FREE Stuff for more power???
Guest
Posts: n/a
Re: FREE Stuff for more power???
And how do you do that? my car will run cooler some times than others.. Also , My service engine soon light comes on for a few seconds and goes off.. Why u think it does that?
And sometimes when i rev my engine up it will rev up and then go to 1500 rpm for about 10-15 seconds then go back down to normal idle.. I cant figure out why..?
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Here's what you do. Get a cooler and fill it with bags of ice. Put it in the back of your car. When you start it up put a bag on the manifold and every 10 minutes put another bag on. OR here's another one- get a crapload of fire extingushers (co2 not powder) and cut the end off the hoses. Insert it between the upper & lower manifolds. Tape the handle down and go for a ride! Or wait, cut a hole in the hood and tape a fan over it to suck the hot air out! That will create more downforce too!
I've got tons of ideas! Oh crap you need money to do all those... Well you can still cut a hole in your hood!
Seriously though you're not going to get free power. Have you checked what the code is?
1 Post
Car: 87 Camaro
Engine: 305 LG4 (H)
Gods honest truth - nothing. There is nothing "free" you can do to actually make the car faster. That holds true for virtually every N/A car. To make any sort of credible difference you need to change the rear end gears or some sort of forced induction.
there is one thing "removing wieght form the car" thats about the one thing that is free that can make a noticable difference
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
I'd worry about what's wrong with the car before I started thinking about making it faster. Check the codes (search to figure out how to do it), then report what, if any, code it's throwing.
Im assuming you just bought it, so it probably is in desperate need of a major tune up. It's not free, but will get you to a point where you can start to diagnose any other problems. Search for Tom P.'s major tune-up.
Oh and also.
READ MY STICKY
1992rs/ss
05-19-2020 07:02 PM
lt1z350
09-29-2015 01:50 PM
backtothe80s
09-05-2015 12:39 AM
