3.8 TURBO VS V8s what u think??
1 Post
Car: 87 Vette
Engine: 355/195AFR/SR/219CAM/1.6
Transmission: TH700R4/Vigilante
Axle/Gears: D44/3.45
Hey guys i ve never drive a 3.8TTA cause i live in chile but i have friends with V8 thirdgens and i have the 2.8 V6 i wonder if the mighty 3.8 TTA is faster than the V8s i really liked to know cause im lookin for a TTA bur in chile i cant find one and bring one from USA is to xpensive ..maybe i can bring just the engine and the mighty 2004R tranny
I bought my TTA new back in 1990 and traded in a 1987 Firebird GTA. The 87 with a 350 went 14.48 best at 98 mph. The first time out with the TTA, it went 13.55 at 103. And has since gone 12.32 @116.
Once I get it running again, it should run in the mid to low 11's at 120.
Pete
Pete
I seriously doubt that there was any stock V8 in the 3rd gens that could beat up that TTA. I beleive it is the fastest 3rdgen made.
- Mike Harvey -
1986 Firebird S/E
- Mike Harvey -
1986 Firebird S/E
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
It is...and faster than all but the Ram Air 4th gens....
The only car I fear in my area is a TTA with pillar gagues and a lumnpy idle...even the mighty LT1 would get eaten I'm afraid...
Jason E
'89 Camaro RS
Medium Grey Metallic
2.8, A4, T-tops, 91k miles
'97 Z28 w/30th Anniversary package
LT1, M6, t-tops
White with orange stripes, killer system, 42k miles
Speed Kills...Wanna live forever? Drive a Ford.
Long Live #3...
Jason E
'89 Camaro RS
LT1, M6, t-tops
Long Live #3...
A well built turbo motor will always beat out a 8. PERIOD. I have seen turbo GN and TTA's run into the 9's with little other than upgraded fuel exhaust and intercooler.
<font face="Verdana, Arial" size="2">Originally posted by Jason E:
</font>
</font>
1997 Camaro Z28 5.7L
1992 Camaro RS 3.1L Check my cars out! http://hometown.aol.com/stopsign696/...age/index.html
Loud pipes big rims Wodie thats our life When we pull up at the club Sorry thats our night
</font>
</font>
89 Trans Am Turbo 3.8L All stock 43,000 miles #1053 of 1555
Past Thirdgen:
86 Trans Am w/ built 355TPI with SLP goodies and too much other stuff to List. One sweet *** car, wish I would have had a good enough Job to pay insurance on three cars so I could keep it, but for a 89 Turbo Trans Am w/ Low miles, I think I made the right choice!
<font face="Verdana, Arial" size="2">Originally posted by Kyle F:
All but the '01 Firehawks buddy, and even then its cheaper to mod the **** out of a TTA and go faster than an new LS1 anyways. All I need is an adjustable wastegate and a chip and I am in the 12's
</font>
</font>
umm...I have seen upgraded TTA/Buick GN's go to the mid 10's and into the 11's wth a bigger intercooler and a upgraded turbo. With a few more mods, exhaust intake fuel and some inside motor work your into the 9's. And not 9.99 try 9.4-9.7 at well over 130 MPH...Get a upgraded turbo with an adjustable boost control and you will pick up 2/3 of a sec alone. Again you will be going up 5 PSI easily.
HA Camaro_hunter_d I got ya beat! The fastest GN I have ever seen was a 6 second 1/4 mile I totally didn't believe it! I lost $50 on a bet saying it wouldn't hit the 6's. I do not think it was a daily driver tho. Atleast I HOPE NOT!
<font face="Verdana, Arial" size="2">Originally posted by 20-psi:
Pete</font>
Pete</font>
Monkie,
If it was in the 6's it couldn't be a daily driver, The way the engine would have to be built it would have no vacume so that it could handle high boost levels, basically people tha built those build them only to race and it need boost to fuction porperly.
As far as low 13's heheheh its way to easy, a MAF pipe will put me there(speeds up the spool up) 12's are basically, and this is no liw there is a lot of people doing this, eace gas, drag slicks, and a K&N away. That TA 49 turbo can put a car into the 11's very easily
My plan is to get a Thrasher chip for the strip only with stadging put in. BAsically this chip is designed for 104 octane, which I can get at the track or a gas station in my town, and allows you to run up to 22psi boost. DOT slicks, K&N, MAF pipe, Exhaust Dump, adjustable wastegate, and a little tuning. That will net me low 12's pretty easily because I will be able to leave the line under 8 psi of boost. Then if I put lower control arms and a pan hard rod with an air bad in the rear I should be able, if I can drive well enough and I am sure it will take practice, post 60' times in the 1.6-1.5 range.
These cars are unbelievable easy to get into the 11's and soon I will get there, but you have to crawl before you can run. KNow what I mean,
you should check out the times on Turbo buick.com you will see it doesn't take a whole lot.
The only problem is that most of them have street mode and track mode. The adjustable wastegate allows you to limit your boost to any level. Like say you let your girlfriend borrow your car, you can set it to only 5psi or something real low.
Past Thirdgen:
Past Thirdgen:
New2Chevy
09-28-2015 12:35 AM
