Burnout......
1 Post
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
Burnout......
Hey when ever i do a burnout on my camaro for some reason the rear passenger side tire seems to smoke and on the other hand the driver side tire doesnt seem to smoke at all. One day I got out of my car and I looked at the tire tracks and apparently only the passenger side tires were apparent on the cement and no marks were left from the rear drivers side tire. Would you guys happen to know what might cause this problem?I have also inflated both rear tires to 35 PSI each as well same thing with the front ones, thanks!
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: Burnout......
exactly, you have a open rear, a one wheel wonder... its only going to spin the one tire 98 percent of the time.
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
Re: Burnout......
I have a feeling this is gonna be a funny thread.
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
Re: Burnout......
do a burnout going forward and leave a mark
stop
put in reverse
do another burnout backwards the same length
itll look like this
stop
put in reverse
itll look like this
1 Post
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: Burnout......
C'mon guys don't be dicks. You all didn't know this stuff from birth.
Cal most cheap standard axles will only ever spin one wheel. The one with the least traction. You need a different (more expensive) type that will spin both. Usually called a posi (Posi-traction) or maybe a locker.
1 Post
Car: 1984 Z28
Re: Burnout......
thanks for the help...would you happen to know where i can buy em...or a link..I just wanna gte lke an estimate of how much it would be thanks!
1 Post
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Re: Burnout......
You could try junk yards and look for one of a higher performance V8 3rd. gen. However, the V6 doesn't really have the torque to spin both wheels on a dry road. You'd need wet/snow/gravel or such or something to break the wheels free to start them spinning. Or very narrow hard tires. But you may be in for some disappointment in the burn out department.
Re: Burnout......
Mine didn't seem to have any problem spinning both tires with the posi on dry concrete
Re: Burnout......
Re: Burnout......
Car: 91' Firebird
Engine: 3.1 LH0 V6
Re: Burnout......
I don't think most people call one wheel breaktorques "bad-***."
Fortunatley I don't have to worry about that
Re: Burnout......
and yes it spins like its rainging out on dry ground, ud think its a v8 smoke everywher power brake into a sideways burnout, wont do it unless i power brake it first, if i just floor it im lucky if it chirps one side, 90% of the time if i am to power brake it it spins both sides
Re: Burnout......
Perhaps i just did it wrong, because there was another time when i did that, and left TWO streaks.
Of course, my Trans was overfull on ATF and im actually a little bit scared to "drop the pan." Changed some ATF its at its right level now... but, when raining, it will spin baby spinnnn... and once or twie just by "punching the gas" while in my parkign lot, once completely by accident, i spun both tires for a few seconds, very bad-***
Question.. does high rear tire pressure ~35psi or LOW help the burn-outs? Also, the differential fluid level comes to mind, mine hasnt been touched forever........
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Re: Burnout......
You should try revving it way up and putting it in gear. It's called a 'neutral bomb'. And get a video of it so we can laugh at you.
Re: Burnout......
and any day on dry ground, it already in gear if i hold the brake and floor it to power brake it it just brakes loose and spins both tires very easily, great smoke show
Re: Burnout......
1) You may laugh a me without this video.
2) After i "Steal my camera back" OR have he Lord inetrvene, and get a better camera than what was taken from me... I will.
3) I thought you messed the trans up by doing that. Though you are right it
.. but standing on he brakes makes nice mark. I onder if i can get i to do bth, you MIGH talk me ino i..
FL *MAY* put me in Jail the ast time i did that, in fron of somene. So, keep it comin
* My spellign sucks, but look, if i can make $$$ buyign and sellign lapops which i hope and think i can and buy anoher camera, i will post thsi video fr you.
In the meantime, here is me in my Thrid Gen. Featuring he interior, and Jacksonville, FL. On a sunny day..... you can har the engine too. http://www.youtube.com/watch?v=doxnRbaLKsA
