Car will not crank, just drove it a hour ago and now nothing.
its done this to me once before, I turn the key and it cranks right up. drive a lil while, turn it off. when I turn the key to turn it on again, fuel pump primes, lights battery etc everythings good, turn the key to crank and nothing happens. the motor doesn't even turn over. could it be the starter? has new battery and alternator since about 2 months, its not them. I tried jumping the starter from the 2 wires on it it spun but didn't kick in.
Re: Car will not crank, just drove it a hour ago and now nothing.
So when this is a problem the starter does not engage at all from the key?
If so, make sure the shifter is all the way in park. Also try moving it to neutral. Sometimes the neutral safety switch can move out of adjustment, and cause similar symptoms.
smack the side of the starter with a hammer a few times and hit the key again, brushes could be going bad in the starter.
if it starts after that u know thats the issue and its time for a starter rebuild or new starter
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Would help to know what year as well... Later 3rd gens had a factory starter disable.
1 Post
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.1L V6
Does it just make a clicking sound when you turn the key? I had a similar issue. my car would just click when id turn the key to start and it turned out to be the neutral safety switch.
It was the neutral safety switch wiggled it around and Vrooooooooooom lol hope this helps someone else!
Ghettobird52
07-05-2024 11:18 PM
db057
08-11-2015 10:11 PM
