just another sucker for the 6 shooter.
Car: 1992 firebird
Engine: 3.1.... soon to be... bigger.
Transmission: 700r4, looking for t5
Axle/Gears: I havent a clue.
The purpose of this thread is practicality. turbo posts please.
No turbo posts please,
I have neither time nor money for a turbo or a swap.
I have nearly 200,000 miles on my 3.1 and ifters are knocking,
So-
What im looking for is a list of valve train components (Part #s etc.)and general performance engine parts that work well with the 3.1 without any modification of the block.
I need to keep stock fuel delivery, intake etc.
other than that, I can get the ecm tuned for anything else.
Thanks for the help.
So-
Re: just another sucker for the 6 shooter.
260 or 272 cam with valve springs and retianers/locks to match
cam will depend on what else u plan on doing
cam lifters will be 105$'s
springs locks and retianers will be another 100
get urself a couple carbide die grinder bits and port the heads
gasket match the intake and do a lil cleanup on the lower intake were the injector bosses protrude intot he runner
also pick up a new timing chain set
reasemble get a chip burned to take advantage of mods and enjoy
Car: 1992 firebird
Do you have any part #s?
Car: 1992 firebird
Also, I dont plam on any extreme numbers so an overly beefy bottom isnt needed, I just mainly want more midrange grunt. Its plenty fast enough, I look fast amd sound fast. Thats about it lol.
call up deltacams and just ask for a 260 grind cam, it iwll give u the midrange ur looking for and extend the top end
id have to look up the part numbers on the vlave springs and locks/retianers. its been so long since ive had to order any lol, i used to know the part numbers off the top of my head
for some reason comp-916-12 sticks out in my head for the valve springs
Car: 1991 Camaro RS
Engine: BBC 509 Merlin ii 9.6:1 pump gas
Transmission: ATI pro th350 sfi case. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Same as what Project89 said. 260 or 272 Grind cam from deltacams. Some 1.6 roller tip rockers, port and polish the heads yourself, some headers. It all matters what your total budget is. And being that your have a 3.1L thats speed density, emc tuning would be best to get the best power out of the mods you add and to make the car run good.
Have you ever looked at the tuning aspet? Chip burnign or what not? If not do some searching and read some info, as its a good thing to do to the car.
I added a delta 260grind cam, ported/polished the heads and saw a good difference, much more responcive. Not the best video but heres on when I just tuned the idle and part throttle, no WOT tuning. 3.1L Automatic 1991 camaro.
0-60
Its idle after cam break in Sorta lopey which sounds nice but I was also no tuned at the time
0-60
the 272 cam is to much for his goals , the 272 is a upper midrange / high rpm cam
the 260 will give him that midrange power hes looking for with a nice boost in the top end
Car: 1992 firebird
Thanks for the feedback so far guys, I really appreciate it.
So does this deltacams require your core or do they grind you a new cam?
i dont recall anyone here ever having to send them in a core though.
and i know of atleast 8 cams purchased from them, i myself have bought 4
Car: 1991 Camaro RS
Agree, I didnt send my core and the reason they said was becasue of how far I lived away. So they didnt tack on a core charge, just the 20 dollar shipping. It was 130 bucks shipped to my door with the lifters.
Car: 1992 firebird
Is the car driveable with this cam and a stock tune?
Theres a place I will have to take my car, they have in house dyno and all that jazz..
But I jave to get the car there first.
it will be driveable,it will just run really rich at idle and part throttle until u get a tune.
how much are they charging u to tune the car?
Car: 1992 firebird
$160 for a full day on the dyno.
does that include tunning the car? or dyno time only
Car: 1992 firebird
Tuning included.
man thats really cheap, i usually pay 100 bucks an hour for dyno time + extra for wideband use and tuning
Car: 1992 firebird
Yep, I just called the guy about it last week.
Car: 1992 firebird
Ill be sure to post my dyno sheet too
Car: 1991 Camaro RS
Thats a dirt cheep dyno tune, keep us up to date.
Im guessing 115-120 Hp at the wheels with a nice tune and just the cam for a add on, but thats good, definitly noticable. Stock is what 100Hp dave?? I know project89 had a dyno of a stock 3.1L firebird IIRC.
Port those heads while your in there and your good to go(more Hp), porting is free minus the bits.
a stock 3.1 will normally put down between 90-100rwhp
same here deathstar , they strap it down and the guy hops in the car when i say its time for a pull
not normally . hell when i went to get the turbo v6 car dynoed the guy did the first 2 pulls , i made the last pull with no changes i pulled 23hp more and 38fltbs more then his best pull.. he couldnt uderstand how to get the turbo spooled up before the pull started
need to find a place that will let me do my own pulls
Car: 1992 firebird
the place im going to lets you do the pulls, they work all the computer equipment. The shop is like the ONLY race shop for about 100 miles around- they build pretty top notch stuff to. The guy I talked to was very friendly to- apparently he had a v6 camaro (91 I believe,) that pulled late 12s early 13s off the quarter.
and yes theres a few v6 cars here that would run circles around the majorty of the v8 cars on this site
Car: 1992 firebird
Sick 'em fellas! Lol
minigunz i know u said nop turbo posts , but fastedi just removed his original under k setup. send him a pm and see if he will sell it to u.
turbo = 118 bucks
wastegate = 40-60
cheap intercooler is about 50
i know were u can get a set of 28pound injectors for 15 bucks
+ some misc couplers and tubing about 50 bucks
and u could have a running turbo car,fastedi might even be able to supply u with a tune .
all in all it would prolly cost the same as what u had planned anyway
figure about 400$ investment
turbo = 118 bucks
wastegate = 40-60
Car: 1992 firebird
I have to fix the engine first- and the car is my daily driver so I cant afford alot of downtime. I dont want to go to radical- I was mever one to desire a quarter mile monster. im trying to head in the directin of road racing. A track monster instead;-)
Car: 1991 Camaro RS
Can you please go back to the V8 boards, because I could run circles arround your stocker L98 all day. And so could 2 others on this thread.
Sorry for the off topic guys, I just can't stand ignorent V8 guys.
Guest
Posts: n/a
My what? My STOCKER L98? Hmmmm....interesting. Jk. I posted that to show my friend the reactions of you V6 guys when someone insults your engine. I didn't think about coming off as an ignorant *** hole. I know there are more built sixes on here than the eights. And they can run 11's and 12's as well. So my bad.
That's what happens, when you make posts like that.
thats right i forgot u had the noisy valve train issues to deal with
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
It's woth sqeezing everything you can out of your naturaly breathing engine anyways before you start force feeding it anyway IMO. Plus I'd rather learn tuning on a cammed/ported engine first before I went to tuning a boosted engine.
Keep us up to date on what parts you buy and how the project goes!
Car: 1992 firebird
roger that, I plan to post pics as well, as soon as I can find some time away from the 'corps to "get 'r' done."
sreZ28
10-22-2015 08:21 AM
