Little build up, how much extra hp will I see?
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
I'm looking at buying a set of 3.1 heads and intake and porting them, buying some pace setter headers, replacing my cat with a straight pipe, and throwing in a bigger cam with a tune, or atleast a delta 260 grind cam, and some bigger injectors. What kind of power increase could I be looking at with just those upgrades? I'm not wanting to throw alot of money into this since I'll be dropping my lt1 in a few years but I want something to tide me over for those years till then.
Car: 1982 Firebird
Engine: 2.8 N/A
Transmission: Manual 4 Speed
Re: Little build up, how much extra hp will I see?
From what ive been told, not as much as im sure youre hoping for. All those things will be great improvments for the car but if youre going for horsepower boost is probably your best bet. I knwi it was brought up in your other thread but unless you have some special reason for doing a straight pipe, just go with a high flow cat. Regardless of emissions in your area its just a good idea imo.
Engine: L31 350
I'm not looking for drastic power, maybe just around 250, enough to scoot around alittle more. After I do this and am still not happy I may throw in a turbo but we will have to see. And I need tossing the idea around about the cat and pipe but the cats can go bad like mine is now, clog, restrict flow, break apart and clog my muffler ect. Straight pipe won't but I'm still looking at it, also I'm going to get some 1.6 roller tip rockers and fiero valve covers.
do the turbo with ported heads it wont cost u much more to to if u can weld
look at fasteddi's turbo build hes in it for under 800 bucks for everything, and im pretty sure he would even burn u a chip for the ecm to handle the turbo
thats about the only way u will get to the power level u want
ported heads and cam untune will get u around 150-170hp at the wheels
nm just relized u have a 2.8 ported heads and cam will put u around 135-150 rwhp
stock 2.8 will dyno around 90-100 rwhp
Car: 1991 Camaro RS
Engine: BBC 509 Merlin ii 9.6:1 pump gas
Transmission: ATI pro th350 sfi case. TSI 5500 st
Axle/Gears: Strange S60 4:10s
0-60 http://www.youtube.com/watch?v=2Srx0vt1R24
Look for the other vids on my channel that have cam and heads in the title.
Car: 1991 Camaro RS
Well worth the $$ and still drives like a normal car when just crusing
Car: 1982 Firebird
Engine: 2.8 N/A
You wont be getting anywhere near 250hp with those mods. The stock 2.8 from an 86 has like 130hp. All the mods suggested are great but theres only so much you can do w/o major mods and/or boost.
Car: 1991 Camaro RS
Yea you want 250 hp then turbo or n20. Im hoping for 250Hp in mine and thats got ported heads, delta cam, and a turbo.
Engine: L31 350
This 2.8 isn't from my 86, it's from a 93 s10. I just retained the mpfi, so I really won't see any gains from the mods and work I'd do?
u will see around 20-35 hp from ported heads and cam, which will be noticable since ur only starting with 120 hp to begin with, which isnt bad for around a 150$ investment
Car: 1991 Camaro RS
@ dave. I make 250+Hp and ill be the happiest V6 thirdgen driver...better yet I make a 13 second pass and ill be so freaking happy!!! I know its gonna happen once I figure out the boost control and tune better.
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
3.1 or 3.4 are way better starting points IMHO... Even just starting from a 3.1 vs a 2.8 you automaticly have a 5hp and 20ft lb jump...
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Lol I only put $250 into my last turbo endeavor. Not including the nitrous stuff anyway... You can install a turbo cheap without bling new parts, just rebuild a jy turbo and do the fabrication yourself. You'll learn more doing it yourself and feel that sparkly feeling after it runs the first time.
Engine: L31 350
im just going to slap a new cam into it and port the heads and intake, and maybe some headers, havent decided yet.
Car: 1991 Camaro RS
[ON] 9 Bolt Axles Partout
6speedIROC
16
03-15-2023 08:33 PM
Mongoose462ci
09-16-2015 11:46 PM
