Another Turbo 2.8 in progress
Old 01-19-2014, 09:32 AM
  #451
willexoIX's Avatar
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
Re: Another Turbo 2.8 in progress
Originally Posted by project89
no real updates on the iroc , im still waiting on connecting rods , and spirolox for the pistons , im just doing lil odd jobs on it like getting the mirror housings primed fixing small lil bits in the interior
anyways i didnt get a chance to do a new tune for ya , i didnt leave the shop till 11pm went picked up the wife and the proceded to lock my keys in the truck at the taco shop , its almost 12:30 am and i just got in the door lol
sometime tommorow ill get a new tune posted for ya
Its ok, lol. Sounds like an interesting night.
willexoIX is offline
Old 01-19-2014, 10:30 AM
  #452
willexoIX's Avatar
Quick question, I know when you power up the MS, before cranking, the outside 2 LEDs are lit, then normally when the car is started, just the LED by the connector is lit. Now all of a sudden after cranking, the middle LED lights along with the one by the connector. What is the middle LED for in my setup? Warmup indication? Its not on when the laptop is connected.
Old 01-19-2014, 07:10 PM
  #453
project89's Avatar
outer leds are spark , middle led is warmup
heres a new tune i just leaned it out a tad across the board , and i cut back on ae enrichements let me know how it works out
are u still having issues starting once the engine is warmed up i forgot to take away some cranking fuel when the engine is warm
File Type: zip
project89 is offline
Old 01-19-2014, 07:12 PM
  #454
willexoIX's Avatar
I will update either tomorrow night or Tuesday morning on how it does, and post up another datalog. I'm going to spend the day at my girls house. Thank you for the continued help!
I haven't really taken it out, but it's still a little rough starting while hot or cold. First start stalls out unless I give it some gas.
Old 01-19-2014, 07:22 PM
  #455
project89's Avatar
if its stalling first fire when cold i need to add some more after start enrichment , the downside of not having an iac is that u have to really tune the cold start enrichment and after start enrichment for it to work well
on the hot start issue are u having to give it throttle or is it just cranking very slow ?
Old 01-19-2014, 09:10 PM
  #456
willexoIX's Avatar
It cranks fine, just doesnt want to start unless i give it some gas.
Old 01-19-2014, 09:33 PM
  #457
project89's Avatar
ok it has to much fuel then
Old 01-20-2014, 07:57 AM
  #458
project89's Avatar
dont use williebase2 use this one instead
i added some cold start after enrichment
took away soe hot start cranking fuel
added a 6,500 rpm hard rpm limiter , soft limit when it activates is 6,300
i disabled the traction control system for now
i disabled the additive, retractive timing controls ( adds or removes timing based on coolant and air temps ) ill enable this later
made some other minor changes
edit i also fixed the Celsius versus Fahrenheit error
File Type: zip
Old 01-20-2014, 09:18 AM
  #459
willexoIX's Avatar
Sounds good. Ill be home around 9 tonight, which is 6 or 7 your time. Ill let you know how it goes
Edit- i also dont have the launch control switch wired up at the moment, not worried about that till shes running good
Old 01-21-2014, 09:39 AM
  #460
willexoIX's Avatar
I'm about to go out and rerun the power wire for the MS away from the dizzy and coil. The turbo setup is supposed to be delivered today, but the tracking number says that it was never recieved at the sort facility in CO. Only says dispatched to sort facility on the 13th. I find it hard to believe that the usps "misplaced" a 40+ pound sizeable package....
Waiting to hear back from usps as I have initiated an investigation. This is in no part the fault of bl85c, he shipped the package and usps dropped the ball.
Hoping it's one of those rare instances that it's not scanned until it's delivered, although I have had many packages sent via usps, they have always been scanned regularly, yet this package has been in route to the sort facility since the 13th.
