Need V6 Info
Old 04-21-2012, 04:31 PM
wilhay's Avatar
Car: 1984 Sport Coupe
Engine: v6
Transmission: 5spd.
Need V6 Info
Have 84 camaro sport coupe with 2.8 v6, heard these motors are crap.It is getting tired and i want to rebuild it, but because in my state and county if you change anything such as swapping in a v8 it will not pass inspection. Was wondering if anybody knows if you can rebuild one of these beasts in a heavy duty way and soup it up a little and where i might find the engine parts to do such a rebuild.
Old 04-21-2012, 04:45 PM
89JunkerRS's Avatar
Car: '89 Camaro RS
Axle/Gears: 3.42, Open
Re: Need V6 Info
I beleve they make a 3.1 stroker kit for them, maybe someone else will know a little more about it
Old 04-21-2012, 04:46 PM
ex-x-fire's Avatar
Re: Need V6 Info
I'd find a 87-89 f body 2.8l to rebuild, they have larger bearings, which was the weakness of the earlier 2.8s. They should be easy to find here in the classifieds as alot are swapped out for v8s.
Old 04-21-2012, 05:02 PM
project89's Avatar
Re: Need V6 Info
dont waste ur time rebuilding the 2.8 u have now, go to the junkyard and pick up either a 3.1 or a 3.4 out of a 93-94 camaro and put that in
u just need to swap ur intake and carb onto the new motor and noone will be able to tell the motor is largher since the 3.1 and 3.4 are identical to the 2.8
Old 04-23-2012, 02:33 PM
wilhay's Avatar
Engine: v6
Transmission: 5spd.
Re: Need V6 Info
All that sounds great, but I thought the difference between the early 2.8 (82-86) and the late 2.8 (87-89) was that one was a 60 degree engine and one was a 90 degree engine. Therefore is my stock intake manifold going to fit the later 2.8 or the 3.1 or 3.4 and since the last three mentioned engines are injected instead of carbed how is that going to work?
Old 04-23-2012, 02:55 PM
project89's Avatar
Re: Need V6 Info
they are all 60* engines (2.8/3.1/3.4)
ur intake and carb will swap right onto any of those engines
the 3.1 is a direct swap
the 34 u will have to swap the timing cover and oil pan off ur current 2.8 onto the 3.4 along with ur intake and carb
other then that the motors are identical
Old 04-25-2012, 04:00 PM
wilhay's Avatar
Engine: v6
Transmission: 5spd.
Re: Need V6 Info
Hey, thanks for the help, know where I can get one cheap.
Old 04-27-2012, 09:16 AM
ItstillaV6's Avatar
Car: 92 Camaro RS
Engine: 3.1L(191ci) V6
Transmission: 700-R4
Axle/Gears: 3.23:1
Re: Need V6 Info
I would go for a 90-92 3.1L engine. The GM RPO code is "LH0". What these guys say about the 2.8L is entirely accurate. 82-86 2.8L engines are garbage. The bearing were too small and failed a lot. Also the rear main seals, were notorious for leaking.
The LH0 3.1L uses the same heads, block, and cam, as a 2.8L. Your carb intake will bolt up just fine. You will need to save your exhaust manifolds as well. All thirdgen V6's, with exception to the '89 Firebird 3.8L V6, are 60 degree bank angle engines. The best part about the 3.1L, it looks identical to a 2.8L. Meaning that the guys, at the inspection station, will not know that your engine is not stock. The 3.1L had only 15hp more, than the MPFI 2.8L, so you may not notice a huge gain in performance.
As far as performance, while maintaining street legal, go with Edelbrock "Performer" series parts. They make a carb intake, probably have a street legal carb, and the "Performer" series cams usually utilize an EGR valve, making them street legal. They have higher lift and duration, and are the most cost-effective means of pulling more top-end, out of an engine designed for mid-range power and economy. You may need to save some other odds and ends, like sensors and stuff like that.
Old 04-27-2012, 09:38 AM
On Probation
Atilla the Fun's Avatar
Engine: several
Transmission: none
Axle/Gears: none
Re: Need V6 Info
If your budget permits, you'd probably just do better to use the GMPP crate 3.4 intended for '82-'85 S-10s. It even comes with a legal upgrade cam already installed. Then Edelbrock makes a legal upgrade intake manifold. Pacesetter makes headers, install those after inspection. This will put you ahead of most stock 305s.
Fanatic1074
10-03-2022 05:57 AM
3rdgenparts
05-21-2016 11:50 PM
oil pan 4
Fabrication
10-06-2015 11:56 AM
bjpotter
10-04-2015 07:48 PM
Linson
10-01-2015 09:50 PM
Quick Reply: Need V6 Info
