Starting my motor build up with and intake and headers.....
Car: 1983 Pontiac Firebird
Engine: 400HP 350
I just ordered an edelbrock 2bbl. intake this week and it is coming in the mail soon. This starts my year long motor build up. I need some suggestion on what to do. First things first, My intake i am putting it on my current engine in my car. But i am wondering if it would be a good idea to maybe get a junkyard 2.8L block and build that up instead of my stock motor so i will have something to drive while the build up is going on. I am hoping to get a 3.4L stroker kit from A.R.I. Racing Engines. http://www.engine-parts.com/ It will be there Stage 2 kit with an over bore of 0.030 or 0.090, also a port and polish of heads, MPFI or Carb, probably carb because it will get me more tourqe because of smaller valves. I will also mill the heads so i can get 9.5 to 10.5:1 compression, and a 3 angle vavle job. The last thing will be the 4bbl. top for the intake with a Holley 390cfm carb. and headers. I'm hoping for 300-350+hp. Do you think this is a realistic number?
Now for the exhaust. As you know i've been bosting(spelling) about my rare Heddman Header. Before I any farther(spelling) I want to say i'm sorry for bosting(spelling) I don't mean to do it, it's just i'm happy I found them. I will be happy to email anyone of you guy with measurement if you want them, and I will be in touch with Heddman about bring the headers back into production.
With that said, I need help. I maybe getting the exhaust done next week. Headers and all. I have put up a picture of what my exhaust may look like, Dual inlet/outlet cat, two glasspacks and out the back. I'm think of maybe using another muffler, other then glasspacks and flowmasters. I'm thinking about going with a Dynomax mufflers, but I don't know which one. Any suggestions are well come. I've seen the website about the dual exhaust fbodies, post by Tas in the Exhaust forum. I am think about instead of having the muflers in the middle of my system to moving them to the end of my system like a Jaguar XKR, Corvette, or RiceBoys. To get the most amount of tourqe out of the system. I will go with 2" pipes and cat. and what ever muffler I end up picking. I don't know what do you think? I am open to any and all comments, question, or what ever you have to say about this thread. I will enclose the pic and link to my exhaust system on my website.
Thank you for your comments and questions and what ever in advance,
Robert
http://www.geocities.com/fiream/Robs...l?994187591828
Chevy 2.8L 60° V6
Mods:
?K&N Filter Lid
?87 Formula Hood
?Bosch Platinum +4
?Hi-Flo CatCo CAT
?Flowmaster 80 Series Muffler
?83 Trans Am 15x7 Turbo Fin Wheels
?B.F.Goodrich Radial T/A 225/60-15
?Chevy 2.8L Heddman Headers (Going on soon)
Aol instant messenger: FIREAM
<A HREF="http://digilander.iol.it/simpson50/1_multimedia/simpson/gif_animate/06/homer_14.gif
http://www.geocities.com/fiream/Robs...l?994187591828 TARGET=_blank>http://digilander.iol.it/simpson50/1_multimedia/simpson/gif_animate/06/homer_14.gif
http://www.geocities.com/fiream/RobsCarArtPa.html?994187591828</A>
[This message has been edited by fiream (edited November 07, 2001).]
Robert
Chevy 2.8L 60° V6
Mods:
?K&N Filter Lid
?87 Formula Hood
?Bosch Platinum +4
?Hi-Flo CatCo CAT
Engine: 400HP 350
Also does anyone have a mp3 of there dynomax system???
Chevy 2.8L 60° V6
Mods:
?K&N Filter Lid
?87 Formula Hood
?Bosch Platinum +4
?Hi-Flo CatCo CAT
http://www.geocities.com/fiream/RobsCarArtPa.html?994187591828" TARGET=_blank>http://digilander.iol.it/simpson50/1_multimedia/simpson/gif_animate/06/homer_14.gif
Chevy 2.8L 60° V6
Mods:
?K&N Filter Lid
?87 Formula Hood
?Bosch Platinum +4
?Hi-Flo CatCo CAT
If I am reading this right you plan on running true dual on a V6?, if so DON'T you'll LOSE power. get a 2 inlet one outlet cat and reconfigure. GM performance has 4 BL intakes for the 60* right? I'm not looking at my cat right now so not positive but I thought I saw one. anywho I would even try a 450 CFM, I have seen the 4.3's I know there bigger but running 750's. Why not lose the carb and go TBI from a Vortec 4.3?. it'll fit. as far as what to build up, get a good junker block and have it redone, so you do not lose your car for the whole process.
Honestly you might see 300 but more then likely 280ish. Sorry. I would not put the comp more then 9.0-9.5 small motors really don't like the high constant comp.
As far as the exhaust exit, hell I found a Greddy muffler I LOVE muffler style with twin tube out to a 3" oval down turned tip.
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
use this formula to calculate proper carb size, this is from the Holley site, and assumes 100% volumetric efficiency.
How To Calculate CFM:
Engine size (CID) x maximum RPM / 3456 = CFM
CFM @ 100% volumetric efficiency
173 X 6000rpm /3456 = 300.347 cfm
209 (3.4?) X 6000rpm / 3456 = 362.85 cfm
$150.00 2.8 Auto.
Blown Head Gasket.
turbo has arrived , but put on hold (4 now)
working on dismantling engine, & finding out what parts I need (and Really want)
[This message has been edited by Project: 85 2.8 bird (edited November 08, 2001).]
$150.00 2.8 Auto.
Blown Head Gasket.
Car: 1984 Camaro
Engine: V6
Transmission: 700 R4
Edlebrock makes a 4 barrel intake for the 60* block but whenever I contacted them about it they told me that if I went with the 4 barrel I could not use my computer.
Dale Earnhardt was a scholar of the race track that drove with the spirit of a warrior.
My Camaro: http://home.earthlink.net/~singleton052095
Engine: 400HP 350
No ECM and no EGR, which is what i'm planning to do down the road. but right now I have the 2bbl. edelbrock intake that will be on soon.
Chevy 2.8L 60° V6
Mods:
?K&N Filter Lid
?87 Formula Hood
?Bosch Platinum +4
?Hi-Flo CatCo CAT
Chevy 2.8L 60° V6
Mods:
?K&N Filter Lid
?87 Formula Hood
?Bosch Platinum +4
?Hi-Flo CatCo CAT