Old 01-21-2014, 09:44 AM
  #461
project89's Avatar
thats odd but if they lost it or it got delayed it shoudl say exception on the tracking page
im heading out of town a lil later today so i wont be back on till late tongiht
friggen 120 mile drive today to go do my grocery shopping
Old 01-21-2014, 10:32 AM
  #462
willexoIX's Avatar
Damn, well hopefully you catch this before you leave, wayyyyyyyyy too lean.
File Type: zip
Old 01-21-2014, 10:33 AM
  #463
willexoIX's Avatar
its undriveable lean. when I give it gas, it maxes out the AFR gauge to ---. no power whatsoever. Its like it wants to stop when I give it gas.
The idle is good though, I almost dont have to give it gas to start it, just a little and it starts right up, When I try to drive it, different story.
Old 01-21-2014, 10:36 AM
  #464
project89's Avatar
checking now , i may have pulled to much ae out of it
Old 01-21-2014, 10:42 AM
  #465
project89's Avatar
ok i only added back some ve fuel looks like ae is still a tad rich at low rpm
try this and let me know soon as u can i have about 30 mins before i leave
edit btw , ur never supposed to tune ve and ae at the same time, like i did on ver 3 lmao
File Type: zip
Old 01-21-2014, 10:44 AM
  #466
willexoIX's Avatar
I have to recalibrate the TPS again cause I had to screw with the idle, When I started it it dropped to around 6-700 rpms and stalled after I calibrated the tps.
Old 01-21-2014, 10:54 AM
  #467
willexoIX's Avatar
The beginning is 1/4 pedal to 1/2 pedal, towards the end is 3/4 pedal.
Much better lol, heres the log
Oh and it started without me having to touch the pedal
File Type: zip
Old 01-21-2014, 11:01 AM
  #468
willexoIX's Avatar
Looks like its still glitching though, the power wire no longer runs by the dizzy and coil..
Old 01-21-2014, 11:03 AM
  #469
project89's Avatar
i took out about to much fuel before trying to lean it out , about .4 msec worth to much
dont know if u saw my post edit lol never try to tune ae and ve at the same time
same goes for spark and ve
looking at dl now ill post up some quick changes if needed
Old 01-21-2014, 11:07 AM
  #470
willexoIX's Avatar
Yea I saw that, lol. I read in the manual to never tune spark and ve at the same time, its always tune one, then tune the other, and back and forth.
Good thing I didnt have the turbo on yet, that woulda been bad news lol
Old 01-21-2014, 11:10 AM
  #471
project89's Avatar
its real close , afrs at 3/4 throttle are just a touch lean .
i only saw 2 glitches in the log much less then before, ill keep pan eye on the glitches in the logs , for now its ok
go out and drive the car , give me some nice datalogs, what i want u to do is manually shift so u can hold each gear longer then normal so u can hit each section of the fuel map.
u dont have to make it shift at redline but let the engine rev up a lil bit
do some at light throttle , then some more, then mid throttle etc , dont go wot yet u can if u want but watch the afr gauge if its over 13.5 @ wot back off for now
ae needs a lil more tweaking its a touch rich in the upper low range , and lower mid range taking away .2 msec out of those cells should clear it up
Old 01-21-2014, 11:14 AM
  #472
willexoIX's Avatar
Sounds good, Ill have another datalog or 2 when you get back on. Thanks!
Old 01-21-2014, 11:22 AM
  #473
project89's Avatar
hows it feel power wise compared to the stock ecm?
i still have very limited timing in it and afrs arent dead on yet so it will pick up a bunch
Old 01-21-2014, 11:39 AM
  #474
willexoIX's Avatar
Butt dyno says at least 20 more horse, but thats debatable. It definitely is faster, especially 1/4 and 1/2 pedal. and that was with the first tune. This current one feels about the same as the first tune, maybe a little more power, but I cant be certain
However, that could be because I havent driven it in a little bit, lol. And the exhaust is LOUD. Pretty much a 1 foot straight pipe with a muffler and about 6 inches of pipe after that. What can I say, it sounds better than a full exhaust system, lol. Ill post a starting video soon.
