It Finally Happened....
Car: 1984 Camaro
Engine: V6
Transmission: 700 R4
I need some advice....I just put a 92 Mercury Topaz on the road about a month ago and I got an emission inspection notice today. It is the first time I have ever had to do an inspection and it is to be done on a treadmill. Give me some advice on what to do to pass this thing. I am worried since they got this one that my Camaro maybe next and it needs a new exhaust system.
Dale Earnhardt was a scholar of the race track that drove with the spirit of a warrior.
My Camaro: http://home.earthlink.net/~singleton052095
Car: 1978 El Camino SS
Transmission: T-5 & 3.73's
Run the crap out of it on your way to the test station. You want to get the converter REAL hot to pass the sniffer test. Replacing the O2 sensor before you go would be a good idea too.
BTW, why a Topaz??? Those have got to be one of the worst POS's ever!
Ya can't have too many fast Chevys!
Car: 1984 Camaro
Engine: V6
<font face="Verdana, Arial" size="2">Originally posted by CHVYPWR:
</font>
</font>
This is VERY SIMPLE.
Really!
Check your AIR FILTER, make sure it clean and there is NO OBSTRUCTION to in coming air flow.
Make sure your entire emissions system is intact.
Or make it look so!
Next, go get Gumout Fuel addative.
The White Bottle, Red Label, Long skinny neck stuff.
Two bottles.
Pour it in tank.
Go get Preminum Unleaded fuel. Fill up, "enough" for the smog test.
Go to the freeway and floor the car, from every traffic light, any opportunity you can. For about a day. Before you go for your smog test, drive high speed for about 1/2 hour.
You'll pass with flying colors.
This has worked, EVERY TIME in LA, since 1984, my first smog test out here. Your tread mill test, was simple!
OH, MAKE SURE, when they do the "HIGH RPM testing, THEN, the LOW RPM test, (fast driving to idle at a light) watch he DOES NOT immediatly lift his foot off the gas.
That will load your car engine up with excesive pollution fumes & you will fail.
This trick makes customers "Pay for tune-up" to pass smog at that station. CROOKS!!
WATCH THE GUY LIKE A HAWK during the test, they do this "trick" alot!!
You'll pass easy!!
Thanks Billy!
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
[This message has been edited by KED85 (edited December 09, 2001).]
Really!
Or make it look so!
Two bottles.
Pour it in tank.
You'll pass easy!!
Thanks Billy!
Chat Soon,
KED85
Karl
Car: 1986 Firebird
Engine: 2.8 V6
I ran the treadmill for the first time two years ago (bi-yearly inspection), here's what I did. Keep in mind I always do a yearly tuneup in the Spring; so my other tuneup parts are always relatively fresh (wires, fuel filter, timing, etc)
Brand new K-mart "e-test only" air filter
Pulled dist cap, scraped carbon tracking off
Pulled, cleaned, & checked gap on spark plugs
Cardboard over 1/2 of radiator to help it run hottest
Used "Guaranteed to Pass" (Pep Boys) in the fuel tank; when fuel tank was almost empty, I refilled, and went to take the test.
I passed; lets see if the same thing works for me this January! I hope so; the car's had much more miles on it since 2000, and now I've got the 3.73 rear...
-Tom P (Hot rodded 1986 Firebird 2.8l)
