building a 3.4 and need opinions/advice
#51
Re: building a 3.4 and need opinions/advice
a cheap turbo setup is ur best bet, over were u at u guys have lot of turbo cars right shoudlbe able to find a cheap suitable turbo in the junkyard
#52
Can someone give me a quick list of things I need to take off my 2.8 to use on my 3.4/3500 build?
And what size exhaust would be a good idea?
#53
Car: 89 firebird
Engine: 2.8 soon to be built 3.4
Axle/Gears: 4th gen posi
Ive been following this thread trying to get an idea of what to do for my own build. I basically want to copy this build but would be turboing it down the road, is there anything else or different i would need to do for that?
#54
Car: 1991 Camaro RS
Engine: BBC 509 Merlin ii 9.6:1 pump gas
Transmission: ATI pro th350 sfi case. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Build up that motor if you have the $$.
#55
1 Post
Car: 89 Firebird
Some one say something about wanting ported and polished heads and a 272 cam?
Ported as you can see, polished as you can see, new valve springs, titanium retainers, machined steel valve locks, vitton valves seals, machined heads and spring combo good for .550'' inchs of lift, 1.6 rockers (need 8 or 10 screw in valve studs) and a crane 272 cam.
4 sale.
4 sale.
#56
Car: 89 firebird
so that motor should be able to hold up to 10-15psi no problem being a daily driver and probably beaten on regularly
#57
Car: 89 firebird
I think I have everything down just trying to figure out what pistons to use with the 3500 top end. I know moly rings, and about how much do those run for?
#58
Car: 1991 Camaro RS
I plan on using moly rings too on my engine/build this winter. IIRC there somwhere arround 100-150 bucks for the kit. Or somewhere arround there. Ill find one of the links project89 linked me and post it in a few.
#59
Car: 1991 Camaro RS
So if you have the time to get the engine in better shape, better to do it now then later IMO. As Ive now learned.
Another thing is I was really pushing my car to the limits. I wasent content with a mid 13 second V6 car. I wanted to go faster and faster. Then once my TC started blowing by I just kept upping the boost till I was trapping 107Mph in the 1/4 mile on a normal basis. So if its just a daily fun toy then yea 10 psi if safe on the engine all day. If its a car that you wana really push to the limits...then no 10-15psi could hurt it in time if your unlucky like me, if your lucky then youll be ok but its truley a flip of the coin.
#60
4 sale.
4 sale.
is it the mechanical version of the 272?
