Problems after v-belt replacement
Old 01-30-2013 | 02:27 AM
K1ng0011's Avatar
Car: 1985 Camaro
Engine: 2.8L v6
I have just replaced the v-belts on my 1985 v6 2.8L and I after I did that I have had two new problems occur. The first is my check engine light started to come on after I have installed the new belts. I checked the error code and it says its a code 22. Which is the tps sensor error. It has a new tps sensor so it is unlikely that it just randomly went bad. The funny thing is that the check engine light comes on and goes off randomly while I am driving. Which indicates something is loose? I have checked it and it is not loose. And it was not moved during the replacement of the v-belts and there was no check engine light before. The other problem is there is a loud screeching sound coming from the AC compressor when I turn on the defroster. Before I replaced the belts that did not happen. I did happen when I turned on the AC but the defrost use to be ok. The heater is working as it should. Any ideas on why these issues would be happening after a v-belt replacement?
Old 01-30-2013 | 07:10 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Re: Problems after v-belt replacement
the tps may have been replaced, but was it calibrated?
recheck all connectors, and for the screeching, a/c may be locking up and the old belt didn't have grip and was just slipping so much it was screeching.
Old 02-02-2013 | 01:35 PM
K1ng0011's Avatar
Car: 1985 Camaro
Engine: 2.8L v6
I figured out the issue for the screeching it was. Before the belt change if I plugged in a electronic wire into the ac compressor it would screech. The belts are tight they have very little ability to bounce. I think the bearings are going out in the compressor. As for the tps sensor error I am not sure. I have adjusted the sensor but that has not fixed the issue. I have checked for loose cables, too.
Old 02-03-2013 | 04:40 PM
K1ng0011's Avatar
Car: 1985 Camaro
Engine: 2.8L v6
Well it looks like project 85 was right about the tps sensor. I tightened the alternator belt a little and then gave the tps some slack on the wires and I adjusted it. That fixed the high idle problem and the check engine light coming on. Now I think the AC compressor or clutch is going out. For now I have it unplugged and it does not cause any issues other than I cant use my AC. Plus I live in Washington so it will be a while before it gets hot. I am thinking of getting it replaced if you guys think it does not need to be let me know.
customblackbird
08-15-2021 11:16 PM
Cleotiz
01-06-2018 09:56 PM
SpaniardV6
Brakes
19
09-07-2015 04:04 AM
Fronzizzle
08-09-2015 02:15 PM
