3.4 3400 Questions
Car: 1991 Red RS T-Tops
Engine: 3.1 v6
3.4 3400 Questions
I'm very excited I just got a 3.4 for a very good deal, and am looking at getting a 3400 to make a hybrid. I've been reading all the posts on how to do this, I happened to stumble across the page linked in the sticky about the 3.1/3100 Basic install guide. I was wondering if this guide will basically be the same as what I am doing.
I was also wondering if anyone had any suggestions on cams. Also should I use the crank and pistons from the 3400? I plan on turbo charging it eventually, but for now I just want a solid platform.
This pic is in the back of the van. Its terrible, I know, but I will have more soon.
Re: 3.4 3400 Questions
Yes, use the 3400 pistons.
The crank is the same between the 3.4 an 3400, so which ever one is in better shape is the one to use.
The easiest ECM to use is the 1227730 with a MEMCAL from a V6 Cavalier between the years of '87 and '94. There was a change in 1990 to the type of EGR.
Engine: 3.1 v6
Thanks for the info. Also I was wondering, while ill building this engine, I'd kinda like to throw the 3.4 intake and throttle body on my 3.1, does this require alot? and I will not be using the egr, does this matter?
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
That's not terrible! Your engine is meant for a clutch pedal! That's wonderful!
The guys on THIS forum will have you running your current ECM and learning to tune and burn chips. I can't wait to see how well you get along!
Good luck!
Good luck!
Engine: 2.8/TBI/TPI
I stand corrected on the ECM; however I knew they would have you using a stock GM piece.
Hey, I was close!
Keep on running...
Hey, I was close!
Keep on running...
t fit the 3.4 inatke u will have to have it cut and welded in one place not really a big deal
Engine: 3.1 v6
i dont but pilsbury may , he has moded the 3.4 intake to fit on his motor
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Hopefully soon! I pm'd junkcltr about it... Supposedly it works but no release.
Engine: 3.1 v6
Ok, I found a 99 chevy venture with a 3400, just wanted to check and see if this platform will work alright.
Engine: 3.1 v6
Yeah that's too bad, speaking of 3500, how much is the advantage of a 3500 intake over the 3400?
Someone whos done the hbyrid swap and I know at least 1 person recently has, should really do a writeup on it that we can have made a sticky, would do it myself, but its going to be quite some time before I can attempt the swap for many complicated reasons, I can't even take an accurate guess at when I will do the swap.
Engine: 3.1 v6
Yes, a write up would be nice. I am looking at purchasing a 1999 Grand am for the 3400. My plans are to park the Camaro and drive the Grand Am while I collect parts. Will keep you all posted...
Engine: 3.1 v6
what are the size of the main bolts i need to put this 3.4 on the stand
Engine: 3.1 v6
That's what I meant, someone else had me sayin main bolts, regardless, does anybody know the size?
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
Hmm, the bell housing bolts are M12-1.75 on my blocks. The mains are M11-1.50.
