3800 V6 :)
3800 V6 :)
i got ahold of a 3800 serries V6 from a 98 V6 camaro. can i swap this into my "new" 1989 firebird V6? i have the wiring harness and everything, will this be an easy swap?
if i get some headers, and a flowmaster system in the back, get a custom ground cam somewhere, ported heads, ported intake, etc. will the exhaust note be like a V8? i really want to swap this all in and have the first "built" V6 on the block
1 Post
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
the transmission is different so you will need the automatic from the 3.8 or the correct bellhousing for a t5.you may can use the motor mounts for a 89 turbo trans am.
<font face="Verdana, Arial" size="2">Originally posted by STL1994:
</font>
</font>
--'87 Camaro LT --
Currently undergoing a 2.8->3.4 swap.....
The biggest difference is the sub frame platforms.
There is no engine, when you open the hood of a 4th gen F body.
It's all under the windshield!
Of course you can do this, but, you will be informing us how to procede.
Yes, the 2.8->3.4 is the WISEST alternative for our 3rd Gen cars.
Your biggest challenge MAY be the oil pan and suspension linkage interference.
Bolt in the tranny and go forward to the engine.
The engine mounts from the TTA is a GREAT idea!
Do you have to be smog legal?
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Chat Soon,
KED85
Karl
forget the smog stuff, i want a built V6. the trans was already taken before i got to the car... and yes i have the computer. think the stock driveshaft will work?
i have NO booklets or anything about wire hook ups, and there's a lot of wires. im not sure if i want to do this now, since i barely ever have time under the hood anymore, ill have to give it some thought, measurements, call, junkyard searches, etc. before can get started anyway
Your best be is to get a service manual for the 98 camaro with a 2.8. You might have to switch out a lot of stuff, but it should be easy. Your best bet is to try to find a Tubo T/A wrecked and get parts off it or atleast measurements. I am getting one soon and I will vbe willing to help with measurements or whatever. Remember this won't be all that hard since a 3.8 was in a thirdgen. Every engine swap is time consuming, look at TomP doing a 2.8 to 2.8 Hasn't been the easiest thing in the world.
Good Luck though and it will definately be interesting.
You can buy Cam and Heads for 3.8s by the way, you dont have to have custom parts made.
FOR SALE!!!!!!!!!!!!!!!
86 Trans Am 355 TPI Rebuilt 700R4 with Corvette servo, modified valve body, and a B&M Torque Converter (2000 rpm stall w/ lock up), 87 350 block bored .30 with new crank. Reworked 305 heads with 3-angle valve job. Added in the rebuild was an SLP TPI cam, BBK 58mm Throttle Body,MSD 6A, Hypertech Power Coil, 1.5 Crane roller tipped rocker arms, SLP Intake Runners and Port matching in upper intake including fully ported plenum, TPIS adjustable fuel pressure regulator @ 46psi, Hooker shorty style headers w/ Thermotech heat wrapping, Custom 3” exhaust with Flowmaster muffler and chrome quad tips, Hypertech Thermomaster Computer chip, K&N open element cone filter on modified MAF per TPIS specs, MSD Wires, removal of A/C hardware and added a 1LE firewall cover installed. Also there has been a PST front suspension kit with Hotchkis strut tower brace added. Soon to have Intrax lowering springs.
http://geocities.com/SunsetStrip/Garage/9548/kyle.html
Kills:
95 Talon TSI, 96 Probe GT, 91 T/A L98, 89 RS, 86 Mustang GT, 88 Mustang LX 5.0, 92 Thunderbird V8. couple or ricers that I think were Civics or Preludes not sure what year, 95 Celica GT-S, 94 Chevy 1/4 ton 350, one of those NASCAR F150's
The Third Gen Will Never be Forgotten
Kills:
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
the vortec V6 would be an even bigger pain than the 3.8.
Kyle, in you kill list you have a 1/4 ton chevy listed......there is no such thing.
Might want to make that a 1/2 ton
<font face="Verdana, Arial" size="2">Originally posted by graebz28:
What about the votec v6. I saw one that I can pick up complete out of a blazer w/ the trans. </font>
The vortec V-6 is an honorary V-8 for the purposes of swap. Is exactly the same height and width as a SBC. It's got the same front and back of a SBC. The only difference is it's 4-3/8" shorter. If your going to go through the trouble of putting a vortec V-6 in a car it makes ALOT more sense to put a 350 in.
wow, who makes a cam and heads for this motor? didnt know they were out there.
anyway, i wont really need to go too far to have sa stout car snce i was looking at some figures. some 305 TPIs had 190 HP, and this motor has 200. i know the 305 has a lot more torque, but it is something to think about
ill be taking measurements soon, but i broke my finger playing basketball, so its hard to measure with a cast on
it sucks to type with 1 hand too, so i better stop.
Cant work with a broke finger? SISSY! ...LOL
I broke my right hand middle finger in a fist fight. I had a splint from my wrist to the tip of my finger for 7 weeks. 2 days after I got the splint I had to change a starter of a ford escort. No I'm not left handed. By the end of 7 weeks I could do anything I wanted, shoot pool, wrench on the car, drink beer, I"d say giving someone the finger was by far the easiest.
LOL! they made me a temporary ghetto splint like your, from the wrist the over the edge of my fingers. the ring finger and pinky finger are paired up together and both broke they are in the huge thing and it gets in the way of everything i do! cant wait till i get the smaller thing.
darwinprice
17
10-11-2015 11:51 PM