Old 01-21-2014, 12:18 PM
  #475
willexoIX's Avatar
Miraculously the package is out for delivery, with no scans from CO, all the way to my post office in FL. Hmm, either they contracted it out to fedex/ups, or they just never scanned it until now. At least I know Im getting it today
Ill post up pics when I get it, Feels like Christmas all over again
Old 01-21-2014, 02:18 PM
  #476
willexoIX's Avatar
WOOT WOOT! Got the turbo setup! In the next couple days/weeks I need to start accumulating parts(gaskets, misc hardware, couplers for the intercooler, etc...), And start planning for the scoop for the intercooler in the hood.
Heres a pic of the setup, and a little teaser pic of something I picked up from an Air Force supply site, I think its a nice little touch
Getting closer and closer!
Attached Thumbnails Another Turbo 2.8 in progress-img_20140117_133504_237.jpg   Another Turbo 2.8 in progress-img_20140121_144117_108.jpg
Old 01-21-2014, 02:42 PM
  #477
project89's Avatar
Lol I need one of those for my parachute for street driving so it don't accidentally deploy
Old 01-21-2014, 02:46 PM
  #478
willexoIX's Avatar
Minimum order was $20 or so, but they have excellent prices. I got 2 of the kind I took the pic of, and 2 of another style, Both are 6 inches long.
Heres the site I got them off of
http://aeroconsystems.com/cart/remov...-flight-flags/
I thought it would be pretty neat and catch people off guard
Old 01-21-2014, 03:12 PM
  #479
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Lol remove before flight.
bl85c is offline
Old 01-21-2014, 03:36 PM
  #480
willexoIX's Avatar
Hey, its different
Definitely make people look twice, lol
Old 01-22-2014, 05:23 AM
  #481
project89's Avatar
datalogs?
Old 01-22-2014, 11:22 AM
  #482
willexoIX's Avatar
datalogs?
Here they are, didnt get to it yesterday. Lots of resets, only one from me shutting it off to get gas.
File Type: zip
Old 01-22-2014, 12:43 PM
  #483
willexoIX's Avatar
Ill grab another one in a little bit. Still cuts out a little bit in first, but its not a lean cutout, maybe a spark cut out? Key on not started i get both ignition LEDs on, after starting there is only the ignition led by the connector on if that means anything. Other than that she runs much better now. Had a couple spots where it leans out to around 17 ish but i let off to let it richen up.
Old 01-22-2014, 01:15 PM
  #484
project89's Avatar
taking the wife to work ill take a look when i get back
Old 01-22-2014, 01:47 PM
  #485
project89's Avatar
something i should mention is i need datalogs after the warmup enrichment is finished , the entire first half of that datalog it was in warmup mode
i was able to tune out those lean spots though
i only saw 2-3 glitches in the whole log , but megalog viewer dont show me the amount of resets
do u have an aftermarket coil on the car by anychance , may have to ground the other end of the shielding on the ignition wire to the distributor
and yes both outer lights will be on with key on engine off , and u will only see the one nearest the connector lit when engine is on
File Type: zip
Old 01-22-2014, 02:07 PM
  #486
willexoIX's Avatar
Could it be that as far as I know its the original coil? I bought the car in 09, but I dont know if it was replaced before then. It does still have the egr solenoid bracket on it. It reset something like 13 times when i was datalogging it. Im on the mobile app, did you upload another tune?
