Fiero Throttle Bodies
The Fiero throttle body is better than ours right? If so would it be worth putting one on a v6? And would it go on both the 2.8L and 3.1L? How much difference would you be able to tell? And where do you get it at?
Ok I just went to this site and they have a big bore throttle body for the 85-88 Fiero. The only thing is that the throttle body is $199 and then the site has a core charge that is another $100. Here is what they say about it.....
This throttle body has a 3mm larger bore size than the stock. Together with a new throttle plate, throttle shaft bushings, and a re-machined idle air control valve seat, the performance throttle body will flow much greater air than the stock unit. You must also add part #57509 to your order, which will be refunded upon return of your old throttle body, provided that it is in rebuildable condition.
Is it worth it. And I dont think the Fieros had a 3.1L and I do so does that mean it wont fit or work on my car?
Car: 1984 Camaro
Engine: V6
Transmission: 700 R4
Monkie,
Maybe check out http://www.pennock.nl/forum.htm that is a really good Fiero forum I bet they could answer some of your questions
"5 out of 4 people have a problem with fractions"
My Camaro: http://home.earthlink.net/~singleton052095
Car: 1986 Firebird
Engine: 2.8 V6
I wouldn't say it's a bad idea, or that it could hurt things... but $300's alot of cash. Have you covered all the other mods in that range?
Oh and AFAIK, the 3.1 throttle body's the same as the 2.8 throttle body. I mean, both have to bolt up to the plenum, and that didn't change, right?
You could probably find a 2.8 f-body motor in a junkyard to compare yours with. Actually maybe you'll find a Fiero TB hanging around!
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
Terrell351
06-13-2021 01:13 PM
mdtoren
08-16-2015 05:45 PM
