Chalk one up for the 6ers! (tech at the bottom)
Old 03-04-2001 | 04:56 PM
RenoLB8's Avatar
A friend in an eighties Cutlass with a 305/4bbl, K&N filter, no other mods that I know of. Came up to him at a light, we both revved up, I spun a little, but still SPANKED him. Second light, I gave him a car length run ahead of me, and SPANKED HIM AGAIN!!!! He was pissed, but we were both laughing about it.
Also, I ran some numbers on the HP calculator (is it here or at another site?), and it gave me back 165 HP, so apparently the mods are working. What I want to know is why my times are so bottomed out then (17's)? Any mods I can do to help apply the HP to the pavement? Or what are everyone's launch techniques? Thanks ahead guys, and don't listen to the 8's.
-Reno
88 Firebird
"Cerberus"
"You think you're weak and maybe I'm the cure, but I've got 6 cylinders under my hood, and I got one for ya, it's a long shot..."
Old 03-04-2001 | 05:47 PM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
us V8 guys might know something about how to launch...otherwise we're pretty much useless. Do you have a stick or auto?
If you have an auto I would suggest launching off the break at about 1500.
If you have a stick I would say that you should pop the clutch out at 2000, then after the car pops and is diving, floor the **** out of it.
of course these will need to be fine tuned- but its a good place to start.
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 224/230 duration and .477/.480 lift. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, 3000 stallconverter. Edelbrock TES, 3inch cat, flowmaster with single 2.5 inch exit.
Best time yet to come
12's?? :crossthumbs:
This is a Pic of my car in race trim www.tbns.net/billyjay/camero.jpg
Old 03-04-2001 | 06:16 PM
RenoLB8's Avatar
I've got an auto and usually launch around 2500, but I always get a little spin, and if the track is wet, I get mad spin and my already crappy time drops into the 18's. thanks for the advice, I"ll have to try it.
-Reno
'88 Firebird LB8
"Cerberus"
http://www.angelfire.com/il/Firebird28/index.html
Old 03-04-2001 | 06:19 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
with my auto, i rev to 2k. With my foot on the brake, then jump off the brake. It'll give me about 1 tire rotation, and a chirp, but the car really moves. I've dried 1500, but then i'm to far away from the powerband.
Old 03-04-2001 | 09:46 PM
Kyle F's Avatar
Well I launch at 2200 RPM at about half throttle, tire spins a tad, chirps and grabs, then I floor it. This gives me about 1.7's 60' times and about 13.9 1/4's on 235/60 street tires at 32psi. There are manythings to try, just try them and see what works best for you guys.
BTW where is this thing to calculate your HP?
86 Trans Am 355 TPI Rebuilt 700R4 with Corvette servo, modified valve body, and a B&M Torque Converter (2000 rpm stall w/ lock up), 87 350 block bored .30 with new crank. Reworked 305 heads with 3-angle valve job. Added in the rebuild was an SLP TPI cam, BBK 58mm Throttle Body,MSD 6A, Hypertech Power Coil, 1.5 Crane roller tipped rocker arms, SLP Intake Runners and Port matching in upper intake including fully ported plenum, TPIS adjustable fuel pressure regulator @ 46psi, Hooker shorty style headers w/ Thermotech heat wrapping, Custom 3” exhaust with Flowmaster muffler and chrome quad tips, Hypertech Thermomaster Computer chip, K&N open element cone filter on modified MAF per TPIS specs, MSD Wires, removal of A/C hardware and added a 1LE firewall cover installed. Also there has been a PST front suspension kit with Hotchkis strut tower brace added. Soon to have Intrax lowering springs.
http://geocities.com/SunsetStrip/Garage/9548/kyle.html
Kills:
95 Talon TSI, 96 Probe GT, 91 T/A L98, 89 RS, 86 Mustang GT, 88 Mustang LX 5.0, 92 Thunderbird V8. couple or ricers that I think were Civics or Preludes not sure what year, 95 Celica GT-S, 94 Chevy 1/4 ton 350, one of those NASCAR F150's
The Third Gen Will Never be Forgotten
3rd gen money
10-11-2019 10:57 PM
MrPackstin
10-25-2017 09:09 PM
jaridjohn
10-05-2015 08:01 AM
Quick Reply: Chalk one up for the 6ers! (tech at the bottom)