Ill have to go down to mcdonalds to download it, im at my friends house. But after that it should be warmed up and ill take it on the highway for the next datalog if thats good. I still dont have the tcc connected yet, still trying to decide how I want to do the lockup. A couple pages back there is a post with a link to a couple options for tcc wireup.at the least id like to have lockup in 3rd and 4th, with power routed through the brake switch to unlock under braking
Old 01-22-2014, 02:11 PM
  #487
project89's Avatar
Ill have to go down to mcdonalds to download it, im at my friends house. But after that it should be warmed up and ill take it on the highway for the next datalog if thats good. I still dont have the tcc connected yet, still trying to decide how I want to do the lockup. A couple pages back there is a post with a link to a couple options for tcc wireup.at the least id like to have lockup in 3rd and 4th, with power routed through the brake switch to unlock under breaking.
yeah new tune uploaded , i added a lil bit of fuel in those lean spots , hopefully not to much as those 36.6 injectors seem to be touchy lol
dont worrk about lockup switch right away , ive been driving my v6 car without a lockup ever since i put the turbo on it never hurt the trans even witht he really high stall converter
btw u can have ms control the converter lockup
Old 01-22-2014, 03:05 PM
  #488
willexoIX's Avatar
not the longest datalog, should all be after warmup.
All highway, up to about 112-114mph, 3/4 pedal.
Ill grab another good one in a little while.
File Type: zip
Old 01-22-2014, 03:45 PM
  #489
project89's Avatar
lol talk about beating it like a red headed step child , about 17 seconds 0-114
it will pull harder in 3rd gear once i add more timing in , but i know that timing map is safe for the turbo so im not going to mess with it for now
afrs are okish across the board .5 lean in a few spots @ wot , and a lil rich in a few spots while cruising
ae enrichments are still a bit to rich , u can see when u open the thottle the afr takes a huge dive then comes back up , leaning them out a some will help the motor have a better throttle responce
edit
btw if that wa sinfact only 3/4 throttle u need to calibarte the tps for wot , as it was showing 96% tps
Old 01-22-2014, 04:07 PM
  #490
willexoIX's Avatar
edit
Well i never went to the floor so it coulda been closer to WOT then I thought. Tps is off again though cause im trying to nail down the idle. It seems to travel a little bit. I did forget to recalibrate it again, lol so its probably a little off.
Btw its a turbo off of an 84 mercedes diesel 300D. Trim could be .45 or .55, not 100% sure. TAO314. Its a 3.0l, so pretty close to my displacement. Did a little research last night on it.
Old 01-22-2014, 04:17 PM
  #491
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: BBC 509 Merlin ii 9.6:1 pump gas
Transmission: ATI pro th350 sfi case. TSI 5500 st
Axle/Gears: Strange S60 4:10s
I looked up the comp map of that turbo and I will bet you will be upgrading soon as you get addicted to boost because that turbo will run out of steam fast if you plan on going fast. Just my 2 cents.
fasteddi is offline
Old 01-22-2014, 04:21 PM
  #492
project89's Avatar
that thing seems like a pretty small turbo , i cant find the compressor wheel specs though , the idle will change a lil bit as i or u tune it , so unless the idle goes realy high or low between new tunes id just leave it alone
down the road pick one of theese up
http://www.ebay.com/itm/GT35-3582-Turbo-Charger-Comp-0-70-A-R-4-Bolt-Exhaust-Flange-T3-Manifold-Flange-/271367614342?pt=Motors_Car_Truck_Parts_Accessories&hash=item3f2ec52f86&vxp=mtr
Old 01-22-2014, 04:43 PM
  #493
willexoIX's Avatar
I know i will probably go bigger at some point, but I wanted to start small so I can learn as much as I can out of the experience. I think it will be ok for a daily driver for now, which is what I was aiming for to start. I will probably stick with it for awhile until I go the hybrid route.
I have already learned alot from this thread and numerous others, and from a bunch of members either involved with this thread or helping out.
