ohm meter tested injectors...
Car: 86 T/A
Engine: 305c.i. carbed, highrise, compcam
Axle/Gears: idk..
ok so i have 6 of these bad boys...i think im doing the ohm reading correctly...heres my results..
(NOT IN ORDER IF CYLINDERS. just numbered so i can remember which is tested at what ohm.)
#1: 5.5
#2:4.5
#3:12.3
#4:11.8
#5:12.5
#6:12.4
i dont know what these numbers means, i assume the 2 low ones means something bad.....help mne decifer plz..
these were tested on an INNOVA-3306 model multi-meter and the setting was set to 200 on the OHM section.
thanks guys
#1: 5.5
#2:4.5
#3:12.3
#4:11.8
#5:12.5
#6:12.4
thanks guys
![driving](https://www.thirdgen.org/forums/images/smilies/driving.gif)
Car: 86 T/A
Axle/Gears: idk..
Re: ohm meter tested injectors...
these are i BELIVE an exact fit..worth the money for um?
http://www.ebay.com/itm/1991-CAMARO-...301742&vxp=mtr
you might want to contact south bay fuel injectors and show your support for a sponsoring company. Mention you are a tgo member for a 10% discount. I think the corsica 15#hr will work but just ask them.
http://www.southbayfuelinjectors.com...injectors.html
Car: 86 T/A
Axle/Gears: idk..
ok sounds good. just curious why u say number 1&2 are good but the rest arent? what SHOULD they all be reading? are they crappy or just dont work well at all and thats what my problem could have been?
Car: 86 T/A
Axle/Gears: idk..
well, i could sell the ones that are good right? so ur saying all of them over 12 are in good shape?
Car: 86 T/A
Axle/Gears: idk..
no the injectors were sitting in my house over night.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: check
Engine: check
Transmission: check
#1: 5.5
#2:4.5
#3:12.3
#4:11.8
#5:12.5
#6:12.4
thanks guys
#1: 5.5
#2:4.5
#3:12.3
#4:11.8
#5:12.5
#6:12.4
thanks guys
Get some reman Bosch injectors from Southbay and be done with it.
{edit: this thread:
https://www.thirdgen.org/forums/v6/6...injectors.html
RBob.
As I posted in one of your other threads, don't even bother checking them, just throw them in the nearest trash can. They are the OEM Multecs which by now had to have coils shorting out (which they are).
RBob.
RBob.
![lol](https://www.thirdgen.org/forums/images/smilies/lol.gif)
![lmao](https://www.thirdgen.org/forums/images/smilies/lmao.gif)
Car: 1991 Camaro RS
Engine: BBC 509 Merlin ii 9.6:1 pump gas
Transmission: ATI pro th350 sfi case. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Agreed toss them and get some good ones!!
Are you ever planning on doing any preformance to the car, im just asking becuase I replaced mine a year ago and decided to add hp, basically making the new ones i had worthless.
Just curious if you have plans to add Hp in the future.
Thanks for your support guys. Just thought I would add my
Let's put it this way 91camaroRS3.1, if a company offered to give us 5,000 or more of the stock injectors for cores for free, we would tell them Thanks but no Thanks! Probably better off using them as a weight on a fishing pole
Whether you purchase from us or not....listen to the other members, they know what they are talking about!
516-442-4707
516-492-6504
![my 2 cents](https://www.thirdgen.org/forums/images/smilies/twocents.gif)
516-442-4707
516-492-6504
Car: 1990 Firebird
Engine: 3.1....4159265
Axle/Gears: axle rose and metal gear solid
Thanks,
BG
Car: 1990 Firebird
:-) thanks for replying! Does anybody know if this random injector on ebay will work? It's from a 1995 ???? 3.1 http://bit.ly/W56pVB. Thanks
It will work...if you are interested, we will be more than happy to help you as we have them in stock.
Give us a shout if we can help
Car: 1990 Firebird
Thanks for the info southbay. I assume one injector can stop the car from running. happy holidays
Car: check
Engine: check
Transmission: check
RBob.
