parts compatibility (?) with fiero ?????????
1 Post
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Hello, i have access to a fiero v6 with holley throttle, does anyone know if the sensors on the holley throttle are the same as ours even though the throttles are different ??
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
Re: parts compatibility (?) with fiero ?????????
The IAC is the same but since the tps is located on the opposite side it's different but has the same connector as the camaro's.
LT1Formula
20
11-14-2015 12:02 AM
camero, compat, compatibility, compatible, fiero, generation, holley, iac, part, parts, suspension, thirdgen, thrid, throttle, transmissions, v6
