looking for a flywheel
Old 03-15-2011 | 07:20 PM
mikey88firebird's Avatar
Car: 1987 Pontiac Firebird
Engine: 2.8
Transmission: t5
Axle/Gears: not low enough
I know this isnt the right area for this but does anybody have a manual trans flywheel for 82-84 firebird,camaro with the 2.8 I cannot find any and the s10 flywheel isnt thick enough for the fbody! I figured with this being v6 forum you guys might help me out
Old 03-15-2011 | 07:58 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: looking for a flywheel
Look on eBay... Got mine there. It's too bad I don't have my other wheel, or I'd sell it to you (got the wrong one with the trans swap parts). You may want to look for whole engines and then email the seller to see if he has a wheel for it, that's how I got mine.
BTW, it's not 82-84, it's 82-87, ANY manual trans wheel (FWD or RWD) will work as long as it has the balance weight on the engine side.
Old 03-15-2011 | 08:16 PM
Engine: 2.8
Transmission: t5
I thought they changed the balance in 85 to internal? well I know that you cant use an s10 flywheel not thick enough
Old 03-15-2011 | 09:48 PM
Engine: 2.7L V6
Axle/Gears: 4.41
I don't know who told you either one, but they're wrong in either case. The balance was changed for 88, and all of the wheels are the same before and after then. Why would they use a different flywheel on an S10 with a T5 than they did on an F-body with the same transmission? You obviously were looking at a FLEXPLATE and not a flywheel. There's a difference between the 2, mostly the price. If it cost less than about $60, it's a flexplate for an auto trans. If it cost about $150, that's what you're looking for.
Old 03-22-2011 | 09:20 PM
Engine: 2.8
Transmission: t5
well i ordered a flywheel for my bird and there is a difference a huge difference actually the s10 flywheel was 3/4 of an inch where as the firebird flywheel was 1 1/2 thick! just thought i would follow up so this can maybe help somebody else
Cam-aro
Camaros Wanted
11-12-2015 04:35 PM
Vincent135
09-28-2015 11:50 PM
mfp189
09-27-2015 10:25 AM
monte87cortez
09-26-2015 09:10 PM
el_muerte
09-16-2015 01:01 AM
Quick Reply: looking for a flywheel
