dies out at half-wot
1990 camaro rs 3.1 v6
i just got my tv cable replaced and when i drive from half throttle to wot theres no power the car just kind of dies out. is this a tv cable/tranny problem
or could this be a fuel issue
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: dies out at half-wot
tv cable only controls shift points, where it shifts in the RPMS, the tranny is a big no, its more or less fuel, try running some fuel injector cleaner through it and changing your fuel filter. if that doesnt fix it you may have a clog in the system, injectors going out, a short in the harness for them or the pumps on the way out the door
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
When my father and I got our project s10 blazer the 700r4 was blown and when we put the engine in it would bog out under part throttle we ended up replacing it and part throttle bog gone. Does it do the same thing when you rev it up in park? If so then I would say say check your fuel pressure or fuel filter could be clogged. Did the car do this prior to the TV cable replacement?
but i have not tried to rev it up in park, but if i rev it up in park and it does the same thing then its fuel?
Engine: L31 350
need to get those fixed, more or likely when your at half throttle your starving the car so its dieing
firebird904 Does it do the same thing when you rev it up in park? If so then I would say say check your fuel pressure or fuel filter could be clogged.
the car car does the same thing in park as when i drive it it wont rev past half throttle
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Well, since you've been messing with the TV adjustment, you probably need a transmission as well as a fuel filter/pump/pressure regulator/etc. I'd have to look it up for sure, but I don't think the 700R4 is designed to downshift at WOT, merely to unlock the torque converter clutch.
You don't realize that messing with the TV adjustment can kill the trans in less than 100 miles by overheating it BAD.
Engine: 2.7L V6
Axle/Gears: 4.41
Better check the trans fluid, but it sounds as if a replacement is in order. If the fluid isn't blood red and it's brown or black, chances are so are the clutch plates.
Oh, and there is no fuel pump access panel on an F-body. Get ready for a 3-hour MINIMUM job pulling the rear axle and gas tank. More time for rusted bolts, and possibly more money to replace bolts and other hardware that breaks.
he did tell me that my muffler is on backwards and that why pipes stick out the back, and he did say something about fuel issues i just wanted to make sure this was all bout the fuel lol
Gunner242
12-25-2015 05:49 PM
