camshaft 3.1 ???
Car: Camaro 1988
Engine: 305 14.5s 1/4mile
Axle/Gears: 2.73 LSD
camshaft 3.1 ???
camshaft
Edelbrock Performer-Plus Cam and Lifter Kits: EDL-3790 - summitracing.com
What cam can be installed on stock EСM???
thank you
sorry my english
Computer-Controlled Compatible
No
No
thank you
sorry my english
Car: 1991 Camaro RS
Engine: BBC 509 Merlin ii 9.6:1 pump gas
Transmission: ATI pro th350 sfi case. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: camshaft 3.1 ???
Deltacams 260 grind will work, although a tune will help alot exspecially the massive lope at idle. Although the lope sounds good it was a tad rich. And once I tuned the idle the lope went away but ran smoother and such. Ive got alot of different bin files saved for a cammed 3.1L.
Heres my delta cam and the idle after camshaft breakin(stock tune)http://www.youtube.com/watch?v=Kj-BaobBxF4
Hope it helps ya!
Hope it helps ya!
Car: 1982 Firebird
Engine: 2.8 N/A
Transmission: Manual 4 Speed
I personally like the lope. lol
Im hoping once i get mine in itll work out well.
Comp is what i finally decided to go with, this one i believe (except i went with the full kit they offer). http://www.summitracing.com/parts/CCA-16-233-4/
Car: 1991 Camaro RS
Deltacams are 118$ roughly shipped to your door with new lifters included. Best bang for your buck in my mind.
Car: Camaro 1988
I do not understand you!
What can I put a cam on the original program?
https://www.thirdgen.org/forums/v6/3...arts-60-a.html
Car: 1991 Camaro RS
Read this https://www.thirdgen.org/forums/v6/5...ost-power.html Scroll down till you see heads and valvetrain. That explains it well.
more then likley u will need a tune to use that 260 cam , if u cant burn ur own chip ask fastedi he may be able to hook u up with a chip since he had to tune his when he installed the 260 cam
most cams with the 3.1 ecm will require u to tune it, the only thing u can really put in the engine is something very close to stock and then its not really worth it
yes it can be, i sent you a message
Car: 1991 Camaro RS
You just get the eprom adapter from moates, so you can pop in a new chip easily...I have alot of bin files for my car with the delta 260 grind that I can burn you, the chips only 5 bucks... Just pay for the chips and stuff, ill burn them for free for you as many times as you need.
Car: Camaro 1988
Car: Camaro 1988
Car: 1991 Camaro RS
A tune is prefered!!!!
Car: 1991 Camaro RS
Believe me it is not that hard. I have a ton of tunes on my car with a delta 260 grind cam and ported heads. Every cars different but if you ever decide to go this route ill help as much as I can.
Car: 1991 Camaro RS
My opinion.. deltacam.com a delta 260grind will work fine. And you have a MAF system so you really dont need to tune it. I think project89 had that one or a 272grind in his car before.
Cam and lifters kit is roughly 115$ shipped to your door. Best bang for your buck in my opinion
Car: 1991 Camaro RS
0-60. Look faster then your stocker??
http://www.youtube.com/watch?v=vtMKAf_Bh6o 0-60s were under 8secs from what i timed, but thats not too accurate. stock 0-60 times vary from high 9 to mid 10seconds.
Im not sure of the increase from the cam it self and every set up/car varys BUT id safely say I personally got about 15-20Hp from the cam and the ported heads. I ported the heads myself, and it was my first time ever doing that so its not to difficult......
Car: 1991 Camaro RS
Or you could do this to your car>>>
Same car with a turbo/im still learining this part though/this was with a conservitive tune about a month ago.
http://www.youtube.com/watch?v=TxAL0VXkG6c
1 Post
Car: 88 T firebird
Engine: 2.8
Transmission: t5
No problem!
Learning alot fast mate, wish i had the time to play, im hoping to end up with a small supercharger instead, no idea how it will turn out, what cam are you on with the turbo setup ? think im going 272 to start NA.
Car: 1991 Camaro RS
The 260 cam from Delta cams, I didnt get the cam thinking I was going to boost so soon after that mod, but it is a good cam.
88SS6SPEED
11-11-2015 07:05 AM
GTAman
09-26-2015 02:01 PM
