35 psi. I'm going to check the injectors tomorrow
jhawkeye
05-25-2022 06:33 PM
theshackle
09-17-2020 08:26 AM
Glowsock
08-02-2020 07:36 PM
92camaroJoe
08-13-2015 06:07 AM
92projectcamaro
08-06-2015 01:20 PM
Quick Reply: 3.1l fuel mixture is off
