help!!! mpfi hesitation
car started hesatating about 3 weeks ago whenever i go above 3000rmp mainly, but it only starts doin it after 1-2mins of driving.
i replaced
spark plugs
spark plug wires
distrib. cap and rotor
fuel filter
o2 sensor
igintion coil
i have no idea what this could be now, ive done everything i csn think of.... :-(
i replaced
spark plugs
spark plug wires
fuel filter
o2 sensor
igintion coil
Ignition modular, I'd say.
I'll bet it pings, too.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Chat Soon,
KED85
Karl
My car is starting to do a wierd hesitation as well. When I take off at lot light it feels like it bogs and then goes. When I push the gas a little harder it just does it again. The car is going to hit 98,000 mi soon. I am going to replace the plugs, wires, and whatever else I can do next week. Does anyone have any thoughts on what wires I should go for? Also, what other little things can I do? I was also going to take it to the shop to have the timing checked. Thanks!
~Josh~
1992 Firebird
3.1 Liter V6
K&N Filter, everything else stock, for now!!!
~Josh~
1992 Firebird
3.1 Liter V6
Dont forget to check the MAF sensor. Run the motor and take look under the hood. Give the sensor a tap with a screw driver or something. If the motor dies, there you have it.
85 2.8L Sport Coupe 5-speed.
Mods: Hpertech chip and powerstat, MSD 6A-L, Crane fireball coil, Accel Cap and Rotor, Dynomax hi-flow cat and catback system with a dynomax magnum race bullet muffler on the i-pipe, K&N filterchargers, Gutted Air Boxes, 8mm Wires, Eibach Sportlines and Tokiko springs/shocks setup, Global west sub frames, Suspension techniqs front and rear sway bars, and good ole 88 IROC wheels with Kumo Ecstas on em!
"It's not the ricers, it's those damn V8's!"
Wins: 2000 V6 Accord, 69 302 Mustang, 2000 Auto VR6 Jetta, 89 Toyota MR2, 90 Civic Si, 76 350 Camaro, 2000 3.8 5-speed Camaro, ~68 Chevelle 350, 92 CRX Si.
Car: 1986 Firebird
Engine: not stock 2.8
My old Grand Prix used to do the same thing, but only for the first day or 2 after the battery was disconnected.
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
Yeah can somebody come up with a GOOD answer and NO we don't have MAF sensors on our 2.8/3.4 so thats not it. I've replace every ignition component I can buy, and still does it when it's not warmed up. PLUS after it does this boggy crap it shifts hard into 2nd gear. MAKES me mad.
The answer is in your post. You didn't let your car warm up.
Mine bucks like a mule if I don't 3-5 min. to warm up. You can replace all the parts you want but if it is not allowed to warm you will have drivablity isues.
Vacuum problems making the sensors read false signals. Check your hoses for a break.
Chat Soon,
KED85
Karl
Chat Soon,
KED85
Karl
1 Post
Check hoses for breaks... check your O2 sensor, and advance your timing... I'll bet your timing chain is beginning to stretch and causing it to retard, causing the hesitation and slowness...
1985 Camaro SC - 2.8L, auto.
http://www.xenodrgn.f2s.com/Frontright.jpg
BitchinRS
You know what I think about warm-up time, sounds like a GM JUNK answer, make up some excuse why the thing works HALF A**.
<font face="Verdana, Arial" size="2">Originally posted by Ryan_Alswede:
BitchinRS
You know what I think about warm-up time, sounds like a GM JUNK answer, make up some excuse why the thing works HALF A**.</font>
BitchinRS
Try Cangeing the Mass Air Flow Sensor, same problem was here, got my butt kicked by a CRX that I could have taken because of the MAF so try that (dont know how cheap that is)
Nick
Nick
RedLeader289
05-28-2019 01:47 PM
RABMAN
Interior Parts Wanted
09-18-2015 09:02 PM
