that stupid heater control valve
Old 04-05-2013 | 07:28 AM
Cadaver_Puncher's Avatar
Car: 92 Camaro rs ( mostly stock for now
Engine: 3.1 v6
Transmission: 700r4 with a b&m megashifter.
Axle/Gears: whatever came stock. wanna posi tho
Oh no...it's not broken at any of the nipples. That would be easy to spot.
It's leaking from around the hat area, and only does so when the heater is off and the vent is on.
Why the hell did they make these outta plastic?
Anyway to bypass it and keep the heater working? I live in the Boston/ Rhode island area and so heat is a necessity.
Old 04-05-2013 | 08:36 AM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: that stupid heater control valve
http://shop.advanceautoparts.com/web...m=heater+valve
It costs 17 bucks and they have them in stock here near my house. You can get them off of eBay for the same price.
I think you'll be happier if you just replace it. I had to undo a "bypass" and it was made out of some horrible plastic crap from home depot.
Old 04-05-2013 | 09:07 AM
Engine: 3.1 v6
But everytime I replace one they fail. The roads here shake the hell out of everything. Plastic doesn't like all the violence.
Old 04-05-2013 | 10:49 AM
KrisW's Avatar
Engine: 2.8/TBI/TPI
Try it again.
I'm really hard on equipment and I haven't had one fail yet. I only have to replace them because they are missing or I break them during some other operation.
I've got mine hanging, suspended mid air by the surrounding hoses on one, and attached to a little bracket on my V6 car. Maybe you just need to mount it in some sort of rubber cushion.
Old 04-05-2013 | 11:06 AM
project89's Avatar
u can bypass it , i do it on every -fbody i own,( them plastic valves always break on me at the worst times) the only down side is in the summer u will get a lil bit of heat out of the vents when u are driving.
i bypass the vlave in the winter so i still have heat then i bypass it so water dont circulate into the heater core in the summer since my car had ac
if u dont have ac u can just leave it so woater always circulated threw the heater core
u can also get a gm i think its the g-body ones that are made out of metal instead of plastic
in order to bypass it u need some hose and 2 water pipe rubber caps
if u dont want to bypass it get some extra long hoses and move the new control valve over twards the fender more away from the hot ex manifold, the heat from the manifold is what makes them get so brittle
Old 04-05-2013 | 11:26 AM
Engine: 3.1 v6
I'll most likely bypass it. I still have ac but wouldn't the temp control slider keep the heater flap thing closed when the ac on?
How would I route and cap things off to bypass it?
Old 04-05-2013 | 11:35 AM
project89's Avatar
its been a while since ive done one id have to be staring at it to tell u which lines to connect to which lines
yeah but u still get a lil heat leaking out even if u set the slider to cold
Old 04-05-2013 | 12:57 PM
Engine: 3.1 v6
That'd still be better than replacing the plastic valve every other month it seems.
Old 04-05-2013 | 03:47 PM
Engine: 3.1 v6
OK weird today I go to go to rot my guts with burger king, turned the vent on and switched to cold and no leak.
Is this going to be a temperamental piece?
Old 04-05-2013 | 05:35 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Not sure why yours keep falling apart like that... Ohio speedbumps (basically parking stops!), very nasty RR crossings (that cracked my windshield), and just about anything else hadn't hurt my HCV one little bit. And it's just a cheapie GP Sorenson or something like that.
Problem with the HCV setup is that both lines running to the heater core have pressurized coolant coming from the core in them. I would have thought that GM would have just welded the other tube to the long runner, but I was wrong. Found that out when I wanted to try to modify mine to delete the HCV (which is useless with a 4th gen dash).
The only way to get rid of the HCV is to get a non-A/C pipe or remove the whole assembly and run custom hoses. Or, as project89 suggested, cap off one of the lines and put a hose on the other.
Old 04-05-2013 | 11:44 PM
Engine: 3.1 v6
OK thanks. Guess I'll just replace it again. Going to advance auto not auto zone this time.
Old 04-05-2013 | 11:55 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I use a brass ball valve from the plumbing dept, just gotta pop the hood for on and off operation.
Old 04-07-2013 | 05:29 AM
Engine: 3.1 v6
How would I hook UP the lines with the brass valve?
Old 04-07-2013 | 12:48 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
you just put it on the feed line, on it lets coolant into the cabin heater box, off it doesn't.
Old 04-08-2013 | 05:46 AM
Engine: 3.1 v6
OK cool.
Is the feed line the one from the water pump or the manifold?
Old 04-08-2013 | 06:06 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Coolant goes from the intake into the core through the valve and then back out of the core into the water pump, just like the radiator (Heater core is just another radiator but smaller).
Old 04-09-2013 | 08:03 AM
Engine: 3.1 v6
OK cool thanks.
1992 Trans Am
05-10-2023 07:19 PM
NORTz89
05-20-2020 03:51 PM
The_Phoenix
02-04-2016 07:10 AM
lakeffect2
08-23-2015 08:44 AM
Quick Reply: that stupid heater control valve