Old 01-22-2014, 05:20 PM
  #494
project89's Avatar
lol u say that now , but once u see how much power a turbo add,s and u get comfortable with it , u will be on here asking how to get more lol
i give it about 2-3 weeks after u install the turbo kit
Old 01-22-2014, 06:23 PM
  #495
bl85c's Avatar
Car: '85 maro
No joke, I had the same turbo on my 2.8, took it to 15psi and decided that wasn't enough so I put the n2o on it again and ended blowing it up haha. The response was really nice though, not laggy like larger stuff.
bl85c is offline
Old 01-22-2014, 06:53 PM
  #496
willexoIX's Avatar
I already got a manual boost controller, lol. I anticipated that early. TBH I don't think I will push it past 15psi. Remember it needs to be a DD. But that doesnt mean I cant build a hybrid on the side. I'm actually looking at getting a 89 s-10. If I do both of the above, Ill probably rebuild the current 2.8, leave the turbo on and drop it in the s-10, then drop the hybrid with a bigger turbo in the RS
15 psi is probably about where this turbo will become inefficient, even with the IC correct?
Old 01-22-2014, 07:13 PM
  #497
willexoIX's Avatar
I was also tossing around ideas for the intercooler, and being its a smaller one Id like to go as efficient as possible, So I will be doing a top mount setup for the IC, Located to the right and behind the rad, on a 45ish degree angle. That way the output of the IC is a straight shot to the TB. A couple 90* elbows, and a 45* aluminum pipe should be all I need for IC tubing.
Looking through some google images of TMICs, it seems that in order to spread the airflow evenly across the IC, I will have to do a couple horizontal splitters in the scoop. If I dont, the majority of the airflow will be pushed towards the top of the IC, limiting the cooling effect.
It'll be a recessed scoop, nothing too crazy. I have a welder and am learning to weld, so the hood scoop should be pretty easy to start with.
So heres what I will need for the setup as of right now,
Misc bolts for the turbo headers
Misc couplings for the IC
Thick compressible header gaskets
Heat blanket and header wrap
Oil lines and a bung for the pan
Misc tbolt clamps
All of which should run me right around $200 or so
Old 01-22-2014, 10:21 PM
  #498
bl85c's Avatar
Car: '85 maro
Yes that turbo starts pushing hot air at that pressure.
bl85c is offline
Old 01-23-2014, 09:15 AM
  #499
project89's Avatar
do urself a favor do not do a top mount intercooler
get one of theese and stick it in the nose this will fit right in with tons of room to spare
http://www.ebay.com/itm/FULL-ALUMINUM-18-x12-x3-BAR-PLATE-RACING-FMIC-FRONT-MOUNT-TURBO-INTERCOOLER-/290933298881?pt=Motors_Car_Truck_Parts_Accessories&hash=item43bcf9d6c1&vxp=mtr
or u can buy a full kit like this
http://www.ebay.com/itm/8PCS-MANDREL-BENT-PIPING-PIPE-KIT-BLACK-FMIC-FRONT-MOUNT-ALUMINUM-INTERCOOLER-/230946109604?pt=Motors_Car_Truck_Parts_Accessories&hash=item35c575f8a4&vxp=mtr
or u can get the big boy intercooler
http://www.ebay.com/itm/S13-S14-S15-180SX-CA18-SILVIA-R32-33-34-35-Intercooler-31-x-12-x-3-delta-fin-3-/390745010254?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A2004%7CSubmodel%3AX&hash=item5afa37b04e&vxp=mtr
get one with 3 inch in and outlets
edit actually the last one is not the big boy one , the big boy one is the 32x14x4 , which is what im running on my iroc
Old 01-23-2014, 09:42 AM
  #500
willexoIX's Avatar
The current ic I have is 9 1/2w by 7 1/2 tall by 2 3/4 thick. I'm set on the intercooler and for now I want to do as little tubing as possible for efficiency. I'm very limited on funds now so I'm working with what I have. When I go bigger with the turbo, I'll go bigger with the ic.
I completely understand that a fmic will be better, but like I said, I'm working with what I have. I literally have like a $300 budget left for everything, and I'm already like $1100 or $1200 total as of right now. It's gonna be tight, but I picked cheap and reliable, lol, fast wasn't part of the equation. Plus I may wind up having to wait till next month to pick up the rest of the stuff I need cause my dad just bought a garage for the pontoon boat, lol.
Quick Reply: Another Turbo 2.8 in progress
