camaro 91 rpm
camaro 91 rpm
hello! need some help please i get my Camaro running again but now this problem with the rpm are to high 8500 the needle pass the gauge reading
i replace the injector, to get i run there is no vacuum leak i check it out, the AIC valve is working the car run good there is any way to reset the computer on the car give any way to work around it
Re: camaro 91 rpm
u can try to take the gauges out and pu the pointer back to zero, sometimes that works.
is the pointer at 0 with the engine off or is it stuck at like 3000,4000 etc
Re: camaro 91 rpm
WELL THIS PART OF THE PROBLEM WHEN TURN THE CAR OFF THE GAUGE GO BACK TO ZERO, I DON'T THINK THAT GAUGE IS STUCK BUT WHEN I START AGAIN GO UP TO 4000 RPM WHEN I DRIVE PASSES THE GAUGE LIMITS, THE CAR RUM GREAT, GOOD POWER, THE MOTOR DO NOT SOUND FORCE OR OVER LOAD
Re: camaro 91 rpm
the gauge is broken u need a new one
Car: check
Engine: check
Transmission: check
Re: camaro 91 rpm
RBob.
eightsixseven
08-14-2015 03:09 PM
