Weird power loss...
Car: 1986 Firebird, 2000 WS6
Engine: 2.8, LS1
Transmission: 700R4, T-56
Axle/Gears: Stock, Stock
Weird power loss...
Recently, I've noticed some power loss at the oddest time. It'll take off just fine, but thenit seems like it loses power, then kickes back in again. It seems as if it should be in the powerband, but it loses power. Any ideas?
Thats weird my maro did the same thing, then the SES light went on. I took out my Jet chip so I could get the car serviced and then I put off the servicing becuse I had no money. Then it went away, I popped the chip back in and everything has been great for the past 2 months.
Sorry to hear your problem...I wish I knew a better cure.
Jeff
92 Camaro V6, mods: K&N, modified air box, JET chip 2,high performance muffler.
www.camarors.4t.com
Jeff
www.camarors.4t.com
Engine: 2.8, LS1
Well, I at least know I'm not alone. The only difference is, I don't have a performance chip. It'll only do it sometimes. For instance, I pulled onto the exit road from college and it had no umph. Then I pulled onto a road from college and it was fine. Just a few minutes later, I go to an entrance ramp and floor it, sped up, lost power, then kicked in again, all while the RPM's were still going up. My car is going psycho.
Put a timing light on the balancer and see if timing mark bounces around.
Could need a timing chain
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Chat Soon,
KED85
Karl
well if you scroll down the threads you will find my hesitation saga....sounds like it might be what your car is doing as well. to make a long story short....while in the mid rpms my car would surge kinda, from having power, to nothen, to power again. well after changing out the distribuot, ignition module, fuel filter, O2 sensor and checking for adequete fuel pressure it turned out one of my spark plug boots was cracked and instead of spaking the #3 plug all the time, it would spark against the alternator mounting bracket....not very effective. so i cut a new wire and runs great. i would say start easy....check your wires and plugs...then maybe do the fuel filter, its cheap and good to do....then if that isn't it you can aim for other things like O2 sensor, TPS, distributor, ignition coil, etc....hope that helps. at least if its similiar to the hesitation i was feeling
1990 Firebird 3.1
- Auto Trans, TA Body Kit
- Home Made C.A.I.
- ASP Underdrive Pulleys
- MSD 8.5mm Superconducter Wires (custom-cut)
- MSD GM Blaster Coil
- AC Delco Cap & Rotor
- Bosh Platinum +4 plugs
- Mobil 1 Synthetic Fluids
- 2.5" Hooker Aero-Chamber Cat-back
- 2.5" Hooker Elite Stainless Extension Tips
- GTS Blackouts (stickers removed)
- TB Bypass
KILLS = Dodge Daytona (stick), 2000 Toyota 4 Runner 4WD,
1997ish Ford Explorer, "older" Jeep Cherokee (don't ask why they are all SUVs...who the hell knows?)
LOSSES = 300zx (had him half way through 2nd, he was manual)
"The racing dice added 5hp...I SWEAR!"
1990 Firebird 3.1
- Home Made C.A.I.
- TB Bypass
Engine: 2.8, LS1
I'll have to check that KED. I'll see if one of my friends had a timing light. The SES isn't coming on. Could it still throw a code?I did a tune-up at 88,766. I'm now just past 106,000, but I haven't checked them since. I'll have to check into this stuff. thanks guys and I'll keep ya posted.
sailtexas186548
08-24-2015 10:11 PM
novaderrik
08-10-2015 12:44 PM
