Oil pressure gauge is pegged straight up.
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
Well this is the next thing on my repair list, to fix my oil pressure gauge. Is there any way to tell if it's the sensor or the gauge? It stays straight up no matter what.
Re: Oil pressure gauge is pegged straight up.
probably the sending unit, they are only like $10-20, plus you could just take it back if its not that. although, is it straight up with the car completely off? if so it might be the gauge..
Car: 1988 camaro
Engine: cammed 3.1
Yeah it stays pegged to the top at all times even when it's off my fuel gauge is also messed up.
Probably your cluster then..
Car: 1988 camaro
Engine: cammed 3.1
Is there a way to fix the gauge or should I just pick up the tach and oil pressure gauge set up at the junkyard?
no clue, but wait for someone else to chime in before buying anything, it could even just be loose...
Car: 1990 Camaro RS
Engine: 355 Vortec TPI LT4 Hotcam
Transmission: TH700-R4
I've been having problems with mine too.....and the tach....and the voltmeter.....lol
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
when the sensor wire to the gauge is broken, it pegs, when its grounded, it drops to 0.
ground that wire manually, such as unplugging it from your oil pressure sensor and grounding it with a piece of wire.
Car: 1988 camaro
Engine: cammed 3.1
I tried grounding it and it stayed the same.
Car: 1988 camaro
Engine: cammed 3.1
Yeah its the sensor by the oil filter with one wire going to it right?
Car: '02 Z06
Engine: L33 5.7
yea, with ignition key on, if you ground that wire running to the sensor and its not fluctuating the gauge, then the issue is not the sensor, but either a broken connection somewhere between the wire and the gauge, or the gauge itself.
ambainb
04-25-2016 09:21 PM
