gunna try something either really cool, or really dumb.
1 Post
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
I have a 3.4l from a 95 camaro. i has also givin an M62 supercharger, its should make 7psi, 8psi MAX. It also came with the 3800 SC injectors. I plan on fabbing a plate and running the SC off the main drive similar to whhat pocket did with his LS1. https://www.thirdgen.org/forums/ltx-...ot-left-4.html
is there anything else i should look for? also i need some suggestions on ECM and tuning. its an 85 ECM and harness with a 5speed.
Car: 92 camaro rs
Engine: 3.4v6 sc
Axle/Gears: 9 bolt 3.73s
Re: gunna try something either really cool, or really dumb.
I BEEN THINKING ABOUT THIS FOR SOME TIME MAYBE ITS TIME TO TRY IT
are u running the speed density ecm or are u using the mass air system?
if using the 2.8L mass air system u should be able to get away with 7-9 psi from the m62 without having to do any real tunning
Car: 92 camaro rs
Engine: 3.4v6 sc
so you think we could make this happen i would like to stick with my 92 SD set up
Car: 1991 Pontiac Trans Am
Axle/Gears: 3:42
that 5 speed is going to explode into a million little peices. You'll need a better trans for sure.
yeah that m62 wont make enough power to blow up that t5, it will make enough power to make that v6 fun to drive though
Car: 2006 Cobalt SS/SC
Engine: LSJ
Transmission: F35 MU3
Axle/Gears: 4.05
I wasn't a fan of Pocket's project, but I would like to see this. Don't let this die!
Car: 92 camaro rs
Engine: 3.4v6 sc
any one help me with a cad set up ill make it happen
